Home » Eclipse Projects » Remote Application Platform (RAP) » conceptual question: "file download link"?
conceptual question: "file download link"? [message #123318] Fri, 27 February 2009 06:40 Go to next message
Folks;
maybe I'm a little off track here, but using RAP I am at the moment trying
to achieve something pretty common in "ordinary" web user interfaces: In
some place (like the cell of a TableViewer) I want to place a functionality
to do a straightforward file download. There's a file provider servlet in
another application somewhere out in our system, and usually I can refer to
(and actually download) arbitrary files via HTTP using this servlet... the
only problem I see so far: How to "emulate" this feature (an HTML hyperlink
that makes the browser access an arbitrary HTTP ressource outside the RAP
context) in a RAP user interface? Ideas, anyone?
TIA and all the best,
Kristian
Re: conceptual question: "file download link"? [message #123447 is a reply to message #123318] Mon, 02 March 2009 07:10 Go to previous messageGo to next message
Kristian,
as of now, there is no "download widget" or similar in RAP.
The browser widget with a mini HTML page that contains only a link
is probably the quickest workaround.
If you need more control over the details, writing a custom widget
shouldn't be too complicated either. In the latter case, feel free
to share your code if you think it might be of general interest.
HTH
Rüdiger
Kristian Rink wrote:
> Folks;
> Kristian
Re: conceptual question: "file download link"? [message #123496 is a reply to message #123447] Mon, 02 March 2009 10:06 Go to previous message
Hi Rüdiger;
and first off, thanks a bunch for your thoughts on that.
> The browser widget with a mini HTML page that contains only a link is
Well this is sort of what I intended to do... Eventually all that is
required in my use case so far would be a hyperlink (like used in the
RCP/IDE or in the RAP mail demo to display the e-mail address) referring to
an HTTP ressource outside the actual RAP application, maybe something like
Eclipse Forms' Hyperlink. Custom "download widget" would be a second option
to consider, I guess...
Cheers & thanks again,
Kristian
Previous Topic:Non-selectable nodes in tree
Next Topic:Getting session from any thread
Current Time: Sun Sep 07 20:54:13 EDT 2025
Powered by FUDForum. Page generated in 0.05093 seconds
