Home » Eclipse Projects » OSEE » Problem starting OSEE X server(starting runDemo.sh leads to error: !MESSAGE [SCR] Error while trying to bind reference Reference [name = server.task.provider)
Problem starting OSEE X server [message #916775] |
Wed, 19 September 2012 08:54  |
i have tried to start the OSEE X Server with ./runDemo.sh on a 32bit Linux (Kubuntu 12.04 LTS) and got the following error:
./runDemo.sh
osgi> !SESSION 2012-09-19 14:26:49.033 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_24
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -console -consoleLog -clean
!ENTRY org.eclipse.osee.framework.core.server 4 0 2012-09-19 14:26:50.301
!MESSAGE [SCR] Error while trying to bind reference Reference[name = server.task.provider, interface = org.eclipse.osee.framework.core.server.IServerTask, policy = dynamic, cardinality = 0..n, target = null, bind = addServerTask, unbind = removeServerTask]
Details:
Problematic reference = Reference[name = server.task.provider, interface = org.eclipse.osee.framework.core.server.IServerTask, policy = dynamic, cardinality = 0..n, target = null, bind = addServerTask, unbind = removeServerTask]
of service component = server.task.scheduler
component implementation class = org.eclipse.osee.framework.core.server.internal.ServerTaskScheduler
located in bundle with symbolic name = org.eclipse.osee.framework.core.server
bundle location = initial@reference:file:plugins/org.eclipse.osee.framework.core.server_0.10.0.v201207031712-REL.jar/
!STACK 0
java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.internal.ds.model.ComponentReference.bind(ComponentReference.java:367)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.bindReference(ServiceComponentProp.java:441)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.bind(ServiceComponentProp.java:218)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:344)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:588)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:196)
at org.eclipse.equinox.internal.ds.Resolver.getEligible(Resolver.java:328)
at org.eclipse.equinox.internal.ds.SCRManager.serviceChanged(SCRManager.java:221)
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:104)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:861)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:819)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:771)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:130)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:214)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.registerService(BundleContextImpl.java:433)
at org.eclipse.equinox.internal.ds.InstanceProcess.registerService(InstanceProcess.java:504)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:259)
at org.eclipse.equinox.internal.ds.Resolver.buildNewlySatisfied(Resolver.java:441)
at org.eclipse.equinox.internal.ds.Resolver.enableComponents(Resolver.java:213)
at org.eclipse.equinox.internal.ds.SCRManager.performWork(SCRManager.java:800)
at org.eclipse.equinox.internal.ds.SCRManager$QueuedJob.dispatch(SCRManager.java:767)
at org.eclipse.equinox.internal.ds.WorkThread.run(WorkThread.java:89)
at org.eclipse.equinox.internal.util.impl.tpt.threadpool.Executor.run(Executor.java:70)
Caused by: java.lang.NullPointerException
at org.eclipse.osee.framework.core.server.internal.ServerTaskScheduler.addServerTask(ServerTaskScheduler.java:60)
... 42 more
Root exception:
!ENTRY org.eclipse.osee.framework.core.server 4 0 2012-09-19 14:26:50.308
Details:
!STACK 0
... 42 more
Root exception:
14:26:50.310 [Osgi Log Service] ERROR o.eclipse.osee.framework.core.server - [SCR] Error while trying to bind reference Reference[name = server.task.provider, interface = org.eclipse.osee.framework.core.server.IServerTask, policy = dynamic, cardinality = 0..n, target = null, bind = addServerTask, unbind = removeServerTask]
Details:
java.lang.reflect.InvocationTargetException: null
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.6.0_24]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) ~[na:1.6.0_24]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.6.0_24]
at java.lang.reflect.Method.invoke(Method.java:616) ~[na:1.6.0_24]
at org.eclipse.equinox.internal.ds.model.ComponentReference.bind(ComponentReference.java:367) ~[na:na]
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.bindReference(ServiceComponentProp.java:441) ~[na:na]
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.bind(ServiceComponentProp.java:218) ~[na:na]
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:344) ~[na:na]
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:588) ~[na:na]
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:196) ~[na:na]
at org.eclipse.equinox.internal.ds.Resolver.getEligible(Resolver.java:328) ~[na:na]
at org.eclipse.equinox.internal.ds.SCRManager.serviceChanged(SCRManager.java:221) ~[na:na]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:104) ~[na:na]
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:861) ~[na:na]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[na:na]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[na:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:819) ~[na:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:771) ~[na:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:130) ~[na:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:214) ~[na:na]
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.registerService(BundleContextImpl.java:433) ~[na:na]
at org.eclipse.equinox.internal.ds.InstanceProcess.registerService(InstanceProcess.java:504) ~[na:na]
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:259) ~[na:na]
at org.eclipse.equinox.internal.ds.Resolver.buildNewlySatisfied(Resolver.java:441) ~[na:na]
at org.eclipse.equinox.internal.ds.Resolver.enableComponents(Resolver.java:213) ~[na:na]
at org.eclipse.equinox.internal.ds.SCRManager.performWork(SCRManager.java:800) ~[na:na]
at org.eclipse.equinox.internal.ds.SCRManager$QueuedJob.dispatch(SCRManager.java:767) ~[na:na]
at org.eclipse.equinox.internal.ds.WorkThread.run(WorkThread.java:89) ~[na:na]
at org.eclipse.equinox.internal.util.impl.tpt.threadpool.Executor.run(Executor.java:70) ~[na:na]
Caused by: java.lang.NullPointerException: null
at org.eclipse.osee.framework.core.server.internal.ServerTaskScheduler.addServerTask(ServerTaskScheduler.java:60) ~[na:na]
... 42 common frames omitted
14:26:50.315 [Osgi Log Service] ERROR org.eclipse.equinox.ds - [SCR] Error while trying to bind reference Reference[name = server.task.provider, interface = org.eclipse.osee.framework.core.server.IServerTask, policy = dynamic, cardinality = 0..n, target = null, bind = addServerTask, unbind = removeServerTask]
Details:
14:26:50.402 [Component Resolve Thread (Bundle 36)] DEBUG org.eclipse.osee.orcs.db - Logger setup for [org.eclipse.osee.orcs.db]
14:26:50.403 [Osgi Log Service] DEBUG org.eclipse.osee.orcs.db - ServiceEvent REGISTERED
14:26:50.408 [Osgi Log Service] DEBUG org.eclipse.osee.orcs.db - ServiceEvent REGISTERED
14:26:50.415 [Osgi Log Service] DEBUG org.eclipse.osee.orcs.db - ServiceEvent REGISTERED
14:26:50.419 [Osgi Log Service] DEBUG org.eclipse.osee.orcs.db - ServiceEvent REGISTERED
14:26:50.518 [Osgi Log Service] DEBUG org.eclipse.osee.orcs.db - ServiceEvent REGISTERED
14:26:50.523 [Osgi Log Service] DEBUG org.eclipse.osee.orcs.db - ServiceEvent REGISTERED
14:26:50.527 [Osgi Log Service] DEBUG org.eclipse.osee.orcs.db - ServiceEvent REGISTERED
14:26:50.535 [Osgi Log Service] DEBUG org.eclipse.osee.orcs.db - ServiceEvent REGISTERED
14:26:50.539 [Osgi Log Service] DEBUG org.eclipse.osee.orcs.db - ServiceEvent REGISTERED
14:26:50.553 [Component Resolve Thread (Bundle 36)] INFO org.eclipse.osee.orcs.db - Application Server Data: [demo/binary_data]
14:26:50.554 [Osgi Log Service] DEBUG org.eclipse.osee.orcs.db - ServiceEvent REGISTERED
14:26:50.558 [Osgi Log Service] DEBUG org.eclipse.osee.orcs.db - ServiceEvent REGISTERED
14:26:50.565 [Osgi Log Service] DEBUG org.eclipse.osee.orcs.db - ServiceEvent REGISTERED
14:26:50.572 [Osgi Log Service] DEBUG org.eclipse.osee.orcs.db - ServiceEvent REGISTERED
Registered servlet '/osee/manager'
Registered servlet '/osee/resource'
Registered servlet '/GET.ARTIFACT'
Registered servlet '/osee/artifact'
Registered servlet '/index'
Registered servlet '/osee/branch/exchange'
Registered servlet '/osee/branch'
Registered servlet '/osee/search'
Registered servlet '/osee/search/tagger'
Registered servlet '/osee/server/lookup'
Registered servlet '/osee/session'
Registered servlet '/osee/client/loopback'
Registered servlet '/osee/cache'
Registered servlet '/osee/model'
Registered servlet '/osee/unsubscribe'
Registered servlet '/osee/ats'
Registered servlet '/osee/configure'
Registered servlet '/osee/data'
Registered servlet '/osee/console'
14:26:50.692 [Osgi Log Service] DEBUG org.eclipse.osee.orcs.db - ServiceEvent REGISTERED
14:26:50.693 [Osgi Log Service] DEBUG org.eclipse.osee.orcs.db - ServiceEvent REGISTERED
14:26:50.695 [Osgi Log Service] DEBUG org.eclipse.osee.orcs.db - ServiceEvent REGISTERED
14:26:50.698 [Osgi Log Service] DEBUG org.eclipse.osee.orcs.db - ServiceEvent REGISTERED
14:26:50.708 [Osgi Log Service] DEBUG org.eclipse.osee.orcs.db - BundleEvent STARTED
Sep 19, 2012 2:26:50 PM com.sun.jersey.server.impl.application.WebApplicationImpl _initiate
INFO: Initiating Jersey application, version 'Jersey: 1.8 06/24/2011 12:39 PM'
Sep 19, 2012 2:26:51 PM com.vaadin.terminal.gwt.server.AbstractApplicationServlet checkProductionMode
WARNING:
Vaadin is running in DEBUG MODE.
Add productionMode=true to web.xml to disable debug features.
To show debug window, add ?debug to your application URL.
Wed Sep 19 14:26:55 CEST 2012 org.eclipse.osee.framework.database.internal.DatabaseHelper
INFO org.eclipse.osee.framework.database.internal.UriDbConnectionInfo getDbInformation (32)
Loading connection info from: [demo/osee.demo.db.connection.xml]
Hope you can help me.
Michael
P.S: I tested OSEE two years ago, and like the last time i simply cant get it work on my machine.
Current Time: Tue Sep 23 07:33:00 EDT 2025
Powered by FUDForum. Page generated in 0.04688 seconds
