hi,a error of SpringAMQP in Virgo [message #916527] |
Wed, 19 September 2012 05:53 |
Amos Ping Messages: 3 Registered: September 2012 |
I try to use the spring-amqp in Virgo. I had installed all the jar for spring amqp. But when I using @Configuration , I met this error.
Caused by: org.eclipse.virgo.kernel.osgi.framework.ExtendedClassNotFoundException: org.springframework.jmx.support.MetricType in KernelBundleClassLoader: [bundle=org.springframewor
k.amqp.rabbit_1.1.2.RELEASE]
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:139)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:247)
at sun.reflect.generics.factory.CoreReflectionFactory.makeNamedType(CoreReflectionFactory.java:95)
... 29 common frames omitted
Caused by: java.lang.ClassNotFoundException: org.springframework.jmx.support.MetricType
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:135)
... 33 common frames omitted
I check the bundle list in my virgo server. I can find the org.springframework.jmx.support.MetricType in spring-context (3.0.5) , I check the bundle status is right, but how to fix the error ?
P.S: Glyn Normington give me a suggestion for check the package org.springframework.jmx.support. I check it in console.
Result as below:
osgi> vsh:packages examine org.springframework.jmx.support 3.0.5.RELEASE
Exporter: org.springframework.context 3.0.5.RELEASE [59]
Attributes:
None
Directives:
uses:
javax.management, javax.management.remote,
org.springframework.aop.target, org.springframework.beans.factory,
x-equinox-ee:
-1
x-internal:
false
Importer(s):
None
Exporter: org.springframework.context 3.0.5.RELEASE [106]
Attributes:
None
Directives:
uses:
x-equinox-ee:
-1
x-internal:
false
Importer(s):
com.focustech.sem.message.center 1.0.0 [157]
Import-Package attributes:
bundle-symbolic-name:
bundle-version:
[3.0.5.RELEASE,3.0.5.RELEASE]
version:
0.0.0
Import-Package directives:
resolution:
static
FUDForum. Page generated in 0.03232 seconds
