Home » Eclipse Projects » GEF » About the PaletteViewer
About the PaletteViewer [message #123758] |
Tue, 23 March 2004 12:03 |
Originally posted by: charleszq.eastday.com
As for the PaletteViewer in GEF, it has 4 default layout, such as COLUMNS,
LIST, DETAILS, etc. My question is, for the COLUMNS layout, can I set the
column number to 1?
Thanks.
Charles
Re: About the PaletteViewer [message #123835 is a reply to message #123758] |
Tue, 23 March 2004 16:05 |
Pratik Shah Messages: 1077 Registered: July 2009 |
So, as you widen the palette, the children will get wider, but they won't
ever share the same row?
I believe something like this (allowing the end-user to customize the number
of columns in the palette settings dialog) is planned, although it probably
won't be available until after the 3.0 release. You can open a feature
request at http://bugs.eclipse.org.
Meanwhile, if you must have it, you can change ColumnsLayout so that its
default width (defaultConstraint.width) is the same as the palette width.
"Charles" <charleszq@eastday.com> wrote in message
news:c3p8r8$edu$1@eclipse.org...
> column number to 1?
> Thanks.
> Charles
Re: About the PaletteViewer [message #123961 is a reply to message #123835] |
Wed, 24 March 2004 00:56 |
Yes, that's exactly what I want. Thanks.
Charles
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:c3pmut$19d$1@eclipse.org...
number
probably
> > Hi,
COLUMNS,
the
> > column number to 1?
> > Thanks.
> > Charles
Current Time: Fri Apr 26 16:14:23 GMT 2024
Powered by FUDForum. Page generated in 0.03081 seconds
