Home » Eclipse Projects » Virgo » How are bundle jars copied to stage dir?
How are bundle jars copied to stage dir? [message #918617] Fri, 21 September 2012 03:11 Go to next message
Hello all.
I have a couple of bundle jars which, when deployed to Virgo's stage dir automatically, drop all their contents except the META-INF directory.
What could be the cause of that? What is the mechanism that does that copying over and creating the special dir structure in stage?
I have to add that I am still running Virgo 3.0.0.RELEASE, unfortunately.
TIA,
B.
[Updated on: Fri, 21 September 2012 03:12] by Moderator
Re: How are bundle jars copied to stage dir? [message #926100 is a reply to message #918617] Fri, 28 September 2012 05:53 Go to previous messageGo to next message
The tooling uploads each bundle to the stage directory and then invoke the Virgo deployer via JMX passing a reference to the bundle in the stage directory. So the tooling or its upload mechanism are implicated rather than the Virgo runtime. What version of the tooling are you using?
Re: How are bundle jars copied to stage dir? [message #937732 is a reply to message #926100] Tue, 09 October 2012 04:07 Go to previous messageGo to next message
Hi Glyn, apologies for the late reply.
The version of the Virgo IDE I am using is 1.0.0.201207122033-MILESTONE.
I should probably add that this happens on bundles whose MANIFEST.MF has been created by the Maven Bundle plugin (as opposed to Bundlor), in case this makes a difference.
B.
Re: How are bundle jars copied to stage dir? [message #937761 is a reply to message #937732] Tue, 09 October 2012 04:34 Go to previous messageGo to next message
Well it would be worth upgrading to the released version of the tooling before you go any further as Miles Parker fixed quite a few bugs. Please could you do that and report back?
Re: How are bundle jars copied to stage dir? [message #937847 is a reply to message #937761] Tue, 09 October 2012 06:17 Go to previous messageGo to next message
Done (updated to latest release tooling) and still same issue.
Re: How are bundle jars copied to stage dir? [message #937968 is a reply to message #937847] Tue, 09 October 2012 08:22 Go to previous messageGo to next message
This is what the generated MANIFEST.MF looks like, maybe you can spot the problem. Funny thing is, I am having this issue for all bundles that wrap non-OSGi jar dependencies.
Manifest-Version: 1
Bnd-LastModified: 1349686464562
Build-Jdk: 1.6.0_24
Built-By: rosib
Bundle-Description: This OSGi bundle simply wraps wt-springrest-intf-2.4
 .1.jar artifact.
Bundle-DocURL: http://www.iggroup.com
Bundle-ManifestVersion: 2
Bundle-Name: com.iggroup.wb.core.wt.springrest.intf
Bundle-SymbolicName: com.iggroup.wb.core.wt.springrest.intf
Bundle-Vendor: IG Index
Bundle-Version: 1.10.0.SNAPSHOT
Created-By: Apache Maven Bundle Plugin
Export-Package: uk.co.igindex.springrest.client;uses:="org.apache.common
 s.logging,org.apache.http.params,org.apache.commons.io,org.apache.http.
 client,org.apache.http.client.methods,org.apache.http,uk.co.igindex.spr
 ingrest.domain,org.apache.http.conn.scheme,javax.net.ssl,org.apache.htt
 p.message,uk.co.igindex.springrest.mapping,org.apache.http.conn.params,
 org.apache.http.entity,org.springframework.util,org.apache.http.conn.ss
 l,org.apache.http.client.utils,org.apache.http.conn,org.apache.http.imp
 l.client,org.apache.http.impl.conn.tsccm";version="1.10.0.SNAPSHOT",uk.
 co.igindex.springrest.domain;uses:="uk.co.igindex.springrest.mapping,or
 g.apache.commons.lang.builder,org.apache.commons.lang";version="1.10.0.
 SNAPSHOT",uk.co.igindex.springrest.mapping;uses:="uk.co.igindex.springr
 est.domain";version="1.10.0.SNAPSHOT"
Ignore-Package: uk.co.igindex.commons.log.rule
Import-Package: javax.net.ssl,org.apache.commons.io;version="[1.4,2)",or
 g.apache.commons.lang;version="[2.4,3)",org.apache.commons.lang.builder
 ;version="[2.4,3)",org.apache.commons.logging;version="[1.1,2)",org.apa
 che.http;version="[4.1,5)",org.apache.http.client;version="[4.1,5)",org
 .apache.http.client.methods;version="[4.1,5)",org.apache.http.client.ut
 ils;version="[4.1,5)",org.apache.http.conn;version="[4.1,5)",org.apache
 .http.conn.params;version="[4.1,5)",org.apache.http.conn.scheme;version
 ="[4.1,5)",org.apache.http.conn.ssl;version="[4.1,5)",org.apache.http.e
 ntity;version="[4.1,5)",org.apache.http.impl.client;version="[4.1,5)",o
 rg.apache.http.impl.conn.tsccm;version="[4.1,5)",org.apache.http.messag
 e;version="[4.1,5)",org.apache.http.params;version="[4.1,5)",org.spring
 framework.util;version="[3.0,4)"
Tool: Bnd-1.43.0
B.
Re: How are bundle jars copied to stage dir? [message #1236918 is a reply to message #937968] Tue, 28 January 2014 06:43 Go to previous messageGo to next message
Hi Barbara,
I'm having the same issue now. Do you remember how did you fix it if you did?
I hope your memory is better than mine Smile
Matteo
Re: How are bundle jars copied to stage dir? [message #1258497 is a reply to message #1236918] Thu, 27 February 2014 07:52 Go to previous message
I had similar issues, the maven-jar-plugin helped me. (I use the virgo bundler plugin too)
	<plugin>
<groupId>org.apache.maven.plugins</groupId>
<artifactId>maven-jar-plugin</artifactId>
<configuration>
<archive>
<manifestFile>target/classes/META-INF/MANIFEST.MF</manifestFile>
</archive>
</configuration>
</plugin>
Previous Topic:virgo:UnableToSatisfyBundleDependenciesExcept
Next Topic:javax.mail issues with multipart messages
Current Time: Wed Nov 05 16:45:43 EST 2025
Powered by FUDForum. Page generated in 0.04060 seconds
