Home » Archived » BIRT » "A data view is not available"
"A data view is not available" [message #123104] Thu, 02 February 2006 08:59 Go to next message
Originally posted by: chris.zzzz.com
I just installed BIRT2.0 on a clean Eclipse 3.1.2 and added all the extras
as described in the install.
When I start up for the first time I can create a BIRT project but when I
switch to the report design persepctive the Data Explorer has the message "A
data view is not available" in its window and I can't move on from that
point - there is no context menu or anything. Nor can I find any reference
to this message.
Any ideas?
Chris
Re: "A data view is not available" [message #123173 is a reply to message #123104] Thu, 02 February 2006 12:39 Go to previous messageGo to next message
Hi Chris,
Make sure you have selected the layout tab and not preview ( in the layout
editor )
--Rima Kanguri
Re: "A data view is not available" [message #123660 is a reply to message #123173] Fri, 03 February 2006 08:55 Go to previous messageGo to next message
I don't even see that. Here is what I see. I have just repeated it to be
sure. Eclipse 3.1.2 + all prereq parts + BIRT 2.0 all downloaded in the
last 2 days.
1. I start up eclipse and specify a new workspace.
2. I dismiss the initial pastel blue page.
3. I Select File-->New-->Project.
4. In the resulting dialog box I expand "Business Intelligence
Reporting Tools", select "Report project" and then click Next.
5. I name the project "first" and click Finish.
6. I see the usual message about switching to the Report Design
Perspective and I say Yes.
7. The upper right editor pane is empty.
8. In the lower right pane I see tabs for Property editor and Problems.
The Problems tab is empty.
9. In the lower left pane I see tabs for Navigator and Outline. The
Navigator shows my project called "first".
10. In the upper left pane I see tabs for Palette, Data Explorer and
Library Explorer. I select data Explorer and see the message "A data view
is not available" in that pane.
11. I can go no further.
Re: "A data view is not available" [message #123673 is a reply to message #123660] Fri, 03 February 2006 09:05 Go to previous messageGo to next message
right-click on 'first', select 'New' then 'Report'
specify a name, then click on 'Next',
select a template (first one), then click on 'Finish'
You have a new report, just start working!
Re: "A data view is not available" [message #123878 is a reply to message #123673] Fri, 03 February 2006 12:05 Go to previous messageGo to next message
That is exactly what does not work. I cannot FINISH that wizard. It will
not exit. Each time I press FINISH, a new Report editor tab is created, but
I cannot exit the wizard unless I cancel. If I cancel, and switch to any of
the report editor tabs, they are calso empty.
I read in the doc that you need to create a datasource first, and I can't do
that.
By the way I am an Eclipse veteran for 4 years, it's just BIRT that is
defeating me.
Re: "A data view is not available" [message #124227 is a reply to message #123878] Fri, 03 February 2006 16:21 Go to previous messageGo to next message
Can you send me a screen shot of what you see?
I'm not a BIRT expert, but I do document data source and data set creation.
I'll do what I can.
Paul
"Chris Gage" <chris@zzzz.com> wrote in message
news:ds02hb$pr4$1@utils.eclipse.org...
> but I cannot exit the wizard unless I cancel. If I cancel, and switch to
> any of the report editor tabs, they are calso empty.
> do that.
> defeating me.
Re: "A data view is not available" [message #124264 is a reply to message #124227] Fri, 03 February 2006 16:45 Go to previous messageGo to next message
------=_NextPart_000_0089_01C628E1.3A9713D0
Content-Type: multipart/alternative;
boundary="----=_NextPart_001_008A_01C628E1.3A9713D0"
------=_NextPart_001_008A_01C628E1.3A9713D0
Content-Type: text/plain;
charset="iso-8859-1"
Try this:
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.3790.2577" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>Try this:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT><FONT face=3DArial size=3D2><IMG =
alt=3D"" hspace=3D0=20
src=3D"cid:008401c6290b$23670150$bb70a8c0@MERCURYMD.RTP" =
align=3Dbaseline=20
border=3D0></FONT></DIV></BODY></HTML>
------=_NextPart_001_008A_01C628E1.3A9713D0--
Content-Type: image/gif;
name="BIRT.GIF"
Content-ID: <008401c6290b$23670150$bb70a8c0@MERCURYMD.RTP>
R0lGODlhgALBAvcAAAAAAIAAAACAAICAAAAAgIAAgACAgICAgMDAwP8AAAD/ AP//AAAA//8A/wD/
/////wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMwAAZgAAmQAAzAAA/wAzAAAzMwAz ZgAzmQAzzAAz/wBm
AABmMwBmZgBmmQBmzABm/wCZAACZMwCZZgCZmQCZzACZ/wDMAADMMwDMZgDM mQDMzADM/wD/AAD/
MwD/ZgD/mQD/zAD//zMAADMAMzMAZjMAmTMAzDMA/zMzADMzMzMzZjMzmTMz zDMz/zNmADNmMzNm
ZjNmmTNmzDNm/zOZADOZMzOZZjOZmTOZzDOZ/zPMADPMMzPMZjPMmTPMzDPM /zP/ADP/MzP/ZjP/
mTP/zDP//2YAAGYAM2YAZmYAmWYAzGYA/2YzAGYzM2YzZmYzmWYzzGYz/2Zm AGZmM2ZmZmZmmWZm
zGZm/2aZAGaZM2aZZmaZmWaZzGaZ/2bMAGbMM2bMZmbMmWbMzGbM/2b/AGb/ M2b/Zmb/mWb/zGb/
/5kAAJkAM5kAZpkAmZkAzJkA/5kzAJkzM5kzZpkzmZkzzJkz/5lmAJlmM5lm ZplmmZlmzJlm/5mZ
AJmZM5mZZpmZmZmZzJmZ/5nMAJnMM5nMZpnMmZnMzJnM/5n/AJn/M5n/Zpn/ mZn/zJn//8wAAMwA
M8wAZswAmcwAzMwA/8wzAMwzM8wzZswzmcwzzMwz/8xmAMxmM8xmZsxmmcxm zMxm/8yZAMyZM8yZ
ZsyZmcyZzMyZ/8zMAMzMM8zMZszMmczMzMzM/8z/AMz/M8z/Zsz/mcz/zMz/ //8AAP8AM/8AZv8A
mf8AzP8A//8zAP8zM/8zZv8zmf8zzP8z//9mAP9mM/9mZv9mmf9mzP9m//+Z AP+ZM/+ZZv+Zmf+Z
zP+Z///MAP/MM//MZv/Mmf/MzP/M////AP//M///Zv//mf//zP///yH5BAEA ABAALAAAAACAAsEC
AAj/AP1Rw0dNILWCAxEeFEjQIMKGBx8qlOiQ4USLFRNmhLhQY0SMHz125Egx JEmQIy+KLJlyo8qT
K1GynCmzZsybMHO+3Omyp0meP322DEp0qFGaOIEetalTKNKmRZ8qleqU6VSr VZNmhdpyyr+vYMOK
BUttrNmzaNOqXcu2rdu3cOPKnUu3rt27ePPq3cu3r9+/gAMLDuvHK9yyDgl2 PKh4YuPEIRlHTriY
suPJjyNmllx5s2XInTGLDk36cmnQplOjXq15tOrWp2G/5jz7s2zWtHHbzn27 N+/fu4N7Hu5aN/HY
wI/XVm68uG/hzpNHh46cOsJUht9O+3dwWkTv3b+L/w9Pnhp48+PRlz/PPn37 9e7jw5+vvv57+/Lx
07/PP3///f4FCOCA+hX4n4ECIkjggQwm2OCCDkYI4YQKVvighRJiSOGFHKZX WFz+cEdNFTBQAQOJ
JqJ4YokrpsiiijC+KCOJNK5Y44025ogjjltQQWKPP/oIA5BDUrFFkUf2qKSR TC6pZBVPRmkklFNK
uQWUWF6pZZZQbqGll1X8AaaXV4rppZlhkmnmFmK2yeabbsYJ55xuAvKmnWLi uYWedvb5piF7bgGo
nYMKGqghfwCKqKKJCtrooolGCumkklZK6aWWSmrIopsm2ummnILaqSqgkrqp qYagSuqqqbbK6quu
xv8KK6ywyGpIraTiakgsrerKa62/7qoKsMMKy2ssxSKrrCrLNsvss85GCy20 sChbLbPXxpJttdxq
6223sFQTi7bikjtuuOeKWw2666obi7rsviuvu/TOa2+9+N6rr7gHYRdXWd6p AIPABA9scMEIH6yw
wDAs3DAVDEP8cMQRs2hiwzG6qHGLHO+o48ce13jkjycaWfLIJiuJ5MpONumy lVRqWeXMMm9p85hZ
jqnzH13yfKaaQLv5s5xE02l0nXcmneefTItZ6KCPRs3o1I5OnSmmWF9taSGL cu1pqF+HfSrXqZKt
aqmxnmrrrGu3revbvcada9y11s3srXfDkvfev/L/Pa20gP+NrbWEDz44uN8m jvjiijfO+OPeevfh
Yf8QNPDFKmCuecOZc37xig/LuHHGHYNsesimE6m6kKsH6SSSLzcZ8+wwR5ll lVze/GWZOvPu+5s/
B3/08EUjvfTxgTqttKHKE3rooVJXLf2iVWud9fXWi/3p9mCLamohZ6stftts l0/+rbbCPffcwKIf
LLLExm/s/IHXLzjg2xbe+OGOr0sut+VCl7nMtS63ZGctUxCXAddFEH/BZTsH QdgfUuEMVajiD6So
QhUSxkGHdbCDJaLYxEJHQotxzESjE13pXIS6FuZoZEM6mQyrYDIaJillsWuZ DnNIO5r10GY5212X
/77kM+AZcU1IJJ4SizcnPRkvecyLIqCURz1ARI96WMwe9rZ4Na8Zwotg7N6m zEa2L45tfGcznxrP
t75YqQ997ENf3dyHN7v17Y54c5be7MdHw3nLj9nizoE+VKHCVEtECCoMsw4y ubeEiCAqUgU18lFB
QFzwgn9YoSZj5MJOnm5FMGxdkVzHshzyMEpf+aEqgcjKIboSTWRKU/BkecQl 2lJOfFpeLpH3tOc5
j1BXDCYXh6lFS3FPe6ES1R/C1yo0svGZa2wjq97Iqza+z33Jyqb8omWs+3mT j/kDJOEgB8B0mXOA
AkwnvuKlQKn4qyAoiKc85dnABMaCO1DBjrjq+f8vERFsC87Ix0FUQYo/GJRn GzSYWDxosBCO0KEQ
pcJXWIQxsaQwhan8pCcXGkoYfGULX6khDm9IUtj1yKJiodJHJfqP2vnQZrjT nSvP1LOeAW1otWSi
Toe3SyjqaYpS9KUwpyfMYhJzi148Jqi0p4oymq1UT3VmNKF5vjdaVY50bN8e 88jVre7xm2DFn/7C
+ceyIg6REakPI71ykHm6da2HjEg8zxNPuMZirf0UyOVSQZBqVPAPVuQZQjuX 0ZCqkHSIXVFGa1TY
f3hSZKAEJesm6zojTXSHIP0HzWTnUiB+NEupzCyUUvnZWMYSTUkUXhJ3ylqf 6vK1ymueoX7pKGD/
Ui2LVjuqUa2n1N4m83vMDC5Vp0qr9MkNjli95ja1Sb+79fG59yOrdMfZPwCW E50BhBe8EMmad1ID
BaABLzX0eU+F1PW7KIgIeQXiQO34c2DOcEZELLjMg/7BRAL7Sn7/QbCwDEws /QULxEL6D4+CxaH6
bZhhw4JC/y7Ywf514WJPBOEqTNSiRwoLDcNC0pAuaaWZZSmIT/nSErMypr2r qWptqtpbuhiXRusp
UGfMNCtC7bZFxe1udWvGRIXRx2I0Y6q+RkZnSnW4SJ7mca8ax2DZsat+82pY pzzWKvtRkPkh5DTS
ax8uG7K84ZlneL6MV7iE6CAocgaySLVmWbHo/8EmgvNEWWpgEpH2wBO2s2Mp XODGWrjAQCJwS1ma
2SFddqRNEkuItXTnRQv6SZ8t7Z/BMtqWXumjYBFiamm52hfbsqegDtRPfTnb UuOWqLndsaqv51tk
KlO4RyZuko+rZGseV7nCWu6xsgndXv9tuuIkJ3bPqc53sYudxm6nU97pDy5j hMvk5e5Aznsde/br
gG0BGDUI5oxjYNKgGvRR5gq20P2GRQUTRbdm53zhApdozhabqJ4njWdK11ne 7Z63Yu2tb31nuKWC
3rBjGZxZghcJpYMOsYBrtsqX5g5nQjQtm1RcS5x2urWtDTUvm2bqPQ311Drm 8ap/vNSS97apZ/9s
psphpTZZT5XJyL3qHKWMR5pD2dfgtLJZHQdmtYqHkN89j1wlN4W40lWe5/ky 0ftpucw5g1hsMwRh
111gPaOQz1iXc4HjvGfGdj3fOdIw2O/so5AG6eyG1qySPGxZqov27QwGMe2w hGnHXhrgmdZ0ilF7
04p7eqcahyJQRy3bXtoW1YgXueI1FWRkfq2Z4EObkWftcuTWOuZ021VWc815 +DV31zinsjiDvfPH
+S9c1y02AWGByMa4frxs/e7rZQ/7dirmvNTWJyz4+cD3qkAVqSBFHu5Lww1K jNz8NfB+EZbudi8/
pMsf4UQNrOCtn7DddKazn2cU9q7Xed9/NvD/v1F25xmO9NGEJjTbMWvihrdS 4hGfeIvn//f6OxG2
QY2toar4camt+v+TQnIkxz1FNkYpJ1yVJ2u6cnkyh1Vz1DdPZnNftSwTKHpi NXplhWVuhQJJx1Zb
th5eVnQ9d17eMVfUoEh3dYLYxhaPNCIlQgXU4AwZhFBCAjFXZ1jhR29Ux28R Jm985n0LRSOKxmB/
VnYcdlmHhlmKRm+iVXeZJmItVWmZRnccVnBfYSYflVk3xWlBU39MFHiBZ3gd d3gg53+Ld4atZnKi
giiwtnKUN2sLuGStUk3IhWued4fMxU2hl3MYmD/CpnqAmF3mRC/Ixh0CsYEW wWwbSE+1V175/2RP
vPcWZRFBBvMHzjAKxDdux8dQHwR9DyUxEWVCGGNCF7VJNuKDj/UxHWVDJZNK I1VKJGVKTuJ+tAhT
75diNJWLficnFueFMYZ/hBdUv9R/OJZqZ7hjSdV4JodyBrhyUeWGCQiHcthG M7d5Ncc3N2eBVAZs
O0d6cZVW5YFX4BiOKviN6ZFWZKaCeUUNl/MwFuQMNdg57TiKoTM6PliKqZiP oBRho9SPq/M67IdK
atd+tsNw7zdTQfRKYJJau+iLMIY8YMhxYvg0gJV4OQaAAJiGvgV5bZhGb7hG cUiNcqhVmrdcuvZ5
2thr3DhdpmddwzZs7WJs/+AHqUCTNlmTOP9Jk15xkzyZk9HWk0C5XrAXFxC0 bZx4lB+ElA0Fikwp
QqG4MVeXWPioUVRJMlYpUiiTlbDYJCYliy9Tiw5nkDO1Mywmfw2Jcfb3ixun fzRmYx5XjKgmKdVz
jFgjgF0TZGZDZAcoedD4kVQFcw3oZDeXjTSXktGlc2Q1BYq5mIzZmI75mIxZ LZAJmdVSZo4kIlJp
ilOZQvrYmf5IWZ9ZUgH5lZ1Vi7lzmvAnSwo5SwyJlmgZkUvjJ4VHahQJlyGH kWiojNzzanyJgH75
csZla7ZGknhILLtmnIaJcytJXeQkiC95bNp1L8iWL9S5L9ZZne5ybf0UMEqZ lCDkMBHllEz/KYqa
WZ6e6UKriJUypDLsiWijaZAEGZYJKVMSV0T22Xe86JBKBJv5N4bEaJF0aVQD qJucwowG2ptp85tu
M42YJ5Izh40SCKHJGVbLyT9/yHMXmqGNs3SUM3uW4aEgKhshShsj+qEieqIk iqImmqIsuqIuWqIw
qqIx2qIz+qIyeqM0iqM2mqM8uqM+WqNAqqNB2qND+qNCeqREiqRGmqRMuqRO GqTt5RZF2SEbkiFU
qiFYeqVaaqVcWqVemqVdCqZfuqVjGqZkKqZoeqZqaqZsWqZumqYR0Uhu0YJb cRVaERVYgad3uhR7
ShV6yhV+yqeAmqeCaqeD2qeEGqiKmqiM/4qojnqokGqoklqnlPqnk2qplVqo mbqojzqUlJNWQneO
okqOpOpzpRqqpzqOprqqqMqqqtqqsPqqsjqOsUqrswqOtYqrtwqquzqqrmqr wKqrwcqrw+qruUqs
wpqsyLqsxtqrqVqsz6qszQqtvyqt0cqs1zqt1lqt2Mqt2mqZboEYz8Ec4zod 5Cod1XGu1tEc6Wqu
7tqu8Loc7yqv8cqu9Hqv9pqv5Vqv+4qv/aqv6OqvAQuw6/qvBjuwB1uwUdoW Uxog6bWmbdWmcPqm
a/qwEguxE5ux/8GBF5sfXKaxHUuxIQuyIluyJHuyGIuxctoWZ1YSb5Ve6dWo b2URMPtdff8aTw3h
bDghXkuBApHqEPO0qYcoqUGrFToLEzGrp2LGqSfhs/C0ED7LsywhXj9rElKb XiSBtZeqqZjatVz7
tUy7tWErtJ1KtlULto16tjOxsGyhbeP4sWkFt9r6saFqsXIbq9TGsdRaq3B7 rN8ht95aHnTbq3a7
rbk6uMH6sYAbuOqhuODRt68KuH4bjlxWgrp6t87KuJOruZm7uZ7buaC7t6Fr uKPbrZ8ruqhLuqK7
sm1bObLxsQRRs+jFZSUKu20lTzaLuzkqu06ru04re1w2T7GLe8SrtTRKu3JV V8MbvPgQvHUlvDeq
tTWLtYyIs7ObvDCrvCqquG11e82ruzv/+rvi27yzK72+q7zB270yirzUa73Z a71NWqTyq6TzG7/0
e7/2m79Pir/7q7/zy7Zr0bBhJmbTK1cO67sGLLsVUrMf2LgN/IEcWLmV21YP LMEEgrsVTB4R/LAT
XLgHwr0m6MEw+7gPbLMNIsLdMcIU7LC5a7NBZ8F6G8EpHHQmPMHzsYEm3MIe PLIpy8M+bLI9DMQ/
jLJhyrprQachkbQR+77a6xNJG7sJ7MJSEbzNtrzixbtV/LTl22xQu7SECl5v tcXO5rRDW8ZRUbRJ
m8bw9L3ylMVmDBXQy8VrzLNUCxQFTMVkDLMMAcZQ27xcDMZcUcdMXMBmjLZl 67Vji8hp/yu2i2y2
jHzIhqy2jWypAKwWk5geg1vAmyu3hcvAhGseBQzKSyzKjgvCj2u6kSvForzE p2zAEZuqnOzKLiy7
rfzK25q+K9zCq9ytd0zKQ2fKoyzDkEurcKvAo2zLp6u6yozKqcvMy/yt0Jyt 0sy5zRzN1PzM0xyq
RmzJ/4AatlvAUKwbHzu0UFyz5Gq+cky+Wky+dKzOf3x7BvG7y6HH3TvGtPdd QCvLxKHEUsy9+Ey7
9GzL4uzK4pvOOpsc9jxt+FzPUHvPV5wQ/DwcOqvAoSzF6nrR80qwGM2vCNvR BevRGy2wHz3SIa3R
zlHJaSHA6GGxo7xlJgggb+XSzwvKLP9dIIrrvC8dwyV4viHMseC7sRh8vbc7 Vx0805b7weLB0rrb
wEF9vixMwuVLw1KtIDpNwRZcvjvtz1K8sXQ11Eu81EMcxEQsxGQ91mYt1mid ZSt4xCIyyZH8yJJM
xooMyYn81nLs1nWd13i91zbryH4915JM13wd2IQN14b913aNyCiNFm4Ljjh8 zY/tzLy6iJkLvtlc
upF92XEbxuRY05KNyZlNzYv406X7rZSNydaczJ+t2dh8zavt2qld2qz92qod 29U8ZmvNzfXbv7y9
277Nv7/tv8A93MJd3L1N3Mdt3MGd3My93M6N3M+t3Pe72Geh0mld1td91mG9 3djN3dr/3d3g/d3i
nd3k7d3Zvc1pgcSJvd56LdjuXdiI3d7wDdiHTd/xPdj1zd74fd/vnd/y7d/7 /RPUbRaXPNu23dq1
beAKDtsLnuAM/uAOHuGyDeETLuG3TeEXbuEIXuEcnuGljd6M3c0JW9IjntEl ztEkbeIgreIpjuIk
vuIuzuIv3uIiPeMEMRg4nuM6vuNhwV65ndIiUt7hLeTjbd5GPuRHXuRI/qVl 8RXISuRQnuRR/qUg
fhYtG+D63d/8Pd9ZzuX/veUAruX2PeZdLrb4FOZejuVfTuZrDrYDPhaNTdsd vuEeXud0fudybud5
jucHvud+3ueAruAhglYNPud/Xuh6/x7oGK6rVU7grivdkN7c0D3pkR7dkl7p lH7pmm7pnN7krTfp
PhmUoh7qpD7qpl7qqH7qqv7pmI7pby4W1i3lsr7kSl7rU27rs47rXopWYu0H uX7r7YFltH6mjT4W
SPwVqSDmZQ7mg+4Hap6nyK7sCBHty87mzy7t157m2O4RhrjtDXQQ3Vw54Y4Y 4n5m4Y4P437u6f5I
617u3KHu5s7u8e7u5I7u827v7y7vk5jtaO6pkohW3OHrh77oA4+q/zANyc7n 0xzwCl8fDK/hBW/o
ig7xEy/xCk7oFY+Ok/juG9/xHP/xHh/yID/yIl/yJH/yJt/xwHoHyHoDhYDo z1zsYv8hruA+Xv66
DDTuEKq689aRVudaOQIPGq/wCl9ACGDwCjI+GdyR7Pn6DqKACswgDaWx9Dl/ 4jWe9DGe9Vev9SYd
G2fO9dSA85mR7OhO7mVR9umO9uau9u/O9mef720P929v9uJO925f92kv9wXu EKIQCn3/95QBC1vw
8lUP49VGlEE+iQKvITiP83Dq5GQR+cJeIJ6e7MnOIEt/H0afCNhACK9ACJ7f sQwPIctgD9PgD6nA
DP0x+metDKAg3gmv67IP7PLB623a+OXh6ygfCsvA+76f8igf/MA//MIv/O1x B/7ADKFwD/fA8uHh
8rQPrizb1pMY+xixf56yDWFvCv//sAw4T7aQD+dObhUzXxk1AfQuQQiooA3/ 0PmfTwjWXv2Y+g72
0A+G0A/9gAo+QfUwsQUKQQwAsYwaPmr+qB00SNAgwoHUlv0TmLDgwYkKKUpc WHEiQ4L/LjbMiPGj
RY4bNYYEOdKkyJIoSZ5U6XJlypYxbdb8l5MmzJpbfP5UVW2ZKYgRKaYa+M+f R6X/8P1jljMnM2an
llJr+vRq1qZYl2pl+rUr161iyzodazYs2rJYZ4qadu/OPWaiUm75w5LnXr19 d6aaIlXwYMJYp1H0
6IfaYYoHGxl6HAtWNaH4/F3GJ3BxY4qMOXvGmoqpzn+iOXfmTFon6tOMPSLd TJHQ/yBCr3K6ok1o
EWjWn0/HdquY90Hey+xN23KvnzS7wBsn9k3FHxV8VKiB+gfKd+vGy5Zq5x5+ +/iDOWGT7914uPP0
7Yn/Xh8f/nzx6umjf5/aY3331G7EYkSyWCrzx7LM3lOMKbcUDOWfGBychpll QlmwQgUvtDBDDDfU
sEMOP2TtjjtCEXHEPu5oLIZCKEKhRfn4yw+/zfwIjDAbBcOKoPKoQUrHhqjZ wpAgt1DFkGocAqUf
UDT7sUkfn0TMo20KW81JijpqzLSDoNyyPHwUc/ILQr7AKqdsCCEEDC6t7LLN Jl9j08l37LnHH+Xu
secdN32EE0p/tFBFC3+wgyjONf+9U2oZYpZZclFDr4TUTc5Eq3JNSyN9dE9M L9W000w/5RTUTSFd
aj9R3fxpCy6IhIVRJZkkqEem8EElR6gGoyuqp1ps0VZf0fr1KV9REBYtXlEI dlamUFA2WV/dcrOZ
fu4RxR9mKNQRFrzaJHZUT0O9FLAbx/1nmv0Ogy7GaZapZpt228Vqm1DsAYUZ 4DzDtzfXTLtQy3wP
Qgo2DHkk+N/FXvsXjCyysE2nQbIAQ119J34v3Xs7Q0WUa+28Rxp7BDIYXWrA vBevLaL6TpklQVH5
YuKIsaygmAs0iBiJbwZOtK1IW+q8kCl2OeifcR5aaKCLRvpoioUlWulQ3N0G Faj/qwlFGvA8S3DB
VLLuw8Eb/HuwD7eQ9YhsD8/+h9kKzTYbRLfPxhcWMMD4AhaqUKRGlT8KucEQ fJGlhtfFAJ8GcMGT
xplGcm/8aqI+V3poypwkV6ofO/c6FnCY/tlmRwXLnElH0hpTZTSGWkqMJYiz AF3hNF9iKXOZDHpc
JnspEmXaPGtiCM6StsDn5LyaWqr4f4iRybvLlmf+MphDl32nMsm9yY+tt579 Jr528gt27r/3PvzQ
x8+ed7fEL3+iUyRvhvJtTrldIoG/QqU0rKTmPP+ojV3W2BaVOtay/ucPZKGA gC3aCrO0QjZeNaWB
zDrg/47lFba4RSLa+MI0XjEN/zKlojlFItJKurUQA44QcAkxoPa6x6MaLW4w 0NoRyfLDjGrkr4ZT
0sY/7FGo8AiOPYgBGMEEZp/GNGM/NaxQmXx2mnKdpzOLyEJt/vEKQkTxC68g om98+MPgkOd2AaNG
Hz7GRc9AZz3SqVMa/TENO9lJM7wBRRvVOEcmsWeLRHwbGUe2NZ28SEZ+zGIg +wPIQd5HkDFKDYz0
eJCnTal+U7rhKXiTNaYgRRuECKOUcCAlsZVtbFhRW9pECcpRirJXpfxk/0LJ rFAGzpWeZFuHGvMF
V6CJEK4gEyJZYzgfFnAzE1wkehTnwhcqBYhIyYiOTiEVyknFctL4iJs056OM /P8DidZkyjUxtRAk
HuRIzzFVkxbiFDAlkxpj0gY1viAmMMTDGOowRjzEGakUuqmaBDPnQZiBits5 g0eo0NM83fS40znk
TtNC6EHBQ82DxHGOchxUPjfSrYLySZYC/ZEfVsNQe27Tox0FKUY5KtJokrSi JR3pSE0lUZZiCn/b
SAUqYtoMmYaCobLyCirS+Q9UoKIa5KiGD6oBhmrUbykTBOAEDVg2fJCNgIET 1lJtBUGmZi5wqxTl
rkoZyqvA0CCuExPEqEGKUTQmnyXckuFc2VSEAC6lKP2IuIgpGHNVbGT68ik2 IdmUHVIIcS6rpBA/
ZzB+eQgpIUNYb14xtzGNiRr/cEALHJTWNIvlaxn96IdMeZQKsSWtsqwBhTTw tJzRitYexfhZkqah
pGKAwrWunazRwJgKJ3rWaE3D7W11+1fexrZoZcJHbyXWBw+m4g96tSaFgEPJ 0BDsktTIxTZwsI0v
bKOTr8TqgrC63f6tTbuoFKArYxlLDnmmBnQbExhqUA1V6E1oBWQMCuI734PI 17e9GeZcc9JV2hGs
Jfiz0T1yUqv0+YUppRNMYfVCDW1m83N8IWf2XvEFRXzBnfCEJzziST4VuuU8 GLlsqTTrwe1ZpHYq
WcadGNXaFZc4SfcoRok5bD6JrBR8M5ZxgW+sY/R1uMc03jEQf5xjaohCcpQS /0wfXiKrq9SPtvdj
8NTqR0qtBu4raAVgU69SwgVSsMpZlepStcpK/lGVql6xIEVgwc4KY1FvekPJ Fo9FQonMOcjmk6t+
mVLGuw4nr5OTioBzotxgBjKcQYThdjxypEW7hdFOZI3v/LiJeMDBnZWOxyYK KR4zcibEUvGHKDxI
yBjip2r3AM+mKZKkVB+y0Kp2NalfrUtaz9rWssb1fIwJ6/70QXIaBfQ/ZHgY 5tpPNLX6ByH80AdR
MPu6bVOb4NIm7asyUEH/G1sDs81AbHO7V+TNUH5eUQNyv0IVeajCH9Jd61wr Uj751W+OjskmURBm
WoKp1be8pbXPlQ6GXEKKKv8IJvCA+7dT5NT3QYxBiWLAYRMMh4Mx9h0qgjak TqDuRyjsAq55h6oY
pz3Vj0AR44SHnOMlP7nJJ75ylLNc5Z7a78vj5IcjE0bJkMKpU+rnB1RoFMrA AnqxhM7UZgW96EN3
ltGnqnRg/RtTf4D6HwDxh5ZXXeV51m9dN/NZ4mRMpvdQToREgYo+9Hy3FPMI LI4iHs+kAhZqFzjc
qQF3WBxWX4lt2iaMsYli/GLvxdC0cLd+V3U5sx/2gMt9ue4y2OZW8I+/r+Mj f3bJV57yl/+ZRyA/
XBotu/N96HyMio0UBXVO2GjTUCvftnrUT1v1cJtYFUbxh1FUAfOT/yu859r/ uP72CMcr5LFJfsOZ
9A2/S7NLXZDj4fdf9N0Yv5An8G1yYiAPufc+/v2diVz97Ftf+9LnfvDFj/3x l0cn5d++jOen8573
fGvtT5BavJwWtqwFLPM/y/3JYn/6698safYeaoi68CO/AiwJrJurRLMeGbo1 Q+I1dnNACJwU63G3
CLS1BfwjC8SarWnACvTADPzAWNPAEQzBB+xAEPSNXZNAFBTBxii21oNB1pPB GKTBQ1vBFmRBXtM9
YkKzkHqrkwJCk/hBIYSrIGwpHyxCIjTCjzIpJXTCI2xCKBxCKUxCKlxCJLzC KGTCKdzCKuzCLORC
8zMIK3zCLyxD3wNDL8TC/zJcQzKEQhtrQzN0QzlkIT3LCa3bvNuzvDzkQ9zz wz38Qz0UxD4ExEIc
xEAkRD18inNBxEY0PzuExEiUxEnsI0c8RMvbQRfir+/jRO/zxO4DRfQDv/Qb xVLsxFA0QFI8RVFc
xVQ0xU8cP6loRQKkRVWERVecRVtExVp8RRxDQB4sFxLMwRs0wXYbxhPEwWQs RmFURmJ0RmRcxhJ8
RmNsxkLDEWmExmlkxmg8Rmrkxmr0RgjMxMWRN6tLuXN0OXQ0x3Rkx3V0xzhB iYISCYvAEovor3tM
M4/AxxnkR7RBOvqjoICURalYxNFoiv2ixITUs3aUOXVsSIZ0yIiEyIl8R/+J 7JJfdCE8tMRE5MiN
9EhD7EiQ/MhLJMmQLMmRNMmURMmVFMmWPEmXHEdy4T1cvEVezMVeZMWa1MWc 3MWdpMmexMmf5Mmh
FMqitEmdDMqjBMqbZEqkPEWMJMdwWg/aWsDrqcqrtMqsxMqt1Mqu5Mqv9Mqw BMuxFMuyJMuzNMu0
RMu1VMu2ZMu3dMu4fMtXg8u6lMu7tMu8xMu91Mu+5Mu/PEsHjMlx6UGBsh6F RMzETEgM1MI4dMzG
hMwwjEw1nMw0tEw2rMyNsB7YyCeqnB7FBM3QtBEe2czLnMPHlMzUpEzVNE06 3JLNbCmoJBeNFL3R
tE0qwc1iyk0cuU3d9E3/3txNqcBAlXRJ4nzJ4zROQnyyGHky0XTO5yyM67G7 4mRJ5KxOjnwygxlM
xtkPlgA26ATP8BTOVGgGpSRK8zRKn0TP9VRPXSRPjmhO8ZTP0CTN40vPpGxP /NTPppwI2tIL2STM
YDyN75yeAh1I1TBIA0VQBU3QA23QBXVQBpXQCD3Q5ezGbdRGbAzHbOTQDfXQ 07DQ+PyHU5iQZSDR
UDDR+VRROyS8b3TRDL1QDcXQW7NQBGmheHOKSKGtwSgEwdgCQNiCFRVSO+TA h6xIijTSJLVIJV25
zpsCJ6WRNYHSJ6XSNmHABMmJhyAMaVimIfXSG9mj8mTSIyXTMQ25KXVS/01B Uyp9EjCBEgC9Edpc
DNJbEJ/7hyowBFWABRXoxz6twT/10wvxA8ZIzus0VOpE1KC5UcGYAolZVKmY gnwRjrsSjAZBUGaQ
Bkv90k3FEQst1ET9VKN51JyI1N4Y1X9o1OXCr1OVyRwNie+UCiQDBENwlxXg VPGkUsHovBspJ/48
z/z01fsMVvOBVUb1njWlEZRAJoIRjKi4gynAgym4g3/oGC69VefcVUjNRB6Z Bqf01qX8VlYsVkiV
CWRNVflRCTi1TSKiU6bwg0Lwgz/YggHZBj4F1HsFkbbBV7eokcCghn79EAaE UXCc0Q+V0YONUd+Y
goVl2IbNolNNVayhCP8sHTRsCjZr6tJrzQlmUUiARVVSBVNPLdiRRViC/cCG RdmI5QyInST22E7b
zCcCzYlCWMQ/oFVYWIGCnB6kygmd5VidJUjX+x+g7Vmp4Fi0QFCiRVqDfIoW elLhnB6g7VXUXM2q
bU2qvdrMPE2tNcNxJVU3OQ/Sk4r6uYGyfRCzHVHCCCCFPFqjXVujNaVJ/M78 YlUeEVPWxEy83Vq9
dU2u9VpUval5UlfCkNNpaFessFNqWAEVWIEOAbcLeT0M0de3mdx9/djBaFS3 GVRQPVTr5NzPPUmW
RY1Jpdh/aJBrQt2MhduNZVu1HZejbVtIfFRW1QmRBd1Qxd3YgljRW1X/SNxE hbDTq0iFsxDIBAoL
b0uqpdI2BxqL7ZK2aDslMougoyol4r3cnIi/tRDIXg1XYe1e9tzP7/XJv50C kVhWsR2wfyjbsvWa
GzBd12Xdjf0foXVbjiWzBlpdwQggVppf/CUzcoFV2pXFVOhWcDXgXw3fA57Y G5mCJfsLAbbN4Thc
YVOQLaiCLXDc7/quyG2lACKlaPskX4IlEB7ht7lRf109ge1Qkk1Yk23hF13h 09hdziCZ0m0QrEBd
j1Dd+BWlHo5b1oXdaePh+rVfuP1fH+ZfFzrhBLTdFx5YGDbYC51hBPGNl6US Lklcj1gRj7DZWFCF
xt2QDgYlwYE2agMv/1JC47jlrjF+oLcZVxRGGzdF0iWl4zm24zKt45IjX7Bd O3y7oX/AAR/YK00l
YiI+4kNGYvjN3/tdZB8el0f92+i82zs20zyuZHYk3ze1ksEdjMKlU9rxg46o AkZoFxXAkv4yGwJK
m44oIY9oKn1UG4JAlv6S5YlAllr2JVxOJVtuCH08n3+FVKel5Xzs5c313GPO 3dvt3HxJ2YaV1Bn5
TF+jhs7xgen6goipn8Eo4iFO5CAOYm0GZyBOZHEmF6d1WiZeImVWZ2SevGZm WN4VPQgmjJlEiCzm
kT/YGkBgBGsCYwvJrvHaZWiTXOxSpa0y6A92mxpJEIWOQe5VYPAdVv9gFd8E RmB8Ytax3QZyyIV/
8AGhmpt/6Jpw7mFvNuKS5mZH7uZx/uFxATaFBlkmLuCKnuiIpuif/LCG4GTe ZNeJSAif84cgmQx7
HcOGsDNZ5hWD6DZewRKrmmXxOuq1eupbZmOkTrMa+9eF7WWGteqhPuWCUOEo duGwhmIWFusnXsEa
juZtyIVxoIZqpq6IqTeRHun+xV/XG+L5lV//bWMhtmuUJgyGZdSFXcgmLusY dmLDFutJdUF5LqaY
xZAtxgrGtddAtdzItdzL3pCp5VqszVur7eys5VvO3lvPDtvPrBWomWZ4sa5I jF2NdU67Fe2+De3N
pu3ZDtybYmy6YkT/4ljW2PZtjNKc0Qbt1SzNZGbndTbuQiXdaF62Zmtu0GM2 1nZt8SRNQl3m60bu
ySMZrMltUOtOkPCD/lIQ8Sbm8c4Q8vZlDEFvx6mQ9Xbv84Zv9Y7v9s4Q/6Tp +57p/H5oieaw8/3M
6QZwSNTsmoZo/ZZpX3xgSDQMEKVkS3bwBmfHIh3rkp3wwwbrCq9GtA7wDVfw 4iZrDAdxs25ABiS2
7iYNLJ5HmKBHFWfxFHfxlFjxF49xGG9xGpfxGqdHxnxwPIZwHvfxS7a60ubw IR/s0gTyI99xJMe5
TTbxctntOTW+KJfyKafyKrfyK8dyLB9O7D7uLk9uj1xuIhfzeJNO/y/n8i+H 5+Vqcnr26hl3cxyH
8xuXcxun8zefczuvcxX3yz0HzD7n8z/387bsz/8e80InzEAH9ERH9L9M1yZP NMaorQ8X8QufdElH
7BC/9EqncE1v0Ug29E8H9VAHYJd1dBXUkfCWbc8W7s9m9VV39VQf7lhvdVif 9d+27bUDGFHX9V3n
9VgV3Cb35OwWdjMfdjQn9mNX7hmpEmNn9jN39mJfSeztXTv8Xa8u8P0mcP4+ 8G33XmzHb2+/xfOt
kmwn92/n9ms/d23vdtqxnyUrdQmWNc0pbErPdPviDHuvL06fd0un937ndwus 4Urc9EwneH8feIO3
8H9notOzDysuJv8s9pFeiZNpYpF2pChRkWqro3hzLCAuuXi2UvIfT/KR7/GQ b5Kw1QmSF/mSV3mT
b/mXR1LzYHJIDPZfwvd8QRacR/b7ynlEJJzO+PnAaXZoJ/qdB0TSXfZnN/ql H3qm90hpj2ffddWL
COWCUCuSmKDprbb6ahGsR6Gn2nqwv+V6gmqJR2of0nrBsQi1r6cU6iUCMupZ Bia3l3h1R/d1x/u7
1/tBNwhKMfe8t/vAL3cDB/z9lPkDLPWdrq/DkHdXyvf38KUY0ZzCqXj50hz4 cvyfj3zguHzHFy/6
iHzKbwzL9/zB8XzSv3yE3/eDV/iEZ/2DCPhDU31Mn319p/3WX33/FJT2SSr1 mCWhWs6Izq+2zW+q
LdJlqGJqtkIror4qaap8Xg5uFonq01fqAjr7b/v9AjqWW5f1V7d1Vad1789M lPfl7+/+8Ed/86/1
2gZ/9Rd/Pmn3uAL2Jzdcrgcmxv+l03cl/Of/56f8mwcIFNRQTBNIkBpCgQkV ThtIraFBhA4FNkRY
0KLCiBcfGrx4cOBGjyElVnxI8qRFlCZTslzpsiRMlTFbznwp8yZNnDZz8tzp syZQnTH9mPTz75/Q
pD2DLlX60ynTp02nSq0a9SrUrFSxNj1KtKWfKUfHki1L1h9Sav6o4VP7VWBb fwrXCqTrsG1Eu3rZ
qp2LAh+KtQP3/9blq7BvXId2D+eVKDeuX8gIHwc2uBaw3Ml/K2vG65ivYLWg PyeePNp0adGpL4tG
3Vr1a9ahZZOOfRr27Nu0Xederfu37+C2E6cSnepo7d7Dlytvnvw5b+i4pe+e Hv269ezVtwNnTr27
c+zchYeffrR46lRizbInS+1fSYmpIEoEWR8F/oz5OerHXz9hRf1JxNh/Bvl3 34ALMUbRgPkFeN9+
HQ0U4X4OTUhgfCrVl2FLG/7XoYYhgjiiSx5+yGGJIqZIIootfrgijC5++BU1 RiEl4384mpjjizqq
6COLPQp54pA8EnmkkUnuuOSPRTIZJJJPwugVj2G1dyVS/7SF0P+WfmzJF5cS fTmmmGWGeSaYaZKJ
5ppqmukmm2+2OaecdcZ5J5x50onnnnra6Seff/Y5qKCFBnooNcUhdBxShCLq KKCRQjqpoZJWSumj
l2qaKaeWonmem+ph2d40acGkKFdWaaXqVqum+qqrsbY6K6u1wkrrrbZmRVRD NsqqK66/5jqssMUG
eyywyQZFJVjrjVoWWqt56Z144H1H3rXUamdttdh2q+144HK7rbfkiltuuOWl m626iRqHHLrjrvtt
u/Haey6+9ebLLr/09mtuu6C6JuqzZb1noqJQKtlklAwvrLCUQMbopMMRUwxx xRljvPHEDXMsMY40
+mqxxx0/bDL/ySeDfDHKGrf8McsrlyxzklRmaGXB7v0TWpc8f4amz6YB/WbQ r31ZNNJEKz0002km
3fTRSzstddRQ/zy11UJjvXXVXF/dNdhfi6112GSPbbR88iH3tNdmu43222yX DTfdcp9td9xU3613
3lnXzffffhcNatQE53xUqTShaqyyjBOL7OONQ+445ZNbLrlNvNaI3OWRe145 5p93DrrojTPrEs6H
75yWbF/NC/C/r8suL+336nt77LXv6y/vsPc+u+3ursVo7sH/rjvuxxvvO/PA 79488vwS/prhh7/H
4Xwxaz/z9ip3nzL4LtMcPszcm+/9+eS/vL7IyI0v/vfwpy8///r1q/9++fbT X9/pKaVuvZbMNK1O
YcpTBiwgAjd1QAUmkIAMfKADI7jATiWMeA2cIAYvqEEIZpCDG5TgB/M0vTBV L2eJe8niRqfC0JGu
hSssHQxdyMLRaW5kM7xhDF8owxzicIdJOV1J/pezaMVmWsmD3vKcd0QlFu95 TFSeE6MHxSVKcVvF
GR68opjEKj4RiVr8IhW3KEYwfkZgsClhwQ6GkoStD39tjF/+7gfHN84vjvu7 ox3zSMcaScSGenQj
IOcYyDruUY6EHKT+WmKz/wgxjTsTIN4C1zZJzi2SlgTcJQWHyU1qspOTzOQn ORlKT1byTRVcmyhL
Scq9rbJvo/98pSphyUpZujKWtpzll0ZoHGcd7oSn0iEwexhMHhLTh8M0ZuNq yDlhMrOYx3xmM5EJ
KyD2kZdDZB1oXMfFbY4xjGScYhO9Kc5wkhOc5pzOFRO1zC6yk5vf9OI4z9nO bpbTPP9AD/Ws6Ujs
IdKQiSwkHgH6R0ES9JAF/Wc/VdS+Gx3Unw4NaEIHatCJIrShEulfUfT5rPes aYAdBKEHQwrSkX60
pCE8qUhNysFTNiqlKCXpS1UKU5fSdKZ40mVb0PgsX5IkhdGEpjN/KtSgElWa lFNmWoZqVKAuValM
nRw1EdLIZxFxNkas5zzfmdV4whOr7uTqVr26xXRaUKtfFav/Wekpz7OuVa2i MSNrdDoqNbKEjREV
KF7vqleLSrSiFH1oX1O2UL8SFrB55eth/wpRxNJskfWZ6lwfeSY/gPKWtcQl Zi+rWUpmlrObrWxn
QfvZVIaWtItSG1JE69nVqra1pmXta13bStjOdnD3nJpcscRTi/i0qE91KnB9 G9ymFhWpxD3ub4Wr
XOTaJKo10uio0MIbbbo1rG1NK3bBytauXle79CTrOrdrXe6Sd7zmFS96gze9 0OT2Stf7UPYUG9jF
yjexhaXvfeerX/s+to/uYyyA67tXAQc4v/xVEUZ7BV0scVSAMX1wTWUqYQjb dMIRprABWWrhCmO4
wxf+MIdB//ye25KpvaQyVU+Ty9zlqrjFw3UxrIwL4xXTeMY2Nt0/aBTEBV+p qo65anfR6t3sCrnI
QT5yedNrG/C2dMhONnKSq6vkJyN5LXDli4nZQ9eV2LXAhh2wgcH8ZS/jd8wE lqp/k7pfMZe5zWsm
85vP59hqqg45kgUTZWOr59rumZa09bNsAd1ny/6Z0IH+koYPXVo+M1rQjTb0 oBftaD/rcng8PrHi
bsziF3N6056uceaKssxPaxrUpO50rJwLWSxJFzfUJXKVpwzl80q51rCO8r6Y PGtZx9rWVMb1r5m4
XvlcWsvwgS+b4xxmOB9Y2WZe9pn/OdhkN7va1L42s6md4P/n1jlLHfVwiMO9 4XGDm9wiLnefNIzu
c7Nb3Ot2d7tHjE8SFtssu31Ib02t71LzG9X9DoqM/S3wUxN836pSdb2hFUCr +nrXDe/1rWkdcV4D
+zO6fnjFIR5sikt84765ck4TrjOEPbvkbrZ2tlMebZM7WyWDZTnKV35ybMu8 5YrMcYpW7d479yzS
o320pCEN9J9PWuhFDzrSiT63RPu80El3utKfruioUx3qdKt0okQ+lntPI9// NnjBvy52VAc87AMH
O9pnjPBut7p1Gnf4xDHecbh7PO65fldS5/72vWe873r3+2iGvSit25mfKoc2 4mFO88TP/PCGnbbj
G1/zmDP/3ubV3rbO29Pgyb7b3PD+vOdD3/nRV0rd8SY96FEv+tNXCqdZ7zbX vX72sZu99mknu6iT
anva33730Vx7nX08GSADXu4cP77xk2/3uufm4sunO/T5/vfp0w7kr6/zlivS 5ckvXvGRt3z3JY/4
l4vf+9z/PuXNT9g5S5XwWQpanodu9anPv+n0v7/98y9/1TJ9//o/etXhn/8N IACuFtZlmb2hGG/x
HgPOngP63qeVXe9NYANCYKrhXLOwHTbFxasxX/QV3/NJH/KFYMXpmggqnwee IAlSX2II3vWpznv9
R3xVXvqVnw2CH/qF335B3vn1IA3qYA3iYMlgnvttHp6p/x4Ssl7qKeHqLWGF mZ4TNqEUJmEUqp7r
IWBZxF4FUuADcqEF0lDueaEYbiEZNhcGoo77CZ9boOAHsuAKjmAKgqB2OV8c umEdwmEbHp/1YeHI
rZH6/eENBqEgAiEhHhT5CeEP5qAi+qD6sR+3YR/PSZUAFuAkGp0lSt3/XWIA ZuLT9R8lcuImEqAm
1p8oYqLfHKD7aWEXluEXrqIrFpMEsuIYvuIsNgTwqU7bZZMK3iEb7mIe9qIc 8osJBqMvFiMxHqMd
yttt8OFYxGB9zCAgImI0DuIiJiIjugwPWqM2TmMhXqPlEWG3GWGXUOEUMiE5 nqM5MiEUlmMVpmM7
vqMUXv9hKiogvsmiPdLiPbZir4RhPtaiP37dLR6OGvoD8SWjMRokMuLhQR4f Hf7iGwIjQkbkNu1h
EaqZ9nFjNWKkN1LjRnYjH0nVMkljIHqkRm4jfjli5hkb/FWiKX5iKYaiS8bk KLIkTCIaapGiTLbk
TIIiTu7kS14diVncPGYaPhalPv6jUSZFLCZlPzbl2QXkNU3XQkKkQiYkVV7l 8w2jRGIlLz6kV+KO
CzJj4SFbRo5kWYokWnIkDWZjSbalWXbkWa4POELit7kjO94lOsJjXobeOu6l X9rlX0ahPMIePXad
Ux7lYSJlBPIjUzYmYjrmSUBlwQxkQVblVn6lQ3alZnr/VUNOJWZ65mYuJEWG o0We1luaZFqS5Gm6
pbIdolqy5muupmzmD0pW5EryJE32pE7uZk3ypm72ZtV5ok/mJHD+pnHmJnIC DioSJlE+pnMqJnSW
2lI+Z2JWp1JJJlVtoFuAZmZ2J3d+p1XeHRblnWWWJ1d6Z3iCZVCyV0UaHly+ J2rGZmrG5V2x5WzK
J36q5nx+yFzCYABxHmAGqF4KKF4SKIb1pYEm6IAuaIHeVFDSG3OikHVSJ2RO qA9NZ3RWqIZ+GnZG
18L92HmC52WGZnqi5+x0ZomKqHl+Zoq+1W0NTEWS3H3qZ37Sp43C5464Jo3u 6I3G5+LVJmne5k8m
55Di/6aRFimSEifdCKdvEqmSOulwRqlvLmedqSKFXmmGYqmKYaiFdumGFkuH spp2EqSKhmiLjqiJ
rqhzaKWapqmZoqkvhmV7kiWOzmiPwiaP1imagSRD6WmN+mmexmd/AlBdMmhg NiiiHuqhIqihKmii
OqoVPiiWDaWEfqmXaqml9hCXZiqmdqoPhWmPfejwvWmblimLwumZCo86NZmb nmqppipVjiYkyuh+
+uid2img9qiO3mqt4imv2heQQqKQPumREmuSSmlxQmmTAg6TJmuxIutxPuuy yh+Vqo6VZim2Xmq2
PsWmeqq2futTgGp75CIHmiqJoiq6vmoysimptquruv/rk8kpabqnreaqvdYr vvpqydhnr+Jqvvrr
NA5qzoijVCkqpB5soyYsojLqoyqswTqsiA1mlRam7Hkrp26rxWJFt2Isx4Jr TIgre1AmvLbquaqr
yVIliqbryJoryeaOrPonrf7pv/Yrzcqsvn7k5qiZzQIsz9YsmAWrfw4rtCqr sx7rtBor0g6tKd0k
0Uar0RZt0h4toVVrL1Gsx3bsxWrrxl4t114syJoFuW4nrL4r2ZbsypYou5Zt y7Is28KOvEIivd6s
3Pbszvoss/Fr3eZtoM6tHgmsIxVqwwbuwwouwt4lww4u4hZu4iKExFqr1WYt 5GYs1mosY0pu11ru
wZ3/4Y5poLScrcqqbdt+LhWl7MmC7tiarVm9LADF7N7Sbeva7b36067Gruv+ 6uuaDNACkNBKLe9C
rdI+rdNGre+mzaKgEvA2LfJK6/AWJ9Wa0ONiLvROLsdubeRK79V+rcJJ5emu 7faGbuk+Wdqirvhy
r+iS09v6Z9zWLu3C7szqLWLh7e3Gr+3+qt9u1H8eoeLmL8TuL+GC3uHqb/8G 8OJGSuNWbXNab/Ve
rj9Sb/QqcGJi71mI6hqabvl6r+d+73eQ7gVvMAVjsGmo7sCWpruob/vK7/q6 L0XNbgnP7wmbcM3g
3M3YJiQpb/D+rvDWcO/i8PKO8KrqsA8n7/HScG42/2/BXKsDJzASYykDI3AD Vy8Ej0XYkmn3TnEF
U7EHlyDeke8VVzEXW8v5AlD6si/fovAKt/AcwS8Ll7Eaj7HE1G9kAe4AxzEA y7HC/i//0rEAz/FF
SWrIRegvJTETB7IsLvERNzGWPvFRiGwHc/D4WvAiL1kWM7IWS7L3grAjsW4a s3Emk7Am72nOrjEn
h7IYO0zuhvDu7jAQ33Aq2zAr53DRNOsPC7EsBzEtU5qkWpofpxggF7Ig0yIh 7zIwSy4ir472djEl
W/Exl2/4TvIjNzIye8cXh3AYk3Eng/IoXzOMoLEZb7M1U/Me04j/VCQc6/Ed k3MelzOi2PE5rzMe
H/9qATvvAfOyPAfzcf2yIffyIWsunQWfBBNkMm8xQP8zqWpwMzOzM3exJdsv JnNzNTe0KJOxCjs0
NrvwzZayI51yLNdyK6PyLKsyDcPyKrtyR290RtvyvO1SLi8gPc/zPX+dPeMz TPPeMEdxBxq0TTvy
QWPwMuP0TT/z+EbzPtFpN1P0QxN1zWrzUG/yRMelGzPY/Y6jObdzVE81g6qz VKMzOzvqOxfx88b0
Sn+17b00S3t1wc10P1emQBc0T6814BF0Tqf1W7tqQkfWQic1Qxe1UstsROP1 XS81fFq0/WJ0SHO0
Rot0YRN2AYL0SBu2Rx92Sc8NEe9UV481ZYN1C4n/tWVXdlnrc/tpYDEHtFr7 dE8rcxaztTGHNpoC
tf1Os1F7s1/bdfsitUS7Nm3TaFPv3Dhj9VVntW4XrlVTNW8HNzlutWTHc2Yf d0ufHWYnN3OLoVl3
LmqDdlxPtxa79WhL93XH6oueUYz6IV/D9my3tkfu9WuHd17/KAwzkgxP1mA/ NmOTdHvH92sptmPL
d30vNvPe8gsacKU2t2aT9YVWLoD/t0xz9iPi4pjWtGlj94LDNTnttGg3eHSz oWpHFmufN4b3dW3f
bZptuIaLN1OfYTiTZm4LN3DvNopH2G/3NoubuMIS96gYMXIP+Iwf03LTuH8/ pYGnJNietYNLOHUD
/zlnRvKEF3mQp+pcO3Vdm/eHZzh4ix95e/iTl/dpAnZkCTZ+uzdiw3eW2/ck 0XdjhzmX37djR3aM
T3aNp3mOF5eAE7iao51Zf/aPRzidn/ZmQridZ7eRQ1+FO/WFNzmgT7mUw5xs fzeTC7q2iXhGkbiD
nbijt3iK++9NRrqLV3qknnQfT6xxrzmOdzoY9sqoefqbF7iO7TOCQ/eR57mQ r3qSWTerq3qdo1eS
79ySG7qtUzmu21eUg3igH/qzWblTYzmZi/l7F/uWG/tqgfmYE/uxN7uWA+VJ 47Km97eoc7qbE8uN
X3u1U06cu9qrM3isz3lY4Tm4w7q5y1qf79yfI/+6k/v6reNVoec6r7N7fd22 5j11wT66pes7pYfQ
iu87pPN7xPLxfsMztWs7wo96qIG67m17wnPojqehj+/5t4t7udOOq4c7xWv8 xs36vde6vLf7u8+7
YHW4u4d8r4sfsO+csDP7s3v5ssc8sr8y03a5zQ+7zO+wmesWmlu7wvt8DGX7 zzt8D3W723G8nqf6
xbMhuVu802/8uqT7va/7yQ/6yIs8x8S71aM8vRuYvRtbife7wAc82ZfUv4t9 2aM9ARO8WMJHzxM9
0MP9TQh93D88t0c85xbR0yv93id97mT8ufd9xduGxxsbyG894pP81Z/PrmN9 4jt+Y6X3Y603nsH/
/MzfvMtb/g4r++XjfOdnftPt/JXIeN0Pvd3nBN3L/elnbql3Nj/LOdQvfewL PjqVNtIPPt8TmdQb
G9UvftdXveKTiNYH/+OnPMd8vVkQbI2oPfOPPcDnydk7f/On/Z/AOM9vuuqb vvbvI8Nnf+nb3nPr
/eyPf+6X/98Tufnjvt+vVeEnvwhv3+/7PvBDfpE0vvEXf/zTpuSbuu7OsOc7 O0D4ozYQ30BqAgka
REit4MCFDQ8ahPhQocSKCR1azIgxIkeKGxleDAlyosaOI0+W9GjyY0qRKlG2 lGkylcFU//65JPmS
506fOoHOXDk0JkujRGEm7Rn0aFGkS4U6lar0/2dUiDhrlkw1BWdXr1+9TstJ bZrBaTXJmlU7sCzb
tWndxoU7ty3dt3Xx3tUrNy/fvXb9BgY8uC/hv4URH1YsODHjxYYdR4Zs109a PzgfN56smXNmz5I7
g/68eXRo0qJRG8ZZWa4frmBhe/U3VmBBf6xrn8y9cHdF2751h+QtHPjw3xmP R0zeG3nw5cSbG3c+
XXr14tejY1dOXTvz7dazh//eHfp48d7RE68p8OZY8+/TP5fP/Xz5+PTh29c/ H3x+/uT/qy9A//C7
zzqsytsqtgVz+qcumx58y6C5JoxQrgonlFDDCzeksEMLPeRQxBBJBNHEDEc8 EUUVM2QRwxVRLP8x
Rhc/nNFGGHFsMUbWqLksJxpTvFHHHF8c0sgikayRSCWPZDLJIJeEskkpn5Qx SmpW09E1BmPDEqKG
/PjSJDE5IhMlM9EcU80y1zyzzTTZjNNNOeGc08468XxTTzr3vLPPPPkM1M+B 0KKmvUERBTTRPxkV
VNFHG13U0UghndRSRBEUU0EuwRKLL7RMC7W0UVMTtVRST0vVVFVRXdXVVj2r rCwfYT3VVlZvfTXX
WnHtVVdfsfyHx7q25PSr2ZYLs8D9lh3QQACbjba/ZwWUFtppmcXW2Wyv7bZa bZddz1DMti3X2m+9
JRDcddOlVt12uUVX3nczQrC5TY3tCssXC7X/ckp/qwQSYCcJprLggQ1OGOGF BW5YyIAfPphFHmmF
+EqHL45YYYz/5djijjVmOGSPJTYoywiLzRezfz7ywyqomqKKqaeqihlmmmee 6mada8b55Z55zlnm
n4XeeWibCbUJM6KZRrpooI/22emmpa46aKqvnlprnDOtCF+VPaULVF5/LZvs s3dNG1i1zWYbbcNk
7REzt+le2+62734b7709y7K111RmmTbhcIuX3sPdTdxwxc1ld17Gz0V88ckb h7fy7MQ99HHKI4fc
cckvB71zzj/33PKIul7o63yxtDAVkjceWfaMaQe59o9xL/l23W3vPffYdx+I YsxgFzl4433n//13
5Jcv3vnZ//VbrZRV9lIjZS+tVNLtte+e0u+zB5978b0P3/zx5Sz00PLRb5/9 98mP/3z455cfpa4T
Wt3YsPEau26+/6c3AQaQgHkrIADhZpm5GZCBCHTgABsIwQf6RXrEApzKkKUb ZZWOdKfjYOhMtzkQ
dlCEoxvhCU0YroisL4UfbKEHYVhCF84whqLjoL22oz9O7Wst/Xre8X6YPOAJ kXnKM+IQmwe9JAJR
SMNzDxKPWEQoTlGKVQziEonIsZNliHqsY9n1sBa1rFlNjGU02hmhhsanrTGM amxjGuHIRqepb2lb
G+MdzRjHN8qRjG60Yx75iEc14m+FF8wX///M4r8IHlCCjWTkIxcZyQkmcFYL nOQlHSnJTGISkmWp
oEG6aKzZRKdwKKShDGsYQhumkoSrROUrXRnL3mRugaq0ZStvaUpW6hKWuXxh 6mxiSGO1DkWvU2IU
r4jMY1IxmcxcphWf2cyFORGaTLRmFqOZzWtikZvKvJL03BLKHf6DTNhzn/3o d876rVOd7UznO9EZ
T0HRMSfwZKc93SnPfN5Tn/i8yj+yYhEdcgmRbFEkJzXZyU0uVKENTSgl5eYe hE6UoQ+lqENF9Unh
CZNTGeTNBnf5wl7ikqS8lGVJRXpSk96SlvVMqS9PqdKXojSmMA3pcHCYm4Ey iIdx8aE2sbn/TW8G
lajddKZQj1rUoVLTqNVUalKbKk2pAjWqJhOWh8TJJSy1bI9d/aMf+6jHr4o1 rIEEpFfLilZBJo1Q
dUzrWM0K1rXGlaxzVetZ4Uo0QrKHowQdS/8wWtGLWlSwhQ2s2+JWMcIedrGN Hexj9aLRHvWVQaP8
TilnulKa3pSzI9XsZzMbWuu0tLMyrelmPSva0toUXcAkFGUXRMwMGROpTq1q baeKW6oO9bZPrSI1
c+vb4PaWuLw1LlStyqNwwrZL5LyeP/sZXX5Od5/VhS51r7s9elpXutzFbnez G159ErIgO11QQcly
UMM6dr2QZax72RtOBUq0vfV9r33jCyzJ/2a1ss79KGhPC+DVota0AxZwak9L 2gMXGMEGVm2DIXzS
nIbEvM3lV3GRm2HbHnfDGh4uh4PIVBDv1sMk7vCJP5zULU6Iv7H9IkZcllcZ v5XGdp2xjWuM1xzL
Vcc4Dtp278pjIde1x0UeMl2RHOSf7NVQzIUNes9yXynnF75Vxi8mE2vJK295 ylbuslr262SwWHY3
mA3wgxmcZtaqmcBrdvNmSRvhNy94zmiu85nZ5domB25lrksxik38Z0EHmtC6 NfS/gFto4Soaw4A+
dKOLB07LiPkr1oOxeL+bae9uGtOcBu+n56k0l2q606UGtadJfWry7pnPUFbv l2FNZS7LOv/Wncky
fWs9ay/TmteevOrf+Cy4ZNG5zcUm9rHtbOxka1bBy3Y2nh0MbTkrG6cABU6F YdNTuPz00SPudom/
7ehFhzu4Igb3uNENaUZ7O91MWjEoKe2VrYLxxkYm8pGVnOR643vf9/a3vjkC 5H4D3Mf2JrjB853w
gTMZ2536ayJzHfFe65riX751xScu8V1DNszBJjPhpo1sabNZ5NE2ecitFWeS P/vkKx/5nTmr54ZX
2kHFHDS5131udeOc5+1WWKJ7vnOfi1voRY+ipGcVb30599KnNnWqoY5qqT99 6pHaLtWx7nStRz3r
clr1zMPycINqHOMbL/vZGXlxsq89423/x2TH+exRhYAU5S+ndsthXne8370+ zbZ7yfUeeJfvfVsT
Lq/SV3Zhdhtd54t3fOMhT/S3mFvykb/50C/PeH+9e6PBnjeMFb7jf4e+4PwW /cFNX/rR00TUqF/9
6UmP8IHHPvUyYzjiHST29LLd7LxHu9sFqHbg+574w9fvr+fS4th83DZmJjzL BZ/3wUef7wVWufSx
X/3sA37675I57mU7IdpiPueVN3/mH3/+8gOd/EFPP/otX34QIX2ynmf6SMzZ 9apzfev797/+0+nq
+g8AB7AA+e8AgyWg8gf3XK34es/4HjACG0n4JNABf68CSQPuAkfuHILuum/7 oO8DtW8E/7mPpVaI
XEIQBP8uBUmQBQ2P1QJH29qC29qvBjUP/tTP/eKvdigPB31Q/oBQB8WN8+qP zz4P/2jv9VTP9Zgw
CZtw9qDw9AQO9qJwCZ3wCqtQ9srq9oKtASHwAsHQAsXQMuYrDL9wDDEwMTQQ gwan+aivBFtwBeXw
+eYQla4vDukwD9+QBXXp++zPz4LQBt8vEG+QEAfxeNivEIXwBxfREKmI/pQv 2+4PTAgQASvx/wwQ
Ey2xTQRwEz1RE0HxEvHp6xhQ96LsDFExDc1QFUWDAlfxFdFwy9YwXzjwIDxQ BfVQBOFwF/kw2fwu
F3FxD+tQF2fqBcFu6RRvBwVRGRVxGf9z0BknBpQWiBkPERod8Rl7iwgjESyO EEywkArB0QqzsPbI
UQm1cAnpKdjUcR3ZsR3d8R3hMR7lcR7zRQELqQtN8dVSERb3MRYtbr7oMSAF ciAJsiAN8iBhY1jg
zePa0BaFERjx8CElkhjnMHP8IBUuMiMxciM1siM58iM9MiRBciRFsiRJ8iRN MiVRciVVsiVZ8iVd
MiZhciZl0iUTBPxqbrYY0RobsSd58icbTbmqsRmJciiNssS2kebKSRQzkSk/ 0SlD0X4KBSqpsimt
8im/5xhxwgtZsR+9sivBcnq+kh/D0h+TD/dq8TZ4cRiDkSIhci0HTFyQIxVo si5r0i7/8fIu9TIv
+XIv/bIvAVMkU+E+tLJBkhEbjxIxqXExFVPcFFJ42gMhD3IjC2Uni5IxnQcj myQp5e3FkHAczbEc
nzAcz7E0RfMbf+x6JHM1u4IyTTM0YXM0xZFmlEsrSvFTzLIsxzI3CytuhGfp ViY4G0Q4g2U4jbM4
kRM4j1M5k5M4mVMzdTM6F8o3z5IhSWki2zI7I9ItsfPu5NJH/gEVmAEVyDPK agIWqoE1B1K5tBMu
u/NyWCM5CjP8IOQaLTMx7xMz7fOZeIQuMQMV0hNLtqFBYGEsnPNAlxNBmzNB GXRBk/Mi+wU/95NH
/gBgpuBCMTRDSSRDOXQKYKRDNTSR/yI06exvKa8yKrEyRVF0RbMrHcNzQP2B GYzBGPAhJwZ0G9JT
PQWSLlWUKQtBC8prUcCzKzzUTobUK4pUTI6USDXFTQqTK8kySnlzSvMmy/YF FbDEGNRhRo3hH1Th
Hwb0S/fFMMl0TM20TNH0TNU0TTF0TDE0TXmUN2vidWqiLOY0ygpjCwrhD/7A D/7AQysUNC7IQxOj
r6agMEC0TZNv8tDSv+bOPbkzUtuzF9my2FoKJ1ABJ4xhHNSBHLo0R3GUHVHg K0ZVHl/DR051QWhr
UjmIGpoBIiYEH5qhWlJBCwaiQrcFVevDNXh1CnpVOpYUJ4pUp64NJw8zPxsT WZV1P/99skiG50rT
8xe2VB1+4R8KlBpg4UxRYFtRYE3HdFS/NU3F1VtzAnAulEjHNU6B0ojUxyYG Jm6ogBpAYRmo5EI3
zFBRBqtwkqtAUzZf019Ps19R81/3SH1GSVhgVEaZATPC9DhRYJRKdasc9mD/ oVsFJzkptkEyVmIj
CkmXbmPjdGBNLxW+ZFbnahn+gV4J1iiC9R+mQCuK4knzkUqlk2altEoV6EpT QRVSARZ6VhWoAWhh
IVvJFFwr9mjBlVuxhFstNmm3dWm3tWItlhqUdlwHdVwNU11rNi1mtWtTBRSU YV7BFhRyQhkYy1Bb
g1Gt87ICs23/8m3dNm7hdm7ltm7/6fZuAXOFJLZl05NoD9YfLBZwqTZpIVZw WaZbHzZwEXc2RlVw
H1ZjIVdiL8hlIvdiLzYVTJZV4YUanGFCqAUU/CF0RXd06XUYW/ZlTyKgVAcn l7VZJdR19RN2kecy
9sUP0nMb/KEY/GFAC9QQ0JRpl7ZBjHZUhxdpmfZoqTZ4nxZrhclDsXZf1PUy jacZvJZ6MwYUigEU
iAF7QaEf7oFeBxFtxRJDOHPpqrJHT/R8WTR9rW5M/WBAU7YfimFliNZMpzYn pjZ/kxd/k/d+9zdp
9yVq19RcwbMynjcn4lR908R6qbcmrFd7luEeiiEqe7WCUTd/nPQ2d3ODt7aD KY52/28VS4rBHt7B
Hub3SwvBPWoDXB0CBQqiYlsYH1g4cWV4LGg4eak2N7q1OcpVWAviNaYgN1Q4 JNxDa8EQc2d1Tg3F
VZuhTv+CRzwUFEChKx+zCDfQUcMDb7XYbrl4i724i8H4i8X4JNtiltwXJ5bB HvrBHlA2R33XfuFY
eAX4eP93joO3f5d3gLekdn2VXNV0VbdTcZYYLRBCiQmkVkMYUgmzWO0vSejS D2BABSJ5kiW5kin5
ki05kzF5kzW5kzn5kzU5I9c1dkc5WUlMM1GkcP4gPZdhGYqhla21KwpBc1Mr el+3SWY1QnLZRvSU
T/2gEAC1lGmEOjvPCD1zIpoYBv+qAAaoQJmZ2ZmbeZmj+ZmlGZqtuZqxmZq1 eZq5+Zq32Zu5WZRn
c5xXljQD1pyJrHCSpkH4VAv4tE/f2Z3/AGhzQiDK1J7NFJ8NU5/3hZ/rWU39 GXXyGaAJGpVFNjZn
4keD9KDlyB75Ch/9gi4l+ZlhgJknupkrmgouuqItOqM5WqM9OqM3WqRDuqMp 2qQxGqU/eqSZGUI5
+INz8qXrxg/aYlZiNUZg1SRuGkVymiN2OkN6GiV+eqh1Wqdp2mYFg0LNsIrL FyeY7yCSeQuoYJml
mqqnGgaqGquvOqu5equ92qrBWqvDuqvH+qvF+qy7mi4rVZFJ6ibwTBlKN5BJ p3D/auKf7Vqg8Tmv
+3mv71qv+5qv8Rqw/Tqw/7qwUQdCaVlS5Vo+b/IPd2SZIduZI3uyJbuyKfuy LTuzMXuzNbuzKRs6
mVWY3VVKQDiZyBYUZidR7ZVDVPtQY6S1Z6tQhDJGaLu2bfu2cTu3dXu3xc+l SVl6f1AoSdSYy2kL
qkCqt2AZmGEZjBu5j5sKmhu6nzu6qXu6rdu5sVu6s7u6t/u6tfu7ubs22fcT i9M96uQm2AQWgHa9
g1a9f/pLiIFlwHd7lvSC3eR0zeR0A260FZutywtCFXi8q84eDw+ixQa6oTsU /KEf/CEUmAHBt0Cr
kRu6JRzCKxy5L5zCJxzDN1zD/yHcwzccQyccQz88wreAOs3uJipzNFT8NBZi kJfYLy6jMFIBR228
Gmzcif0CdA9CbMN2GVA7Mgb1L8Q3L1o7LxLLlGXXRMK4ycf4ye1SbeMOi21x C7bgD7aAGRicwUPh
D7bBxr/8yq1czK0cy8t8zM2czNU8zdkczd38zOFczVEVy1E1zs2cPRcbdcYi dIJlWQTHqbvCssbD
rcuDGraBZxF9ZxUdaKNDGUb30UMXFAYEVfvDgnv1OU53ODKnvyn1LTv9Paej UHTKWHvouK08FOzB
Hu7BHkLBymHgBrAaq63c1HFizP9hzE29uWd9C249133d1nE92Hd92JvbXM31 1/93nZiNshkaRImT
WEgceJAFZ5eJxDDHhYdABIQxRBW2oRBu/NsLgUS69x78QYq5V4ptZ7WdqshB qd2XPLSBG95vWXj0
1f5aBhDEXBRCQd9Rocu3AN+xHOD//cprHctvPeDFXOAVPuEZ3uAbfuARPuIh Xpj8AOItHuDxHJ2Z
4s+PZYg5QqtsbzaK+GJhAr114tBvtCvgF2iTYtznu5yDRr9Rol0RWmBtXuMZ Oue1xqFhEGzyUcyx
/A9gIOiBvuiJ/tYP/h8MvuCVnuD/oOm9YumTHiek3umbnuixflCNfuv7dOLQ e1whA2t1HDAQmIdM
XsZjui5q3Ntv9x/aPlAHo3v/UbstlsEU6gtfxdKmPRipZbqxmLpRSckQtsAQ /kDwuaDws5wZmGHw
EZ/wBd93If/pGV/wlf7WCR/pJf/yJ5/XM7/zkf4fHr/xRX9Ip8DxN9/0HR/P uc9y//afs6Ny/xYk
egMn6ncs0Ps5CL05DJ3bY4PlqQN7lYMYWvkhM1099HatP92Vnta/k3/NVDeY HHu2/r3xb0DwmSF0
+4EZikHwAaHxef3fQR/0eb0rKP/7ASH8H/8fut8rfLf7IX/w1V/8H3/65795 ud/77//xlX0HDbtD
iEMgAMIfNXzUChqcZjAhtX+pGhZsmEohNYQF/fwrSNGgqm2FtsG4ASMkyH+F /xRmTHhymb9loCRO
dHnyIMyZEqf8u4nz5hSJfgz2LIgiqEmaQyXGxJgwKIqjL40SpYYCqdOpCpVW dRmVKsqnMrV2LQp2
q1epYb+KLUv27NafMv3YzAk37s2FBAvW9WPoT968XG5sCeWvX2Bmf7ZV26ZX 77+8//40bsxYsaHF
jitHhlwZs2bLifcmtnjTLc4pnkt31st2oMG6qu2ufu06duvZrFlfZCqbtVOB uWFTE+gPn6qHFwXW
NpjqIm1qsLZt/LcN+rbozpfHBrWMGMvs/vz9I9Y7vPXxx2W7PT8FveyID4HW RVGevO/48bNCnY9f
PP381uG752/ffvrxJ6B8A/8eaGCCBS5IIDURHZfKW3JN+M80ymU0TSqneRaK PR7eE4ohH8HgmWaL
UTbZXiieqGKKkq3YIoob6vXWFDTqNKNpe/WE4Vc9kvVjU0IGSZE/7A3p41dH EilTRBGVBJGDSVoU
ZCocGYZTNTj9kWRBoPRzjz/T+BPmNGD60xKQXSKpZptsvokQj9TwmNU0dQIl 1H1R7TmRUgjxCVWe
PUb1Z1NL3WcnnoTuaadVUDWaZ6BB/RkphnXeuaefkiqKkaZuMvnpmqDCKWqp oZ5KKllsZSQahRN6
RxBvv/mhiiG13mprKMyEIoqutv566z/BLqZKTr8Sm2KxONlqrLLM3lQrsrj/ 4noesOlNMS2w2t6a
mnG/GeStrOGCq5q45ZIbq0LpFjQuu+dKZO6638qbULzfJtduQao8J9dw7sqL ZjHYgSIwmP2AYm/C
6H77L8PzOpxvxFIKFJE//lnsblQCZUpQnlF1HOjGEJ+r8X28oSAyxvOiLJTF se7p8m8wD8Ryw+Je
nJXI9vGZsp4LK2zzz0IHTfTDQBs9NNJFSwzwuw8f6W2Erk64kFipGIK1KoVk jbWtW/+a9de1hs01
2WB7nfViaJ+tddlrj/12122zLbbcdRsi51hCqmVW32n5vTfgTA3OnJTNBF6R cmd1NGFJhBsFyj0H
C87V35YjjjmrPgFl0KGK/wq180uh73ynRKF36vOhSjHKOVCJ7pwo55GKBXvn iPrcup6eo5V55b3r
/TjvwfN9+fBzBt7q1HAtJOtdsPz6fK3RGzJ99dBfLz321EOPk/XZf789+N6H T/745tvqh0MOs9Y8
ubK17+77vsG/vvuz0Y+/bwmxj5xy9KuSCq0BcIABvN/8VvMlhB1Qfgw0YAP5 90DkSBAqJ2NNgEx2
H5DpjFxBgeB9cocPmO0phOwaIVAqODOokFBmdmkZbFD2H9mpBlAfrGGe8hfB +Dlwhx7sof18qEMg
1i+IPyyiux5ELqkpDy4WAtLVsgXFbUkxilScohWriMUrajFb6kuVF0cFRv9T fVGMYaQSGc8oFVCk
aYyoCmMb2/ISOqFOdHQ8nQ1vN0f7FGqPtmud55ZyKdQBUpAU2V1Wdhe7ROLO Z3wklOvQyMZIulGS
kJzkqFblEwkt8SbesZkfYqEKUIoylKQcpSlLicpTqjKVrFylK1sJy1e+MhU/ YdrImobLW+ryaLbk
pdMkhq+k9VKYvyxmLn15TGKmq2IT29S6lAIyzr0sKD2zSjRXdsMZ2q5jSomZ ylxWM5lxk5rdPCHJ
hJIuPoGsZCH0mAuXZsxdKlOe8ExmPemptHzmC4myUuIm51IhiVwNFqGkXkEJ GguDJhShCm0oQx96
0IguVKIOpShEJ4rRimb/9KIaTV9qfic83xmveCItKfBMGtKTqjSlvGMLJldK vMA5EqaUA559DnJT
ktJUpyyN6UhB6lOUBvWkH42TJjdJF9h8EhaiZGoonRoLqEq1qVR9alWjetWp WnWrWOWqVrsK1q+K
Naux8CiCGHTWBqV1rQpSa1vZita3yrVARzpSXO+6mqzgFa74cdRsLsjXwM7V rXsdrGALux8kusaf
/2zikAIoy1hKNrKUnaxlK4vZVHqUlpzdrGc7C9rPija0pB2taUuL2tOqNrWs Xa1rWwvb18q2s3Gk
5Btva9vcWrKSvMXtbn3bW91C8qVzOuoSYQUxP1QjFsttLnOf69zoQne6/9Kt LnWva93sYne72u0u
d7/r3fCCd7ziLS95z2ve9KJ3vep1LjMrNtv4xna+8q0vfe9r3/zid7/67W9q CQI11TAWqYprSiqY
imCsJnjBCm4wgx/s4AhDeMISrjCFL2zhDGN4wxruMIc/7OEQg3jEIi4xiSHs 0oL8czQrbrGLXwzj
GMt4xjSusY3/WRHkGVd5zFPqcm98k1NMYxlALrKRj4zkJCt5yUzOyXLrqmIc zkZqPDTiEK8sZSFm
2cpbJqKXsbzAKn+5y2DOYZnFfGYtS4l/A16iYzF04FgU+RT/kEYomoznPOt5 z3zu89SYKiceXahU
ognub4UL3EQjetGHbv+0oR+dY1XteGqdNJpy5SxjZtyDGRb6xylu8A970NnP pC61qU+Nalc9+V6/
8V88KWaTV88Tmfgc5j1pjetZ6/rWu9anrHkN7HzyEzmTdtVCjhLnTOeEGf9A xT980Gy5BCXV1K62
ta8dY0Bv7ti+K/RQe1pTcPP02+QOd7nHbe50o3vdQIXjWopNoaTG5tI5QW1c RpEKURhsGpv+RyjI
4QMw3BkuKMBJwSl0cGwrfOEM13M1YAFleSeIyhaEJmFfWB7/qPDih+W4YT+O WI+HvONpVayA4T2h
Nx8k2TgBDVxcjhMNkWnmYfJ3LnzwBVHEJeFT43nDfw70oMs4lIGeyKD/Q+Vt OvJR0ZZiOqQZ/XRH
O33qUFfVV5L3T+SKi94xl0ty4pIKwYRJ7P/wAyr6gAqY30Qp/yi429c+bbYL fe50r7tcVk2xVtvz
XrHOGMNg6FerWIycIcTY6mRG+E0NPlK29vXeGw/5Xzu+1pKP/OMrH88AAxjl cqlaV1geGrmo/SZ/
MJjkJKe8hLv94Dz3ud1fD/uGazvSBQ5eoTOiRxoO0naFPGTs9FTID76ucz8t vlDV3W52G3+nyW++
8fKWSRf3eN4/7vrqCp6c7DOkMZL7g/e//wdAgJ/gBm+7wVUf+/SrH9urbs/0 0UzxPtJMUh104cfM
qcKcmZCCek2hxtPM/2VhpmZmRmYFKIABSIAHOGYKCGYmB2supnIYAXplJ3py UQX3YA/3UAWxEAvb
8FzbwFRVQH5rZ345EXfrh4IpWGraFidG90ZJt3S7Zyk0lEis8yiB9Ec1SHVS V3U9yIM/GHVXd3Wc
FxeVFi5cdxNfBxdKmBOAkIFV4IFR2IEduAU7V36u93YqqIVbyGR4NzGulkzx V00sJE7fok5kCE4n
400zU3j6d3lvSHlwmGvBZnlxaIdzOHn95DRtxmMBpRATOHoUGBdVYA8b+FUi aIUkqHrTBndc6IiP
aGOzdzzcpjdJ9zlJ4U5/BDrBd3h48iib8ok15HzHp3ykOIrMt3zidv+KQ1FU xSV9/1AeSMgQoyUX
XLCBqyBKuBhKiAiJveiLe/ZwEQeLbhV/JEcbeiVyyWiMIwdyytiMy+iMALYc fDg1ETgRE9hiVhAD
2qiNXLCNMfCL4SiOS0Z0tWWNTAKDQRiKPqiO7LiD7QiE72h1kuZiWgcuslhv 46iP+3hqXlgxszhf
NuFfA8lfBUmQB2mQCYmQCymNDUONxlZ7D8FU/EiRFXlqkvgTU6CRG8mRHemR HwmSISmSI0mSJWmS
J4mSKamSK8mSLemSJJljMYF1BAY/+Nh1LRaIFqmTO+lksSCMr8iTQYlqecdm RMhER3eNE6lnyxAK
TOmUAyeUUYmCLHj/PPHojldplVkJj1spj4tGXDN5XGA4K9UHdi6Wk3Axajlx D2kplW35ev7YavXo
lnOJZ+0hLw8Zb36YENjIZMugJTehJcxgZ3RJmEGHkSoGlIWpmEDWgu/2irFI lktolktEZ6oQPf+w
aaIGZK6XiIvpmRQSjBP0YgvxmaUZY9IIIUaZE+fIl0t2ClqyELD5D9XAlk3G mabpmeXYgp3WYryJ
m7+5RJEmJGCpPPbILjaZhJOpPHQGC9Vgmc/pbz0nd1k4nazHiG0Xd9cJnIsJ l94hl9sJnhTSkE+j
mjjheVLRmkqGCrE5m+1JDbXZmatHgvOZhebXeuH5mYdJmi22n/jp/5/KAX0V UZ4AVZORmY84SYEW
oaCCGJ2wQA3PqTXR6Sroh370iZ1sd5//WZjtJyX9iWMa+p9EmUQDWiFImSFK mWeveRHuOZvONqFX
WH4W6nMZCqJzSZWCBoE1ip/CySokaoTlgpzbh6DKc2fN+ZwEJaGJSKExWoL1 WZ8lqKNt2Z0v5p1R
Cpx26TB4STV6iRwoimfr6Z5YQg06J21wx4itd53WuYjWaaVRqZ+j2abA2Zht QaISdxcGepMrdpY5
0QfCQlD70p59+qL/dJtxSpeh6X5waqimiZqvoaVywZpe2mSiQA3bUKmXaqlk inCEuqilqZtV+WK+
2amKyaPR12LGOf+WmFaWQzo1Zod2rpp2Zzeqs5olPslqVbpiuEqrdDmeUVOn Eekgkrqrw+pn+qmK
qXhuq5isyIp8zFqKqGiKztpuAeqK/PkPBaqqksmqFLIMp8AMp9Ct30pk0tYP KFCu52qu6Yqu66qu
7cqu7+qu8Qqv8yqv9Uqv8EqsL8ah7KGo+eqWInpEJBqp2cpkULls4woX96AC MLCwDcuwD+uwEQux
EyuxFUuxF2uxGYuxG6uxFXsP/tpiN2p0OQqybVmqAiqXnoSnybmtE8JscbFp L2uCVAADVQADNGuz
OHuzNbuzOcuzOgu0Pyu0Pku0PWu0QVu0SHu0Q7u0SVuzhVqycTH/pd8ZtUKJ pf30q8gmrEp2Z02w
kU1QIdPwrXDRDx3LsWdrtmmLthz7D2qbth9btcrzpokZtzs5p0hBnFNjpxWx skKqp8ojs3JRmyhA
swxbuCpwuIkbEoi7uIpruI0LuY8ruYj7D5PruIwLA//guJobuZirApVruZEL tXU7mxAnmnRLuhXZ
qIslsCaankh2ZzEAEjdQDbNLmwnrtmubuxnbtrrLsL0bscDruxkLt6nbL2Vl jqFqvDp5stWaq8O4
dX3LhJu0pzfxstERFwbbdlSQEzyLEzf7DzZbuSKItJobvpl7E+D7veKbvtxL vjgBtOFrvuuLE+x7
EzS7vuhbuePb/705gbOjW7dTe6rLa5G9enKvaDVbm2SxewOySw0NfAPvibvA 27YU/LkLW7kXTLHp
q8EXbMEfnMHC27Ac/MEjbMIl/LD7m8KZu8Iq0A8EHBdza60wzI8xqRB5C5HY OiHTu0QL6sOCiApa
Qh3Q0Z7aS7igK4L6exNJbL6Za7OSe75KLL+Gu79P3MQ1m8GFi8VUHBJMXLhR PL/fm74hsb+Mq8K/
GxIAHLf7ipgzTMP6CLB8l6NOpMBI1geWaqk+gAMXYakuihMKi8In7MEVa8EQ G8gVbMIbnMiD/LuC
vMEqnMEsHMkZXLxvLLKiukmY/Ma+2Lw4TCE/GitBysM1hgrRof8lPuAD1aAI YJCka+e+4Eu+WIy/
O1u55YuznPu+OSu/t/zKvczCvXy+7ovLwwzMPgvJtMzC4vu0mwyYtpp3urpJ 0MzMkHi1xPaKWkuw
S3bHuTAO1KDH2/AFYDCmZNvBvfu9GNzCipzCJHzO+tvI64zO5dzON4HBOFHP IUzPLPy5YtzClUzD
MrxiHjrNkHi3cfSrkJnNLFtk60kO3bANOJDKYAAG2yCoBne5F925GM3FnqvR HN24WZzRIR26j9u2
jqvGVYuoHdqvA92Lq3vAvem6dXxkd3yp1YCp46yWu2vIcMG2Os27Ps22+eyx 0/yp0KeVXXnUWMmV
So3US6059Dj/wAAjykd2dlUNq65KcEqr1Uy71U7r1U0L1l0d1lxN1lVw0lEr wM/L0r5owJuHwJ8n
06Z2Dygw1+U613edrnhd13TN13ut13nd14CN13Yd2IQ92IHt14WN2ILN14bd 2NMM0B+61r1owwnh
yVuqw15HY1U42VHKxgIdnJ0NiXH8gDBNxwltY5wt2iB6ycq72lzYyT4qlv4w 1UukaZwWF6r92v6Z
1lm321tYzQ+RtQIV11MTuIH7D7r92+AZ2QS23ClY0Eb1mD6WrfYGF/imb5LD b8yQHJOR3FZ41mf9
3I6Y0vyKuuMNey7t1qb9WF4aiKMnc2Ei32TyD6D23WW6SeKN/95aWNQjC9P7 nX6xLZdSHZlKmHCj
HHYzJ3beUQ1bsAWwAN5neqZXqJ0A/ou9Hc0WHntt7SC/msDZ6nIJF4ild3qm 98KbWqFNquIaPo7N
HdosbneVbaoBfa3UnY/Xt33alxx/0H3g533i933kt6ZpyqQw7oufvdJGHnSk 3eFz3N4gzqSBeIFP
yIEeuFwgGAu8qIhFzqT6reSv19ok++VBJ+ADrLLVzaSj7IQaKIVtrtz22eVb DqVjTt7O/IVUS+cN
F9xNbq3YnBPvbYGFGFaipOUxKuGsZ+henudAZ6zS6ujRCunQKunHGumUPunL Ool0Ot3UV920GBe2
GAu6GOqEvv/oG2q6iXrepW5t6s3nKzawMcaN3+iN2qjqhNnfmqw8uF7rqFbm z0vgqD3Kux6eGB6W
wn5tHP6ocXGeBlbcxu6fLt6Hzl5tMo6y1prZq+piQoaw0r6TSJ7q3O5nTJ7s R3nac1Zn2gvu/Bjm
/53uptbrvn3mO7xJt91pnxZq8Nnu4kjsxZnv7r5mWTrcf9jsFHLc0QZtfrxk it7vSQbtervwpBbd
zvuhCF1vnp4T2L1v/fZvAYfuSKbwD29k5d3GNA7yfMbq476aMQ3lcQHff0Bz M2dzOKepCV/yp3br
rl3zefbuGf7rB6qtS7jgZHfV0nbo56emZjrkOV9q+05pSp//Z8ju4XC98i8n FyRu4qlngjAa50s6
n07PZw0PkV7PZNQu8TRp49a3Ojmu9jzeDz7+4+NngkP+pFwP510v9nnm7W58 90gm7q1b7i1XgYOI
gRpY5R8YgkQ/53NO906693p2yU4N+U0t+UxN+UnNg18p2/Gepz7fhE/Y5lO4 DW+u9XXf9Yyf4o3f
hXb+j3iO+kC25yhvnlwqkVP/54FuiFdV6GZq9Lt/oaWP9K3fZGCfl8BfZBF/ 2Z03jJxe8aRVi7eY
i6RO/Cko8qAd7dFvYyfv908O69/Yjd9o/Sl482L+/TO282HZ8+PvlkzvKtKM /i0G9W+NngPf/i2O
vLT37fOP/1RVecO/eu00Vr34DxD/BA4kWNDgQYQJFRqsFisVNYgPqS1EOJHi RYwZNW7k2NHjR5Ah
RSr0R+0hPojUSqaawnHaP4jTUk5LBSvWSI3LQunkGQrnT6BBhQ4lWtRoQZt+ qMlU+tLlUahRpU6l
6hGi0pgp/bTc6A+mSmoo/flp+NPPxVMG76Wt2tbtW7hxKTZ8uFJlR69y9e7l yzdiWLARuWqcKDNl
RJtVl1UbyJiZNJ99JU+mXPlgUq0QO1q03Nnz54tMDy+ltpXjRJQQU5O9ifMs xbSqYBlS9e8eM3ts
caKgyBv0b+Bxq8GSaFLz6eDJlU9GeTJl88EZX2aNWbP11P9TjCdq/1dNt1Tf y8WP/6kqVtPSSzs6
Jd/efdGrM7VGx+hVbMqxZV2j/QermmwA/4ksIRQK9I23AwsUSMF/DBzIQQff k3BChOgCqy68KNRw
w42aww8wlpA7zDDrqkJlu+5SpOa7g8JD8MAHF2wwxvBm5PDG9zCLbzTSeDRs tB9H5LFHIIcMUj4f
jVQySSaLbFLIJ5F0ckooqZSySiyv1JI6K7nM0kst0TvMtI0mKkm1q/Qb6Sw2 /2nzNQH7owZAVQqJ
UyEXbdQTRgMVrLFGHANVzsK/OCNMUERxtCu1C+kL7asfaUqMquxgUrE7VBbK M08ZZwT0z0RD/Q0z
0djTyFT/UVMdb0ciydTIK4hKEou1qnzyD0BYahuwIBhl5NRGBGkkCFBVi9XL Qrvy6spYZpP76z7B
kDvSpEmnOlHFbbQTBaEEGfyTQWDBjRDcZsulSsf0DM1IXXPb7Us0IV1d9x9G V1NTqj7+obM2xvLF
UyNi3RX4reGKk2izgRPWy8N6TXKUoumIlPQ6qUShZpuLM8Z4238xClhhkKEy D72m1gv5ZKpY/VHe
+ugNTCVaqfIDlT5Qmbnmm1HWOThkjVP21Z2DJsrDWEF8eKGJoCxRaKZ3Rhcr hJuWOqT4jmT5IjOf
S5Piqbtul1Dj2MXaa7JfNY7RlY5WKOJIly777WJJTQ9V/4zohvtugVSejyNY wZr1XrwDv7FnDPkW
/PBnXw6xzH+mdftwyCd8+jjGI78bXvmupgg1rUsD3HLQlys4pYORC71shrVe /FRIZ3r8dNh/G5k0
MSWWMtLbc+cS9911t7134H8XnvfhfSf+eOOTDx755ZUvvnnohceqVbUTsu/l /LiOfXvLCL/LcO6l
Jtpvh0VE8vXw0+drcrE3V5/pqkfTHOl/zgTMc+3f198tsEuvfH+ULepDq5NO 66pTLQAm8FznoZ16
nqLAkOntKtVDSN9kBbPPQVCDQ/HezzLiwQ22K3H2IyBGCsMj9IVQhSNhX9RW 2C7MZWV+CuEcmvD3
QhyOZP90hXJhDpmVOjSV8FG7S6EPjUiR2ZXKZEc0lgRLQ8GDXM9+2WNiFS/S wQxZMVXju6AQ3ac0
BGpRjANpoenGiKj4jQmKBsmaDWN2xjP2j3KHgqOgBFg0Ly6Eba4LYx2rKLeS PdCPN3LiDK33lQtS
cZBaxCL4FrmhEZJujQU54WiK+MgXso9IX9rkljoJJlB+UpTTGuWSulTKKIWS lKs0JSdZmUpUnvKV
slTS9GQ4SYLU8H5vxKQRdxi2HvbyPUA02lOI2EdhrjCJc1tiMt9TSFwORIr4 4aUzV9jIZVnTPVws
JuPAmD9tQrCM/wuneNK4N8bZz17gLCcA5dg++rVTPHf/bJQxJXZJeb4PkA7c iN3y+RloGq5of2Pn
P9OHTaAZNDiRjBbjHIdMhaZvnHSMKGhiSLto5s1lbsxgRbn3S/9R1KOdISZ0 7Nk2iI4UdssMZD9V
6pmALgtaGCzoSy2H0A/a1DLcNKk3z5dSnUZuovMK6mTOOUHkqHNrRd3eO4PJ VLnQM20n5WNNoXq3
fTLveVvValed59XogZWrXyVrWMs6VrOmFa2tkpIhK4hIwCjyqqDDacvmqheG ls+hKATqXd82VBP6
VS4XZUpGLdWwGwoWciCdI1EV65aS6pV1x7TqY6XGUn6yzrJtiSnQZirXzcKt rhcBYWiPwlPJzuub
psUq/wN39FTWwmdu8jNsG3fZ0dgyzalmzK1RpJrauhlwKfjsrc6y2sziEqWz OR0oTZPbtdFSpLTP
xUle80jDxvG1stQdGGDHxl2hEPaJyEFsNcGLMsbCE7vnBUpkr5uQPR5wu+wt F2b9qUf6/mS5Lfus
efObsOguZLr/7VDYyPfeinyFOsQlcLM06cpWenKWEIblhCUcYVViOJYUpmWF NWzhDHs4SrVDajo7
598Gf80hpGtsYFP8kd8i+CDxHW5fXxw3BipRkDcuU7qoJ1DygZbH5gowSYZ8 mrMprrbZtaSNj5wo
77rvydLx8S3Je2LcTjlU6YWtlg/iXsPSeGJebpZ9kf9L5or4eGWGnWasUIxm QRX5kHBOCGplzEYF
94jBdNZQlOPJZzbOVo1JxfJ8Ae2e3ZLz0AKJcZiFO+ZFI+q4O470fkkLV4JG GlFyfqum85ZkEi75
oYb2tHL8vF5Pi9etB9HlOkuNIy7zNtJgpqp8X30j+55VrLvWda/Vyutf+3qt wB62sIk9vTUbrr9Z
vvV4OB3FV9t5yattdp9dm64u8/mo4zUxR0ld7c8kWqSRbnSta/xtcHdm0i4t taWli2nnpltCzzbI
gOlsXVFrV94SOnVC1AtnVS+5vMze929irehF09qllC24e8xM6UW7W8Aum+Kb G27wFScri56WtvkW
7OT/i1um3wlut6DReSilJjbkolsxD2W96HIv/J4gX/lk1q1ZT0vcyM0Vcs0x XhefbVzT+JaWvn2e
HE2CeMMXFnGHnc5hqDP96VKPeoinbvWql9KWGL2yt4+enIOPO+FJDqKjGf51 4Dyc3TlX88lzumx0
o51/GQ+6IzXdcZ9+PO5yr8rIWf3qba8azym3ON/5Im7Hajrmk5353g0vlZsX sOTIdnvLeF74x8uF
3gWxN5yJvtcmOz7zR/E7nksd8K7fVvSjL0rYEz9rsneT8ShdPeuHonacD73t JfYs9jBv+7ZsniCd
RzPeD0Vt4Pel9JQEvMl5Py/CEzz5VEG8iz29+AKe/336e8mqsb0fbPAXO/zE Jv/3xX/+8nOJ8s+3
fJB/v/2oCF+azXdOqIseevhz/9pQe/mhUc+4gau9/AsJ17O+u4u9npq9qhpA ucA9yWO79eO23qs4
6WPA1qO7wskmjjOwLpq2nxJAC+yI5cul5iMxCYS+QgtBgmk5YOo/QMO+4NI+ FVwgksmsB9S9CBQ8
zoO3nptBqJA/RqO/uJKk+zuMPfNBoBjBgfg3NPu/QwlAJKQ+4mAxJvy7UlM4 BbS1KJQKBwyuyWsr
NqM4aqrALRQJIKyfaONA2VOtDyzDqHgwqotDrJPDpZtDO6xDPFQ6PfwwPmy6 rLMwE9RBEow+EHTD
hP+ovu+6vtibKpmjPUMkvRxjJog7NJ07pMsjw0fsiDMkPjL7vEMZtUwsCiXU qNOrMq4DwBQMRQ6a
QpdDuEPDwuxrPFW8vUhsqdyrtN07Qf7yPUycRYzYxDQsjg70OD2jOV/EiFG0 lC+0miUjxGMECkSU
MkV0DjwyO1l8RpyIPC+EQDAEskR6P2ycCwz8Hg3UvfojQtAzQmMMx4RIxir0 MiecFyhkRwJkxRZ0
RUCDxRi8Rnr8iFwbP/NLP/QLSIIESIMcyIMUqxwMQ7jrR5AAxitUwwRkQ71z yI9wxxLsJEFcwvpJ
RYvkiGj8M8VbROAaIn78SI3Qxkf5QvULw0ssxGP/hEi2O8eG+kSjQ8mU3L8W S0RNi8fAmkeczIgC
5EnYo8Y13EdHDMqM6MKV5MaWVDZehElflMkDFMajHBvkU0qKwMhlpC1C8zqt vCIWDKnXgzmSvLOC
ELMj1EqVhJiMfMplecmwFEugy8CEmskhrMl5AcW5XIik68Ory0PA/MPBpMM9 9EPDLMw7PExa2rrC
Sj1X60uFGEpprMr7uUq3lEHJNAimdEuW/DGZisrNPMRx5MR6C8YPmcjAysrR JAiu5EZm/ErVa82D
CElUG0mjZMQsPDfaNIi2xK/PTLa4dL9exEmqxEWaLEn34cveJCOdfEfmK0XH 1MWxAcrm7A57JEsD
/yzKy1RNk0zK69SXWrTBbcTBbgxNCpTKWTzOsbNK7/yiNgzP/njObLs356NO 93FG+bRNf3s1GPzO
BZTP7kvIgkRIAxVIBC3QBCXQg1xIb4wrcFRK9qREUENHm8Q/AaVPF+Qzn6xO j7xOyhRJ7mwYtCQI
tVxHnOxM4HRK0JzAMVRPVZzQfJRI5aQf1uzN1zTP2Oy22dzPsdzJyiS3s7RG 8LzO31ybt2xR5iJO
GA1FGdW2CtXLwGJOI9VQfORQU3xMVATL8AzR2xxR1SHSAA1PFUXS4Ky8S2tI H61LcrxLy2yuEuXI
G6VNOFxMxRRMxLTTPMXTwGRMwtxTP43DQGzGD/9tznd6GbTRGqVIOUT9EBtq 1KJ5VEad1M6BVEul
VEl9jikwk8OyFFihF0/tVE5FjVAl1VEF1VPFh1JFVTQ01VZl1U9V1VRdVVl9 1VqNVVr11EpNuSn4
z8w8yebsvotgCegMFdNIGktBVmVNVmZdVmdtVmh9VmmNVmqdVmutVmxNmirc ikp8K7lc0wsBC5hI
pNT0A6UY17wMstTEnnQlV55b1ylqV3n9rHllV5b4VPt41XzFV1DlV1X1V33t 11D914ENWILl1INF
w4Td14IFWIdtWF2lV+jwxL28ySqdnunJsyshVo3V0z6900B9ymsd2WwtWZI9 WZNNWZRV1ojJkq3/
6FD3sU5Dzc6UULDUQIF6MVdt7c5KRSyefVSfDdqeHVqgJdqfvUyOrVWlFVVW XVpXddqmZVqonVqp
rdqntdqovVqtRVXAQAGeZQl9BFAtJNPxlAmY+JECWbBNPVsFbVsG5bqVVVm5 jVu6nVu7VdZKooa0
pZ5uhTY17dLSTJozMRBo0Vl0fVfEVdfEdVfFbVzGfdx6jdf7uFeBRViDvdyH tdzMVVjMhVjN9VzO
3VyG/VzNTQkDUTLjo8hibNJM1CQF65MR4djEBFSQrV0eOda7zd263V3d7V3N yArYxajAI1QuBdEf
/V3VMBB1Mtxdbd5Mfd7LxNTodd7phd5EhV6O/8XVWd1eW81V7tXe7v1epgVf 8h1f83XV8kWT0y07
X8UvzcTRsk0atPVaPVvbA3Xb+20e3OVd/vVd/+1fac3bvV2zvj3NbwVcNi0J dBUL+pUV5oVciWXX
CJZcCa5gCr5geM3gahTdyg1d0B1dDybdEB5hEC7hDjbhhT3hE+7adSXWKK1R 7KLSYH3OncUS2aVd
HP7YHN7f/+1hAPbhu23ZMJkCmKUfme3N9NrZoGXeom3ioxVaJ4biJzZaKfbZ pMVaqt3aLM5aLt5i
L8ZiMNZiq51isEVAGIavR1tLpcw1tgUe2V3Q/I1jr+LhH65jILbjk81b4uHW XNzIIPxb401gk//w
g1QgZEMuZETW2URe5ENuZEZ+ZEeOZEieZEmuZEq+ZELuVRVOYU7uXBFGYU8m 4U0OZVDmYHyw5EOe
gtRdzfgMT/aZAliOZVmeZVquZVu+ZVzOZV3eZV7m5Tv+ZTwG5mjt5U29Tz/W VW8bjoZY5lhQ5mZ+
Zmdm5miGZv+A5mauZmnGZmqW5mvm5mleZm0GZ28O52625m8u52weZ3U2Z3I+ Z3duZ3he53RmZ3ne
Znq+53nOZ3vWZ3HG533+534+VOm93uotaII+aEc16IRG6EhV6IZm6EulXoge 6IWu6Ie26Ii2Xoym
6Ivu6HBN1DgViBONBfOwCZMm6Vg4aZso6ZT/bmmWPumXdumWhumZlmmVRumb jumVrumdzmmexuma
1mmgpmmfLuqg/mmhTmqkXmqjJuqjbmqbfmqpdmqqjuqq7umptmqtxuoBlWP8 hWOw/mqxftuwDh4H
Hc5vxGS1RuW1bmu2fmu3jmu4nmu5rmu6vmu7zmu83mu9fuQL4WvA7uvAHmzB LmzCPmzDTmxLTteQ
tpSQ5dM/1WHJjmzKnt3JtuzK9tjMhmzM7mzN9mzO/mzRDm3SfmzT5sNjbjUq Xu0oZu0pbm3Yfm3Z
rmLXpu3Ytu3Zrm3dvu3dzm3e/m3fDm7cHu7eJm7gNm7hLm7lPu7lTm7mfm7M dN/fUey+Juux//Zq
685u7N7usubu3DmL7g7v6xZv7SZv7zZrhrRXC9Zgx43cDAa6CWZvCF7vxXXv +o7v+6bv9sbv/dbv
+cbg/Abw/hbw/5Zv+x7w9+5I/i7wADfwBT9wBkfwBp9wCa/wCL9wCM/w97TR 89ls0y4O0D7tHPZw
273s0RZxEy/tEh+TjkVxEh/xEF/xGIfxEy/M1O5IN2LU4phoid7o58AKjs5o hxZyHtdojw5yJO/x
I1dyIvdxI2/yJX/yJJdyJpfeVIArKs/yIZ/yLa9yL9fyIu9yMHdyMS/zMAdp Ma0OImoJ8+adVGjz
8Y7z8pbz865z8QZvOofzOd9zO89z5zlmC/+C0HdlNA3373n1AwIv9ER/cEY3 9EZfdEePdEifdAeX
9EqndArHcHq9cky3cEW/dFDP9E8X9UcPdU8vdVJXsiIkHRfHbImYlr3tMPqt cRrH01lX8VpvdVpP
cV2PpbPY9RfndRkH9hkX9lyvJYE7MStubuQ+5aL1WpSA9p6l35ttdmaf9t/G 2c7RdieedWuH7m93
bnEPd3Lv7SsH92tHd3Uf93Rn93Uv93cPU3OjiTVnsj43CeKZdeZBgUihXz1/ Hn7/Kn+fiYHn838/
eD8HSDw3+IS/d4dHeIZnvzT1PXol9FTHdERP19P1Wo4Pi40vkGiHCNgtidPF BxQgeZXQ9in/wtmT
19u0NfnTJfm9PXmW31tZoXmXT1t/UN6cp9+Yz3m9TfmPt/lRP3VLv3hT1/Sj N/qVUPClV/pOh/qk
L3qpR3qrZ/qpj+DGrmESCfY/BHHgNV2XF3mCPwyvnYZZ53jD6Pigb3vqmPm1 b3u0d3t+n3kvSdu5
J/uAp/u8D/q993vSYHu39/piJ3xiP/zSaPFhx3Vjb3zDZ/zHD9QbJzwd/3Iz X2gg1xqvRfm0p/YG
DnqTjxWO75Od19vQb3kbQv0+wXmP19vBDf2Ul1TPF33TF/nXX/2x13sWTnsy P/Pe//0ov/zg9/3h
B37FwXLhh3Ll53LiX37Lb37mN/7oL37q/6+nRnSdeof4N5cS3j9701V7sdfb tc/78Vf7gl8Kfy/4
va/7mAB/8UeS9S//9p//v1/7ju/+wH/4hod47154/Y94gKA2jRrBgQUJCkRo MOHBhgwfLoyocKJD
iRUpQsRoMePFjhw/bgyJ0M+UfyZPokx50t8/gv6o4aPmz49LmDKpmXwZ82XN nQh13uwZ9KbPnn54
EqWGAuHSpUj9ocCHAulSqTynRpW5VKnNrUmhuswKdipMrGGtEiQbc6taskqh 7twK161ark27cn3p
9KfNp335Fv0KeChQv4ELDzZM+K9QxY4TQ24cWbDkmqn+Pa5MeTNizZ05MwZ9 OPTn0qRPj/9OvVh1
ZtGrX7c2zXpyqpIqb6PEuRBhqt0YET4E7tuhcOC/UxHnOvBuWhRenU97XpCt 84TSh6NY6Hxp9O1M
q3O1zlbgc+/Nm4M3rx498/DBf8NPLv/9/OH079vPb7z+fvz99e8HIDV+tORf gP8heKCCxglY3IIO
MphghA/GZ+CEF0KYYYUNbiihhvyRhJuILf0TE0Em+mGiTQQhdyJCKsL4oowu 0riijfjQdOOMOtYo
VY87xvijkGUNGSSPRB5ppJIyVgWkk0U+mWSUS0JZpZRWUnmlllmqeBmWU4L5 pZhbhknmmFyWieaZ
abK5pou1jYjbNAVG1GKdJYnkUZ4gsbj/p59p/dnRduZxlJ1GhwoaKJ/TQYfo oo8qGqmjkuo5qaWV
YgrpgP9QqmmmnYJ6qaejhvqpqKWSeipGIcapEkuHpbhYTpPJBltkR6Fmq2e5 xsYrrb7uOluwurrW
q7DF/npsrcYSu2yytl7m7LDMUvtstdNamy222yLLrbTdugZnqynh5GCL/FGI LoYKndthuhZ+CK+7
66obL4f1zmuvh/nyi6+/8v5776bvClzwvgEfDLDCBhOcMMP0LuzwvqyOexJO SKGIMV81alwTxzt2
PBSOHtsYsskgo/yxyiWnzPLKKp788sYu0wxzyzbLTDLONc+8s889A61z0CIP HTPPJHtJ/7TQSyvd
tNE/M/100TdPnbPTVEeN9dVWS50119SIW7FJc1Zkp6qmot3b2amizbbbqMK9 dtxtz/223HcfRGDd
e+NtN9198/234H4/SrHYLDWW47eLA0sUrt42zriykVM+ueXNVo755deCK7nm n/carbadZ86556aX
PvrpqqcO+bFhi62bxA3TDvHD+taOu+2z7557vxH7jnDwwPdevO7H/3578rwj L7zxyw+vvPP6Gl4x
TmqamT3227epfffcu+l9+OCLXz7553+f/vjqm88++uvD337878tvE+wVT5OK H/rzv7///QPwfwIM
IAEHaMACIvCACkwgAxfowAZC8IESjGogBSdowQpi8IIazCAHN+jBDoLwgyIM IQlHaMISotCDthHb
P0jiwim8MIYwnKEMa0jDG9owhzjcoQ57yMMf+jCIQByiEItIxCMaMYlIXKIS m8jEJzoxilCcohSr
SMUrWjGLWNyiFFlokoAAADs=
------=_NextPart_000_0089_01C628E1.3A9713D0--
Re: "A data view is not available" [message #124346 is a reply to message #124264] Fri, 03 February 2006 19:46 Go to previous messageGo to next message
Chris,
I haven't seen this type of problem. I would check the Error view to see if
you have any useful information there. Does the report file appear on your
file system?
To open the Error view, select Window--Show View--Other. In PDE Runtime,
select Error log.
Also, just for kicks, you can try resetting your pespective. Select
Window--Reset Perspective.
The only time I have really weird problems like this is when I have a bad
installation, or when I start Eclipse after making changes to the
installation but do not use the -clean option. In times like these I get a
hybrid of dysfunction.
I wonder if anyone else has any suggestions.
Re: "A data view is not available" [message #794880 is a reply to message #123104] Thu, 09 February 2012 15:27 Go to previous message
Hi all, I just had a similar problem after installing Eclipse 3.6.2 and was integrating eclipse with Tririga.
I first created a new project and imported a starter report (from Form (Tririga)).
Then I only saw 'A data view is not available'
To solve it went to the menu > Window
Open Perspective > choose 'Other'
Select 'Resource (default)'
This different perspective showed several different windows and I was able to drag & drop the .rptdesign file to the main design window.
When I change Perspectives back to 'Report Design' I see the data sources now.
Good Luck, Mark
Previous Topic:How to dynamically generate column heading and avoid outof memeory issue
Next Topic:Local file images in PDF report fails
Current Time: Thu Nov 06 07:03:51 EST 2025
Powered by FUDForum. Page generated in 0.06091 seconds
