Re: Birt designer throws 'Connection is closed' error while previewing the report [message #919100 is a reply to message #919091] |
Fri, 21 September 2012 17:24 |
coolguy Missing name Messages: 6 Registered: July 2009 |
I've tried different queries and it gives the same error.
I tried this on newer revisions (eclipse-reporting-juno-win32, birt-report-designer-all-in-one-3_7_2) and it gives errors. The eclipse-reporting-juno-win32 gives the Connection is closed error.(stack trace given below)
Quote:org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
at org.eclipse.birt.report.engine.api.impl.DatasetPreviewTask.doRun(DatasetPreviewTask.java:135)
at org.eclipse.birt.report.engine.api.impl.DatasetPreviewTask.runDataset(DatasetPreviewTask.java:97)
at org.eclipse.birt.report.engine.api.impl.DatasetPreviewTask.execute(DatasetPreviewTask.java:49)
at org.eclipse.birt.report.designer.data.ui.dataset.DataSetPreviewer.preview(DataSetPreviewer.java:69)
at org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPreviewPage$5.run(ResultSetPreviewPage.java:336)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
Caused by: org.eclipse.birt.report.data.adapter.api.AdapterException: An exception occurred during processing. Please see the following message for details:
Failed to prepare the query execution for the data set: MyDataset
Failed to prepare the following query for the data set type (org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet).
... query...omitted..
org.eclipse.birt.report.data.oda.jdbc.JDBCException: Error preparing SQL statement.
SQL error #1:The connection is closed.
com.microsoft.sqlserver.jdbc.SQLServerException: The connection is closed.
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.execute(DataRequestSessionImpl.java:644)
at org.eclipse.birt.report.engine.api.impl.DatasetPreviewTask.extractQuery(DatasetPreviewTask.java:166)
at org.eclipse.birt.report.engine.api.impl.DatasetPreviewTask.doRun(DatasetPreviewTask.java:126)
... 5 more
Caused by: org.eclipse.birt.data.engine.core.DataException: Failed to prepare the query execution for the data set: MyDataset
at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecution(QueryExecutor.java:345)
at org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(PreparedQuery.java:455)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.produceQueryResults(PreparedDataSourceQuery.java:190)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.execute(PreparedDataSourceQuery.java:178)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute(PreparedOdaDSQuery.java:145)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.execute(DataRequestSessionImpl.java:624)
... 7 more
Caused by: org.eclipse.birt.data.engine.odaconsumer.OdaDataException: Failed to prepare the following query for the data set type (org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet).
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.newException(ExceptionHandler.java:54)
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.throwException(ExceptionHandler.java:108)
at org.eclipse.birt.data.engine.odaconsumer.Connection.prepareOdaQuery(Connection.java:298)
at org.eclipse.birt.data.engine.odaconsumer.Connection.prepareStatement(Connection.java:197)
at org.eclipse.birt.data.engine.executor.DataSource.prepareStatement(DataSource.java:302)
at org.eclipse.birt.data.engine.executor.DataSourceQuery.prepare(DataSourceQuery.java:281)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQueryExecutor.prepareOdiQuery(PreparedOdaDSQuery.java:442)
at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecution(QueryExecutor.java:341)
... 12 more
Caused by: org.eclipse.birt.report.data.oda.jdbc.JDBCException: Error preparing SQL statement.
at org.eclipse.birt.report.data.oda.jdbc.Statement.prepare(Statement.java:135)
at org.eclipse.birt.report.data.oda.jdbc.bidi.BidiStatement.prepare(BidiStatement.java:52)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.doPrepare(OdaQuery.java:229)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.prepare(OdaQuery.java:186)
at org.eclipse.birt.data.engine.odaconsumer.Connection.prepareOdaQuery(Connection.java:290)
... 17 more
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: The connection is closed.
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDriverError(SQLServerException.java:190)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.checkClosed(SQLServerConnection.java:388)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.prepareStatement(SQLServerConnection.java:2166)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.prepareStatement(SQLServerConnection.java:1853)
at org.eclipse.birt.report.data.oda.jdbc.Statement.prepare(Statement.java:131)
... 21 more
[Updated on: Fri, 21 September 2012 17:25] Report message to a moderator
FUDForum. Page generated in 0.03272 seconds
