Masterpage orientation = landscape. Report prints and exports in portrait #2 [message #923501] |
Wed, 26 September 2012 00:39 |
j k Messages: 436 Registered: September 2012 |
Cant reply to my thread anymore. Same thing's happened a few times. I actually only have 4 or 5 posts. No idea where the 400+ came from
reply to : http://www.eclipse.org/forums/index.php/t/383902/
Hi Jason,
made no difference
i fixed the watermark truncation when exporting to pdf by using pixels instead of inches when setting the size of the header grid.
the existing behaviour is
view in browser - print as html - prints as portrait. incorrect pagination (rows split over a page, wrong page numbers)
view in browser - print as pdf - fit on single page. tiny portrait table on landscape oriented page
view in browser - print as pdf - auto. Mostly correct now with the watermark showing. Some field truncation. Incorrect page numbers - there are 127 pages but every page shows 1 of 1. I use the following code in a dynamic text box in the footer
"Page " + pageNumber + " of " + totalPage;
I did notice that when i used the autotext "page n of m "that it worked correctly in PDF. Is there any way to format the auto text into a 'neater' format so that it doesnt look like
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.17" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.3.2.r232_v20090521 Build <2.3.2.v20090601-0700></property>
<property name="units">in</property>
<text-property name="title">REFUNDS AND REPAYMENTS AUTHORISED</text-property>
<method name="initialize"><![CDATA[function wrap(longStr, width){
length = longStr.length;
if(length <= width)
return longStr;
return (longStr.substring(0, width) + "\u200B" + wrap(longStr.substring(width, length), width));
}]]></method>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<list-property name="libraries">
<structure>
<property name="fileName">CAMSReportLibrary.config.rptlibrary</property>
<property name="namespace">CAMSReportLibrary</property>
</structure>
</list-property>
<parameters>
<scalar-parameter name="FromDate" id="400">
<property name="valueType">static</property>
<property name="dataType">dateTime</property>
<property name="paramType">simple</property>
<text-property name="promptText">From Date</text-property>
<property name="controlType">text-box</property>
<property name="distinct">true</property>
<structure name="format">
<property name="category">Medium Date</property>
<property name="pattern">Medium Date</property>
</structure>
</scalar-parameter>
<scalar-parameter name="ToDate" id="401">
<text-property name="promptText">To Date</text-property>
</structure>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc" name="JDBCmaximoDataSource" id="7"
extends="CAMSReportLibrary.JDBCmaximoDataSource"/>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.SPSelectDataSet" name="RefundsRepayments" id="402">
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">GroupID</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">GroupLabel</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">CaseType</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">CaseNumber</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">Applicant</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">ApprovalDate</property>
<property name="dataType">date-time</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">ApprovedBy</property>
</structure>
<structure>
<property name="position">8</property>
<property name="name">Amount</property>
<property name="dataType">decimal</property>
</structure>
<structure>
<property name="position">9</property>
<property name="name">Reason</property>
</structure>
</list-property>
</structure>
<property name="dataSource">JDBCmaximoDataSource</property>
<list-property name="parameters">
<structure>
<property name="name">@FromDate</property>
<property name="paramName">FromDate</property>
<property name="nativeName">@FromDate</property>
<property name="nativeDataType">93</property>
<property name="isOptional">true</property>
<property name="allowNull">true</property>
<property name="isInput">true</property>
<property name="isOutput">false</property>
</structure>
<structure>
<property name="name">@ToDate</property>
<property name="paramName">ToDate</property>
<property name="nativeName">@ToDate</property>
</structure>
</list-property>
<structure>
<property name="nativeName">GroupID</property>
</structure>
<structure>
<property name="nativeName">GroupLabel</property>
</structure>
<structure>
<property name="nativeName">CaseType</property>
</structure>
<structure>
<property name="nativeName">CaseNumber</property>
</structure>
<structure>
<property name="nativeName">Applicant</property>
</structure>
<structure>
<property name="nativeName">ApprovalDate</property>
</structure>
<structure>
<property name="nativeName">ApprovedBy</property>
</structure>
<structure>
<property name="nativeName">Amount</property>
</structure>
<structure>
<property name="nativeName">Reason</property>
</structure>
</list-property>
<property name="queryText">{call Report.usp_GetRefundsRepaymentsReport(?,?)} </property>
<xml-property name="designerValues"><![CDATA[<?xml version="1.0" encoding="UTF-8"?>
<model:DesignValues xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design" xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:DataSetParameters>
<design:parameterDefinitions>
<design:inOutMode>In</design:inOutMode>
<design:attributes>
<design:name>@FromDate</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>93</design:nativeDataTypeCode>
<design:precision>23</design:precision>
<design:scale>3</design:scale>
<design:nullability>Nullable</design:nullability>
</design:attributes>
<design:inputAttributes>
<design:elementAttributes>
<design:optional>true</design:optional>
</design:elementAttributes>
</design:inputAttributes>
</design:parameterDefinitions>
<design:attributes>
<design:name>@ToDate</design:name>
<design:position>2</design:position>
</design:DataSetParameters>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">"Verdana"</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="CAMS from to date Master Page" id="8" extends="CAMSReportLibrary.CAMS from to date Master Page">
<overridden-values>
<ref-entry baseId="378" name="HdrGrid" id="378"/>
<ref-entry baseId="379" id="379"/>
<ref-entry baseId="380" id="380"/>
<ref-entry baseId="381" id="381"/>
<ref-entry baseId="382" name="HdrTopGrid" id="382"/>
<ref-entry baseId="383" id="383"/>
<ref-entry baseId="384" id="384"/>
<ref-entry baseId="385" id="385"/>
<ref-entry baseId="386" id="386"/>
<ref-entry baseId="387" name="SAWaterLogo" id="387"/>
<ref-entry baseId="388" id="388"/>
<ref-entry baseId="389" name="CamsTitle" id="389"/>
<ref-entry baseId="390" id="390"/>
<ref-entry baseId="391" id="391"/>
<ref-entry baseId="392" name="HdrBottomGrid" id="392"/>
<ref-entry baseId="393" id="393"/>
<ref-entry baseId="394" id="394"/>
<ref-entry baseId="395" id="395"/>
<ref-entry baseId="396" id="396"/>
<ref-entry baseId="397" name="RepTitle" id="397"/>
<ref-entry baseId="398" id="398"/>
<ref-entry baseId="399" name="ToFromLabel" id="399"/>
<ref-entry baseId="283" name="FtrGrid" id="283"/>
<ref-entry baseId="284" id="284"/>
<ref-entry baseId="285" id="285"/>
<ref-entry baseId="286" id="286"/>
<ref-entry baseId="287" id="287"/>
<ref-entry baseId="282" name="RunDate" id="282"/>
<ref-entry baseId="288" id="288"/>
<ref-entry baseId="302" name="PageNo" id="302"/>
</overridden-values>
</simple-master-page>
</page-setup>
<body>
<label id="444">
<text-property name="text"> </text-property>
</label>
<table id="73">
<property name="fontSize">large</property>
<property name="marginTop">1pt</property>
<property name="marginLeft">1pt</property>
<property name="marginBottom">1pt</property>
<property name="marginRight">1pt</property>
<property name="height">1.9895833333333333in</property>
<property name="width">99.9%</property>
<property name="dataSet">RefundsRepayments</property>
<list-property name="boundDataColumns">
<structure>
<expression name="expression">dataSetRow["GroupID"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["GroupLabel"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["CaseType"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["CaseNumber"]</expression>
</structure>
<structure>
<expression name="expression">wrap(dataSetRow["Applicant"],25);</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["ApprovalDate"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["ApprovedBy"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["Amount"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["Reason"]</expression>
</structure>
</list-property>
<column id="107">
<property name="width">0.8229166666666666in</property>
</column>
<column id="108">
<property name="width">0.96875in</property>
</column>
<column id="109">
<property name="width">1.698in</property>
</column>
<column id="110">
<property name="width">0.9375in</property>
</column>
<column id="111">
<property name="width">1.0833333333333333in</property>
</column>
<column id="112">
<property name="width">1.1979166666666667in</property>
</column>
<column id="113">
<property name="width">1.1145833333333333in</property>
</column>
<header>
<row id="74">
<property name="backgroundColor">#7CC9FF</property>
<property name="fontSize">9pt</property>
<property name="fontWeight">bold</property>
<property name="borderBottomColor">#000000</property>
<property name="borderBottomWidth">1px</property>
<property name="borderLeftColor">#000000</property>
<property name="borderLeftWidth">1px</property>
<property name="borderRightColor">#000000</property>
<property name="borderRightWidth">1px</property>
<property name="borderTopColor">#000000</property>
<property name="textAlign">center</property>
<cell id="75">
<property name="borderTopWidth">1px</property>
<label id="428">
<text-property name="text">Case Type</text-property>
</label>
</cell>
<cell id="76">
<label id="430">
<text-property name="text">Case Number</text-property>
</label>
</cell>
<cell id="77">
<label id="432">
<text-property name="text">Applicant</text-property>
</label>
</cell>
<cell id="78">
<property name="colSpan">1</property>
<property name="rowSpan">1</property>
<label id="434">
<text-property name="text">Approval Date</text-property>
</label>
</cell>
<cell id="427">
<label id="436">
<text-property name="text">Approved By</text-property>
</label>
</cell>
<cell id="80">
<label id="438">
<text-property name="text">Amount</text-property>
</label>
</cell>
<cell id="81">
<label id="440">
<text-property name="text">Reason</text-property>
</label>
</cell>
</row>
</header>
<group id="403">
<property name="groupName">ReportGroup</property>
<property name="interval">none</property>
<property name="sortDirection">asc</property>
<expression name="keyExpr">row["GroupID"]</expression>
<property name="repeatHeader">true</property>
<property name="hideDetail">false</property>
<property name="pageBreakAfter">auto</property>
<property name="pageBreakBefore">auto</property>
<property name="pageBreakInside">auto</property>
<header>
<row id="404">
<cell id="405">
<property name="colSpan">7</property>
<data id="426">
<property name="resultSetColumn">GroupLabel</property>
</data>
</cell>
</row>
</header>
</group>
<detail>
<row id="85">
<property name="fontFamily">"Arial"</property>
<property name="fontStyle">normal</property>
<cell id="86">
<property name="whiteSpace">normal</property>
<data id="429">
<property name="resultSetColumn">CaseType</property>
</data>
</cell>
<cell id="87">
<property name="paddingTop">2pt</property>
<property name="paddingLeft">2pt</property>
<property name="paddingBottom">2pt</property>
<property name="paddingRight">2pt</property>
<data id="431">
<property name="resultSetColumn">CaseNumber</property>
</data>
</cell>
<cell id="88">
<property name="textAlign">left</property>
<data id="443">
<property name="resultSetColumn">Applicant</property>
</data>
</cell>
<cell id="89">
<data id="435">
<structure name="dateTimeFormat">
</structure>
<property name="resultSetColumn">ApprovalDate</property>
</data>
</cell>
<cell id="90">
<data id="437">
<property name="resultSetColumn">ApprovedBy</property>
</data>
</cell>
<cell id="91">
<property name="textAlign">right</property>
<data id="439">
<structure name="numberFormat">
<property name="category">Currency</property>
<property name="pattern">#,##0.00</property>
</structure>
<property name="resultSetColumn">Amount</property>
</data>
</cell>
<cell id="92">
<data id="441">
<property name="resultSetColumn">Reason</property>
</data>
</cell>
</row>
</detail>
</table>
</body>
</report>
FUDForum. Page generated in 0.03973 seconds
