Re: Bookmarks automatically generated in PDF [message #123312 is a reply to message #123141] |
Thu, 02 February 2006 19:28 |
No real name Messages: 87 Registered: July 2009 |
Member |
As you've discovered, BIRT automatically generates bookmarks or table of
contents values for group values. You can change the values displayed by
going into the group editor and specifying a different expression for the
TOC Item Expression field. Unfortunately, you can't delete the value
specified here so the TOC always displays them (you should file a bug
requesting the ability to delete this value.)
You can specify TOC expressions for other report elements, such as a text
element that displays a section heading. Select the element, then in
Property Editor, specify an expression for the Table of Contents property.
-Diana
"floor" <floorflux@hotmail.com> wrote in message
news:drt93f$ote$1@utils.eclipse.org...
> "Frederic Ferrant" <frederic@ferrant.be> wrote in message
> news:t914u1lqulndpr713ajfqf2o7595i6mkuv@4ax.com...
> > Helo.
> > We work with BIRT 1.0 to generate PDF reports.
> > Our rptdesign files generaly contain many scripted datasets (~50), and
> > are divided in main sections (9) which are divided in subsections
> > (almost one subsection per dataset).
> > I am tying to get this running with BIRT 2.0, fine work
> > Unfortunately, the PDF generated now contains bookmarks which have
> > automatically been created for the the tables where a grouping is
> > done, which I don't need...
> > So, I have two questions:
> > 1. How can I disable this automatic bookmark generation?
> > 2. How can I manually specify other bookmarks (any
> > documentationavailable) pointing to the main sections headings, and
> > how can I name these sections (localization is necessary, I work in
> > Belgium...)?
> I would also like to see how to control the bookmark generation for the
pdf
> format. That is an awesome feature! Documentation would be great, but at
> least a simple description would help me get started.
> --floor
Re: Bookmarks automatically generated in PDF [message #124172 is a reply to message #123582] |
Fri, 03 February 2006 20:34 |
Member |
I don't know the answer to the first question. My guess is that you cannot
localize TOC values. I suggest you submit an enhancement if you want this
functionality.
Bookmarks are for creating hyperlinks between two report elements.
Basically, there are two steps to create such a hyperlink. (1) Select the
target report element and use bookmark to identify it. (2) Select the
source report element, choose the Hyperlink property and specify the
bookmark of the target report element.
Table of contents is for specifying values for the Table of contents that
appears in the Web Viewer. In a PDF report, the table of contents appears as
PDF bookmarks (which has nothing to do with the Bookmark property in
Property Editor).
Does this clear things up?
-Diana
news:6b46u157a27ictpm83590na9gpjd3i5md4@4ax.com...
> Thank you for the answer.
> I still have a question: how do I specify a link to a label in a
> 'properties' file using the Expression Builder? I need to display a
> different bookmark label for each language...
> The labels are linked to the properties files using 'localization',
> but this isn't possible for 'Table Of Contents' entries... Can I use
> the value of a selected label in the Expression Builder? Or is there
> another way to do this?
> Can you help me?
> Another question: what's he difference between 'Bookmarks' and 'Table
> of Content' in the Properties editor...?
> On Thu, 2 Feb 2006 11:28:11 -0800, "Diana Peh" <diana.peh@actuate.com>
property.
> >-Diana
FUDForum. Page generated in 0.03869 seconds
