Home » Modeling » M2T (model-to-text transformation) » [xpand.support.cdt] DefaultCodeFormatterOptions not found(DefaultCodeFormatterOptions has been moved in V 5.4 (Juno))
[xpand.support.cdt] DefaultCodeFormatterOptions not found [message #916064] Tue, 18 September 2012 09:25 Go to next message
Hi all,
I have made an update to Juno. Everything seems to work fine, but I'm not able to run the CppBeautifier any longer. It seems like the DefaultCodeFormatterOptions class has been moved from org.eclipse.cdt.internal to org.eclipse.core.
Is anyone aware of that? Is there a (simple) workaround, or does this need to be adapted within the support.cdt?
br, Joerg
Re: [xpand.support.cdt] DefaultCodeFormatterOptions not found [message #916185 is a reply to message #916064] Tue, 18 September 2012 13:07 Go to previous message
what about filing a bug and as a workaround copy und paste/fix the code to your own formatter?
~Christian
Previous Topic:[JET]
Next Topic:[Xpand] How to use local variable in a template
Current Time: Sun Oct 26 17:45:40 EDT 2025
Powered by FUDForum. Page generated in 0.04064 seconds
