Home » Modeling » EMF » Ecore Metamodel EAttribute bugs(bugs linked to the multiplicity of EAttribute)
Re: Ecore Metamodel EAttribute bugs [message #918143 is a reply to message #917957] |
Thu, 20 September 2012 19:39 |
Ed Merks Messages: 33142 Registered: July 2009 |
Dario,
Comments below.
On 20/09/2012 5:43 PM, Dario Imparato wrote:
> Hello,
> I am sorry if what I am going to ask has already been asked in
> another post but I have not found it.
> I have 2 problems.
> 1)Suppose you create an Ecore metamodel with an "Eclass" in it and an
> "EAttribute " called "Value" of type "EInt". Suppose Value has NO
> "Default Value Literal" and has "Lower Bound" =0 and "Upper Bound" =1;
> if you create a model using this metamodel, Value appears with default
> value "0"
Of course a primitive must have a value...
> and if you open it with text editor, "Value" field is not present.
You mean in the serialization?
> Same problem with "EFloat" type.
Yes, all the primitives have an intrinsic default of zero.
> So the first problem is that "0" is not considered as an integer.
By what?
> 2)Suppose Value is an "EString" and has "Lower Bound" =1 and "Upper
> Bound" =1, so it is a required attribute; if you don't specify it in
> the model, an empty string ("") will be assigned and if you try to
> validate the model you will have no problem.
Assigned by whome?
> So the second problem is that I cannot control if a required attribute
> of type "Estring" has been specified.
I don't follow what you're saying.
> Are these bugs?
I doubt there are bugs in these basic things after 10 years of wide
spread use.
> What do you think about it?
I think I don't understand what you're saying. Yes, primitives must
have a value. Default values are not serialized, i.e., if eIsSet if
false, nothing will appear in the XMI/XML. In general, binding
String-valued features to text fields suffers from the problem that you
can't distinguish null from the empty string. The properties view lets
you reset a value to the default (little button in the view bar areas),
so if a String-valued feature has no default, you can use that to set it
back to null.
> Thanks in advance.
Ed Merks
Re: Ecore Metamodel EAttribute bugs [message #918693 is a reply to message #918143] |
Fri, 21 September 2012 08:59 |
Dario Imparato Messages: 20 Registered: August 2012 |
Ed,
comments below.
Quote:You mean in the serialization?
Yes, but I don't understand when you say that a primitive must have a value...
Question: if I had an optional attribute of type "EInt", how could I assign "0" value to it? I tried it and in the serialized file (.xmi) I have not the specific xml attribute.
Assigned by whome?
By the editor plug-in that is created by the genmodel.
Quote:> So the second problem is that I cannot control if a required attribute
I can not distinguish an empty string from a null, but as you said it must be used "Restore default value" to avoid the problem (imho it's a weak workaround)
Now I have another issue, if I had a meta-model class "ClassChild" that inherited from a parent "ClassFather" and the latter has a required attribute (no matter what type), it is not inherited as "required" in "ClassChild" .
So if "ClassChild" is present without the required attribute, the validation of the model, performed by the editor, goes fine.
Suggestions?
Re: Ecore Metamodel EAttribute bugs [message #918751 is a reply to message #918693] |
Fri, 21 September 2012 09:58 |
Dario,
Comments below.
On 21/09/2012 10:59 AM, Dario Imparato wrote:
> Ed,
> comments below.
> Quote:
> value...
Consider when you have a field declared in Java of type int and you
don't initialize it. What value will it have? For all primitives, it's
the zero value; for everything else it's null.
In the Ecore model you can set the default value literal for an
EAttribute to "0", but even if you don't, it will still have that
default value because primitive types have an intrinsic default; they
can't be null because they're not java.lang.Objects.
> xml attribute.
This is a third question. As I said, feature will be serialized only if
it's considered set. For non-unsettable features, that will be the case
only when the value is different from the default value. And, as I've
explained above, primitives always have a default value, either explicit
or intrinsic. This save option can force explicit (not intrinsic)
defaults to be serialized
* Keep default content ( e.g. default attributes). This applies to
saving and converting contents to DOM.
* By default the default content is discarded.
* To save the default content, set this option to
<code>Boolean.TRUE</code>.
String OPTION_KEEP_DEFAULT_CONTENT = "KEEP_DEFAULT_CONTENT";
So if you set the explicit default to "0" and use this option, you will
see values serialized for features that not not set up have an explicit
default in the Ecore model.
> Quote:
>> > an empty string ("") will be assigned and if you try to > validate
>> Assigned by whome?
You mean in the properties view?
> Quote:
>> attribute > of type "Estring" has been specified.
> weak workaround)
Yes, but consider that this problem is everywhere in every dialog you
see. For some reason no one (even the folks providing data binding
support) seems to care about it.
Yes it is.
No, I don't think so. But again, the nature of primitives has an
impact. Look in
org.eclipse.emf.ecore.util.EObjectValidator.validate_MultiplicityConforms(EObject,
EStructuralFeature, DiagnosticChain, Map<Object, Object>) and look at
else if (eStructuralFeature.isRequired())
if (eStructuralFeature.isUnsettable() ?
!eObject.eIsSet(eStructuralFeature) : eObject.eGet(eStructuralFeature,
false) == null)
result = false;
if (diagnostics != null)
diagnostics.add
(createDiagnostic
(Diagnostic.ERROR,
DIAGNOSTIC_SOURCE,
EOBJECT__EVERY_MULTIPCITY_CONFORMS,
"_UI_RequiredFeatureMustBeSet_diagnostic",
new Object [] { getFeatureLabel(eStructuralFeature,
context), getObjectLabel(eObject, context) },
new Object [] { eObject, eStructuralFeature },
context));
See that it only diagnoses a problem if there is no value, but for
primitives there's always a value.
> Suggestions?
Ed Merks
Re: Ecore Metamodel EAttribute bugs [message #918918 is a reply to message #918751] |
Fri, 21 September 2012 13:34 |
Ed,
comments below.
I understood that primitives must have a default value, but so why "EAttribute" can have "Lower Bound" to 0 for these types?
In a metamodel I can have a Class with an optional attribute of a primitive type (i.e. EInt) so when I create a model (istance of my metamodel) with a Class MYClass, I have to specify the optional attribute and for me it is a nonsense, doesn't it?
Quote:> Now I have another issue, if I had a meta-model class "ClassChild"
Yes it is.
Try this. Create an "EClass" A with an "EAttribute" name of type "EString", create an "EClass" B inherited from A. Create now the model from this meta-model with a class BClass of kind B WITHOUT specifying name. If name is required, you will not be able to validate it, right?
On the contrary, validation goes fine, while if you try to make the same with a class AClass of kind A you will not.
As suggested by Christoph, using EIntegerObject is a solution to create an effectively optional EAttribute for primitive types, while setting "Unsettable" an "EInt" doesn't solve the problem: the attribute still has "0" as default value.
Thanks a lot.
Re: Ecore Metamodel EAttribute bugs [message #918932 is a reply to message #918918] |
Fri, 21 September 2012 13:51 |
Dario,
Comments below.
On 21/09/2012 3:34 PM, Dario Imparato wrote:
> Ed,
> comments below.
You're suggesting the Ecore model's validator should diagnose an error
when the attribute's type is a primitive and the attribute is not also
unsettable?
Sorry, I can't make sense of the phrase "I have to specify an optional
attribute". You don't have to set a value for an optional attribute.
> Quote:
>> > that inherited from a parent "ClassFather" and the latter has a >
>> required attribute (no matter what type), it is not inherited as >
>> "required" in "ClassChild" . Yes it is.
When I do that, and don't set a value for B's name, it diagnoses that as
an error.
It also complains when an A instances doesn't have the name set.
How are you doing the validation?
> Thanks a lot.
Ed Merks
Re: Ecore Metamodel EAttribute bugs [message #919071 is a reply to message #918693] |
Fri, 21 September 2012 16:50 |
Maximilian Koegel Messages: 253 Registered: July 2009 |
considering one of the questions, I might have an answer ;):
> value...
The value does not appear in the serialization because it is the same as
the DEFAULT value. You can view this as an optimization to save some
bytes in the serialization. If you do not specify a default value the
defualt for the default value is 0.
Maximilian
> Quote:
>> Assigned by whome?
> Quote:
> weak workaround)
> "ClassChild" . So if "ClassChild" is present without the required
> Suggestions?
Maximilian Kögel
Get Professional Eclipse Support: http://eclipsesource.com/munich
Re: Ecore Metamodel EAttribute bugs [message #921801 is a reply to message #918932] |
Mon, 24 September 2012 12:45 |
Quote:You're suggesting the Ecore model's validator should diagnose an error
unsettable?
I say that, for primitive attributes, the Ecore model's validator can't distinguish between the case where the attribute has been assigned and the case where the attribute has been not assigned. For tools that take the model as input and require to understand if the value as been assigned or not, it is a problem...
Quote:> Try this. Create an "EClass" A with an "EAttribute" name of type
an error.
You are right. I deleted and recreated "name" attribute and now if I don't set a value for B's name, it diagnoses that as an error. I don't know why there was this problem before. Thanks Ed
Quote:The value does not appear in the serialization because it is the same as
Thanks Maximilian
Re: Ecore Metamodel EAttribute bugs [message #921859 is a reply to message #921801] |
Mon, 24 September 2012 13:49 |
Dario,
Comments below.
On 24/09/2012 2:45 PM, Dario Imparato wrote:
> Quote:
>> error when the attribute's type is a primitive and the attribute is
>> not also unsettable?
Even for non-primitives it can't distinguish between the default and an
assigned value equal to the default.
Either the tool needs to work for all models (the EMF runtime does), or
they can insist that features be unsettable because that's the only way
to know if the value you get back is there because it's been assigned
verses it's there because it's the default.
> Quote:
>> > Try this. Create an "EClass" A with an "EAttribute" name of type >
>> model > from this meta-model with a class BClass of kind B WITHOUT
>> specifying > name. If name is required, you will not be able to
>> validate it, right?
>> as an error.
> Quote:
> Thanks Maximilian
Ed Merks
Re: Ecore Metamodel EAttribute bugs [message #921877 is a reply to message #921801] |
Mon, 24 September 2012 14:02 |
Hi, Dario,
On 2012-09-24 12:45:06 +0000, Dario Imparato said:
> Quote:
>> unsettable?
But, it can. If you designate the attribute as "unsettable", then EMF
generates an additional state variable that records whether a value has
been explicitly set in the feature or not. This additional state is
what the eIsSet()/eUnset() API works with. So, the validator (and any
code) can tell the difference between a 0 in an EInt attribute that
happens to be there because Java requires it and one that was
explicitly set as the intended value.
Note that "unsettable" does not indicate that a feature cannot be set.
It indicates that a feature can be unset.
HTH,
Christian
Re: Ecore Metamodel EAttribute bugs [message #922752 is a reply to message #922663] |
Tue, 25 September 2012 09:44 |
I imagine we could have a button, like the reset button, that sets the
value. If all this boils down to wanting serialized defaults then you
can specify the default explicitly in the model for each feature and use
the save option I mentioned previous to save those explicit defaults.
On 25/09/2012 10:05 AM, Dario Imparato wrote:
> Quote:
>> has been explicitly set in the feature or not. This additional state
>> is what the eIsSet()/eUnset() API works with. So, the validator (and
>> any code) can tell the difference between a 0 in an EInt attribute
>> that happens to be there because Java requires it and one that was
> Thank you Christian, but I have a problem using "unsettable" flag.
> If I want to set the value "0" to an "Unsettable" attribute of "EInt",
> I first have to assign another value (i.e. "1"), then have to save the
> model before reassign "0" value and finally save the model. In this
> way in the serialized file of the model (.xmi) I can find "value=0"
> field. Otherwise if I assign "0" value from the beginning, no "value"
> field appears in the serialized file of model, in fact I can't save
> the model because no changes are detected.
> Any suggestions?
Ed Merks
Current Time: Sat Apr 27 01:39:06 GMT 2024
Powered by FUDForum. Page generated in 0.04144 seconds
