Re: Issue is ChoiceSelectionCommand [message #123817 is a reply to message #123702] |
Sun, 24 February 2008 13:06 |
Jimmy Jin Messages: 32 Registered: July 2009 |
Member |
Hello, Pushparaj,
The key is to get the cell editor activated before the modify or choice
select command is executed.
The enhancement includes adding some attributes to the <command>
element, to include the identify of the parent of the current ComboBox
or Text, if it is a Table.
* When recording, for the modify and choice selection command, if the
according control's parent is a Table, then include parent Table's
identify into the attributes. Also include the column and row, which
this control is in, into the <command> element.
* When playback, if there is these parent control info in the modify and
choice select command and it's a Table, then try to send an mouse click
event to the Table with calculated mouse position, so that the editor in
the according cell can be activated.
I think this can also be workaround by adding a verification command
before your modify or choice select command. In the verification
command, you can find out the Table, and send it a proper mouse down
event to activate the cell editor.
Jimmy Jin
Pushparaj wrote:
> Hi Jimmy Jin,
> Can you please explain what enhancement/attribute i should do to make it
> working? Becuase in my application we are using celleditor in most of
> our viewers. So without this fix ican't continue my work.
> Is there any workaround for this issue?
> Please help me to resolve this issue.
Re: Issue is ChoiceSelectionCommand [message #124720 is a reply to message #124265] |
Thu, 28 February 2008 14:08 |
Member |
Hello, Pushparaj,
I will suggest you debug the verification method to see what the problem
it is. The enhancement needs some modification to the generated XML
script, so it may take me some time to submit it (also including the
modification to the document, which I've never done before). Also even
it's available in some version of AGR, I'm not sure if you can use the
compatible Eclipse version (for example 3.4).
You can post your verification method here, and I can also help you to
have a look.
Jimmy Jin
Pushparaj wrote:
> Hi Jimmy Jin,
> Can i get this enhancement if i take the latest build ?.
> Because i tried the workaround what you mentioned in your reply. I am
> not facing any problem while recording the test case. But while running
> it is going up to the verification method then it waits for sometime
> after that i am getting some irrelevent error message(in line number 3).
> So if you have the plan to add your enhancement in near future i can
> wait for this enhancement.
> Pushparaj
FUDForum. Page generated in 0.03681 seconds
