Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP J Unit Test - Command line execution
TPTP J Unit Test - Command line execution [message #124226] Mon, 25 February 2008 13:08 Go to next message
Hi All,
I found out from the TPTP Manual that we can execute the TPTP tests from
the command prompt using the cmd shell available using TPTP automation
client.
There is an example for running it using ant script. But nor for running
it using the cmd shell available using the TPTP automation client.
Please let me know the steps involved running the same from the command
line.
Saran
Re: TPTP J Unit Test - Command line execution [message #124350 is a reply to message #124226] Tue, 26 February 2008 06:16 Go to previous messageGo to next message
See the instructions:
http://help.eclipse.org/help33/topic/org.eclipse.hyades.test .doc.user/tasks/texecuting-the-test-execution-service.htm
>> Running tests from the command line and shell scripts
You can also use the automation client adaptor scripts:
plugins\org.eclipse.hyades.execution\automation-client-adapt er.bat/cmd/sh
PS
"Saran" <saravanan.subramanian@cmegroup.com> wrote in message
news:a50307fb376b2d07ed6363300e534d63$1@www.eclipse.org...
> Hi All,
> client.
> line.
> Thanks
> Saran
Re: TPTP J Unit Test - Command line execution [message #127272 is a reply to message #124350] Tue, 25 March 2008 04:59 Go to previous messageGo to next message
The above link to the eclipse help doesn't help much in this regard. It
just has a small paragraph briefly explaining the overview. I found out
the parameters and syntax by running the automation-client-adapter.bat
without any args. It will then show the TPTP Automation Client Adapter
Help on command line, which explains the usage definition and valid named
parameters that may be used.
A simple and typical usage example:
automation-client-adapter -workspace c:\myworkspace -project myproj
-suite myt
est
Re: TPTP J Unit Test - Command line execution [message #128888 is a reply to message #127272] Wed, 23 April 2008 06:17 Go to previous messageGo to next message
Hi Bobby,
The overview page has links at the bottom to documents covering
everything you need to use ASF for test execution/reporting:
Using ASF:
http://help.eclipse.org/help33/advanced/content.jsp?topic=/o rg.eclipse.hyades.test.doc.user/tasks/texecuting-the-test-ex ecution-service.htm
Supported test execution properties:
http://help.eclipse.org/help33/advanced/tocView.jsp?view=toc &topic=/org.eclipse.hyades.test.doc.user/tasks/texecutin g-the-test-execution-service.htm
Paul
"Bobby" <bobbyjoseph@in.ibm.com> wrote in message
news:c0c1c2ee77cc3e8f6cd0641ab6798d5c$1@www.eclipse.org...
> myproj -suite myt
> est
Re: TPTP J Unit Test - Command line execution [message #128953 is a reply to message #128888] Wed, 23 April 2008 06:38 Go to previous message
The below links may not work in some browsers:
Using ASF:
http://help.eclipse.org/help33/index.jsp >> Testing applications >> Testing
applications >> Launching tests from scripts and applications >> Using the
TPTP automatable services
applications >> Launching tests from scripts and applications >> Supported
test execution service properties
"Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
news:fun2co$gv7$1@build.eclipse.org...
> Hi Bobby,
> Using ASF:
> Paul
>> myproj -suite myt
>> est
Previous Topic:Commandline Property
Next Topic:AGR future (tptp 4.5)- is it dead?
Current Time: Tue Sep 23 19:26:32 EDT 2025
Powered by FUDForum. Page generated in 0.31103 seconds
