Home » Newcomers » Newcomers » Can't open Eclipse Juno
Can't open Eclipse Juno [message #919183] Fri, 21 September 2012 15:16 Go to next message
I can't get Eclipse Juno to open.
Here is my eclipse.ini file
-startup
plugins/org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.200.v20120522-1813
-product
org.eclipse.epp.package.jee.product
--launcher.defaultAction
openFile
--launcher.XXMaxPermSize
256M
-showsplash
org.eclipse.platform
256m
openFile
-vm
C:\Java\jre6\bin\javaw.exe
-vmargs
-Dosgi.requiredJavaVersion=1.5
-Dhelp.lucene.tokenizer=standard
-Xms40m
-Xmx512m
When trying to open Eclipse it says:
An error has occurred see log..
The log says:
!SESSION 2012-09-21 15:10:42.111 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_34
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product
!ENTRY org.eclipse.osgi 4 0 2012-09-21 15:10:42.611
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:74)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
I appreciate your help!
~Crystal
Re: Can't open Eclipse Juno [message #919923 is a reply to message #919183] Sat, 22 September 2012 10:04 Go to previous messageGo to next message
Hey Crystal,
Would you try to run Eclipse with -debug flag? Just open a command line window, go to Eclipse installation directory and enter: eclipse -debug
Re: Can't open Eclipse Juno [message #920078 is a reply to message #919183] Sat, 22 September 2012 14:04 Go to previous messageGo to next message
How did you unpack the Juno Java EE download? What did you use to unzip it? Did you extract it into a clean directory? Is that also a 64-bit JRE you have installed?
Re: Can't open Eclipse Juno [message #921841 is a reply to message #919923] Mon, 24 September 2012 09:31 Go to previous messageGo to next message
I ran eclipse -debug
The popup said:
An error occurred. See the log file.
The log file says:
!SESSION 2012-09-24 09:30:29.632 -----------------------------------------------
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product -debug
!ENTRY org.eclipse.osgi 4 0 2012-09-24 09:30:30.078
!STACK 1
Re: Can't open Eclipse Juno [message #921847 is a reply to message #920078] Mon, 24 September 2012 09:37 Go to previous messageGo to next message
I had right clicked the eclipse Juno zip file and used the windows 7 extract all option. I extracted it to a clean directory.
Yes, I am using a 64 bit JRE.
The eclipse I am using is 64 bit as well.
~Crystal
Re: Can't open Eclipse Juno [message #922032 is a reply to message #921847] Mon, 24 September 2012 13:12 Go to previous messageGo to next message
I did a search on Google with the text:
"Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started"
Apparently there is an issue with config.ini file, maybe the first result of the search (the one that points to StackOverflow) could help you.
Re: Can't open Eclipse Juno [message #922147 is a reply to message #922032] Mon, 24 September 2012 15:44 Go to previous message
Thanks for your suggestion. I had also seen that on StackOverflow before I posted here. I had tried it by pasting
Dosgi.bundles=org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@
to the bottom of the eclipse.ini file and I receive this error:
Could not find the main class:
Program will exit.
When I close that I get a popup that says
Java was started but returned exit code=1
C:\Java\jre\bin\javaw.exe
and more text but I can't copy and paste it.
So I pointed it to a different JDK I have on my computer and it went back to the original error message:
[Updated on: Mon, 24 September 2012 15:57] by Moderator
Previous Topic:SDK manager
Next Topic:again (No suitable driver found for jdbc:sqlserver) error !
Current Time: Mon Oct 13 20:36:33 EDT 2025
Powered by FUDForum. Page generated in 0.10069 seconds
