Home » Language IDEs » C / C++ IDE (CDT) » Cross-platform developing with GCC toolchain
Cross-platform developing with GCC toolchain [message #123476] Thu, 14 October 2004 09:26 Go to next message
Originally posted by: y.ivanov.request-bg.com
I'm using Eclipse 3.0 + CDT + mspgcc toolchain (gcc port for TI msp430)
on Win2K. As a debugging tool I use insight from the same toolchain.
I've tried to use the debug capabilities of CDT but for some reason
unsuccessful (the toolchain contains gdb.exe also). To be a bit more
specific I can't create debug configuration in Eclipse.
Is anybody have an idea how to use debugger from toolchain with
different target from that on wich I'm building?
Thanx in advance
Re: Cross-platform developing with GCC toolchain [message #123697 is a reply to message #123476] Thu, 14 October 2004 20:40 Go to previous messageGo to next message
Originally posted by: cliechti.gmx.ch
Yuliyan Ivanov wrote:
> Hello,
i have a plugin for mspgcc on my homepage:
http://homepage.hispeed.ch/py430/mspgcc/
HTH
chris
Re: Cross-platform developing with GCC toolchain [message #123769 is a reply to message #123697] Fri, 15 October 2004 06:00 Go to previous message
>> Hello,
>> msp430) on Win2K. As a debugging tool I use insight from the same
>> toolchain. I've tried to use the debug capabilities of CDT but for
>> some reason unsuccessful (the toolchain contains gdb.exe also). To be
>> a bit more specific I can't create debug configuration in Eclipse.
> HTH
> chris
Thanks a lot Chris! Works just perfectly!
Previous Topic:Breakpoints in ARM assembler
Next Topic:Re: Problem with CDT
Current Time: Fri Nov 07 01:46:55 EST 2025
Powered by FUDForum. Page generated in 0.03128 seconds
