Home » Eclipse Projects » Eclipse Platform » Moving a class to another package with Refactor feature?
Moving a class to another package with Refactor feature? [message #124767] Tue, 09 September 2003 01:05 Go to next message
Originally posted by: hans.schwaebli.schwaebli.de
If I move a class to another package with drag and drop then I might get
errors because the imports are not correct anymore for example.
Can I use the Refactoring feature to let Eclipse do those modifications
automatically? If yes, how?
I tried it, but didn't find a way.
Re: Moving a class to another package with Refactor feature? [message #124829 is a reply to message #124767] Tue, 09 September 2003 03:46 Go to previous messageGo to next message
Hans Schw
Re: Moving a class to another package with Refactor feature? [message #124949 is a reply to message #124829] Tue, 09 September 2003 06:13 Go to previous messageGo to next message
This is not possible. I use Eclipse 2.1.1.
If I right click there is no menu item called Refactor. Only Move is there.
But this is no Refactor move but an ordinary move.
So my problem remains.
"Ilja Preu
Re: Moving a class to another package with Refactor feature? [message #124998 is a reply to message #124949] Tue, 09 September 2003 06:52 Go to previous messageGo to next message
Originally posted by: m.bauer.signsoft.com
I'm using eclipse 2.1.1 too, and there is such a menu entry. Rightclick on
the class, you want to move. Then a context menu opens. There you click on
"Refactor..." and in the new opend menu then on "Move...". This should do
what you want to do.
Michael
"Hans Schw
Re: Moving a class to another package with Refactor feature? [message #125663 is a reply to message #124949] Tue, 09 September 2003 11:59 Go to previous messageGo to next message
The Refactor menu is only available from within the Java-oriented
perspectives/views, such as Java Browsing perspective. I hope you're not
using the simple resource Navigator to do Java coding - that's just silly...
HTH,
Eric
Eric Rizzo
Software Architect
Jibe, Inc.
http://www.jibeinc.com
Re: Moving a class to another package with Refactor feature? [message #125959 is a reply to message #125663] Tue, 09 September 2003 14:06 Go to previous message
That seems to solve it. I will try it tomorrow.
I use Navigator view because I like the hierachical display. The package
explorer can be set to hierarchy but somehow it doesn't work as I expect it
when I use filters. So I use Navigator view.
"Eric Rizzo" <eric.rizzo@jibeinc.com> wrote in message
news:bjkt6a$8j0$2@eclipse.org...
Hans Schw
Previous Topic:console redirection
Next Topic:adding Revert capabilities
Current Time: Sun Sep 14 02:42:28 EDT 2025
Powered by FUDForum. Page generated in 0.10091 seconds
