Home » Modeling » OCL » Extend EcoreEnvironment locally
Extend EcoreEnvironment locally [message #917816] Thu, 20 September 2012 09:04 Go to next message
there is an opportunity to extend the EcoreEnvironment by using for
example the "defineOperation" method. I did this for example to extend
the OCLEnvironment by the operation "getValue()" of a EFeatureMapEntry.
But when I tried to evaluate this operation I got a NullPointerException
caused by line 227 in the class EcoreEvaluationEnvironment.
I think this occurrs because of a mistake in line 206.
When an operation is added to the Environment a so called "ShadowClass"
with the added EOperation will be created. But in the shadow class no
information about the correct InstanceClass is stored.
To get this information I changed line 206 to:
EClassifier container = OCLStandardLibraryImpl.getOwner(operation);
Am I right, is this a mistake?
Lilija Klassen
Re: Extend EcoreEnvironment locally [message #918056 is a reply to message #917816] Thu, 20 September 2012 13:43 Go to previous messageGo to next message
You give no clue about which version you use.
For me line 206 is a blank line.
Ed Willink
On 20/09/2012 14:04, Lilija Klassen wrote:
> Hello,
> NullPointerException caused by line 227 in the class
> "ShadowClass" with the added EOperation will be created. But in the
> shadow class no information about the correct InstanceClass is stored.
> Best regards,
> Lilija Klassen
Re: Extend EcoreEnvironment locally [message #918635 is a reply to message #918056] Fri, 21 September 2012 03:32 Go to previous messageGo to next message
Hey,
Oh yes, sorry for that I use version 3.1.0, but its also the same line
in version 3.2.0.
class EcoreEvaluationEnvironment, method getJavaMethodFor,
line 206: EClass container = operation.getEContainingClass();
Lilija Klassen
Am 20.09.2012 19:43, schrieb Ed Willink:
> Hi
> Regards
> Ed Willink
>> Hello,
>> Best regards,
>> Lilija Klassen
Re: Extend EcoreEnvironment locally [message #918863 is a reply to message #917816] Fri, 21 September 2012 08:19 Go to previous message
ShadowClasses are a necessary evil when using an underlying meta-model
representation that does not allow DataTypes to have Operations. (The
Pivot model for new Eclipse OCL code does not have this restriction.)
The existing tests of defineOperation seem to ge only for Classes.
Your (remarkably obvious) example for an EDataType fails as you observe.
Your change seems to do no damage (apart from a small execution cost) so
I've raised https://bugs.eclipse.org/bugs/show_bug.cgi?id=390094 to
incorporate it.
Thanks.
Ed Willink
> Hello,
> Best regards,
> Lilija Klassen
Previous Topic:how to concatenate each element of first sequence with every other element of the second sequence
Next Topic:Changing OCLinEcore editor code formatting
Current Time: Sun Nov 09 18:36:11 EST 2025
Powered by FUDForum. Page generated in 0.03870 seconds
