Home » Eclipse Projects » Eclipse Platform » How do I Open Javadoc API?
How do I Open Javadoc API? [message #123779] Sun, 07 September 2003 11:52 Go to next message
Originally posted by: ThisisFake.Fakeness.xyz
I am very new to eclipse and I have read lots of the documentation, and
seem to be well on my way. But I can NOT seem to get the API javadocs to
open to the requested javadoc file by right clicking on a method or
variable.
I need to be able to look at relevant javadoc information in its entirety.
But it seems all I am offered is javadoc info related to just the item
selected.
Basically, how do I open the javadoc for a whole class?
Hate to ask, and I am sure its simple as every other IDE I have used does
this by right-click. But Eclipse does not seem to.
Thanks for you help!
CL
Re: How do I Open Javadoc API? [message #123793 is a reply to message #123779] Sun, 07 September 2003 12:14 Go to previous messageGo to next message
Originally posted by: jmordax.terra.es
If you are looking for JDK JavaDoc then fo to:
Window -> Preferences -> Java -> Installed JREs (select yours) -> Edit
and add:
http://java.sun.com/j2se/1.4.2/docs/api (for 1.4.2 API; if you
prefer other choose the correct URL)
to JavaDoc URL entry field.
Then, select the class, method or whatever you want and:
- Shift + F"
- Or Navigate -> Open External Javadoc.
Hope this helps,
Chemi.
>variable.
>selected.
>CL
Re: How do I Open Javadoc API? [message #123832 is a reply to message #123793] Sun, 07 September 2003 17:23 Go to previous messageGo to next message
> and add:
> - Shift + F"
> Hope this helps,
> Chemi.
Actually I am looking for stuff that is part of PDE or other Eclipse APIs.
Actually I'd like to be able to right click any variable and have the
javadoc OPEN so I can read it. I know its in the envrionment because I
get a javadoc tooltip. But where is the whole doc??
CL
Re: How do I Open Javadoc API? [message #124044 is a reply to message #123832] Mon, 08 September 2003 03:37 Go to previous message
--------------060009090302060000090009
Content-Type: text/plain; charset=us-ascii; format=flowed
Try selecting what you are interested in and press F2.
To get the whole doc you should follow similar steps as for JDK. You
should select each JAR library from your project, right button ,
properties and set its JavaDoc location. Try this location:
http://dev.eclipse.org/help21/index.jsp?topic=/org.eclipse.p latform.doc.isv/reference/api/
(Note: I haven't tested this myself).
Hope this helps,
Chemi.
>>and add:
>> - Shift + F"
>>Hope this helps,
>> Chemi.
>CL
Content-Type: text/html; charset=us-ascii
<html>
<head>
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<title></title>
</head>
<body text="#000000" bgcolor="#ffffff">
Try selecting what you are interested in and press F2.<br>
<br>
<a class="moz-txt-link-freetext" href=" http://dev.eclipse.org/help21/index.jsp?topic=/org.eclipse.p latform.doc.isv/reference/api/"> http://dev.eclipse.org/help21/index.jsp?topic=/org.eclipse.p latform.doc.isv/reference/api/</a>
(Note: I haven't tested this myself).<br>
<br>
Hope this helps,<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp; Chemi.<br>
<br>
CL [dnoyeB] Gilbert wrote:<br>
<blockquote type="cite"
cite="midpan.2003.09.07.21.23.05.420907@Fakeness.xyz">
<pre wrap="">On Sun, 07 Sep 2003 18:14:57 +0200, Chemi wrote:
</pre>
<blockquote type="cite">
<pre wrap="">If you are looking for JDK JavaDoc then fo to:
Window -&gt; Preferences -&gt; Java -&gt; Installed JREs (select yours) -&gt; Edit
and add:
<a class="moz-txt-link-freetext" href="http://java.sun.com/j2se/1.4.2/docs/api">http://java.sun.com/j2se/1.4.2/docs/api</a> (for 1.4.2 API; if you
- Shift + F"
- Or Navigate -&gt; Open External Javadoc.
Hope this helps,
Chemi.
</pre>
</blockquote>
<pre wrap=""><!---->
CL
</pre>
</blockquote>
<br>
</body>
</html>
--------------060009090302060000090009--
Previous Topic:Classpath in Run-time workbench
Next Topic:Opening the same file to two editor wiews
Current Time: Thu Nov 06 05:23:40 EST 2025
Powered by FUDForum. Page generated in 0.04672 seconds
