Re: [CDO/OCL] Bug in error handling causes misleading LegacyModeNotEnabledException [message #915862 is a reply to message #915628] |
Tue, 18 September 2012 05:18 |
Am 17.09.2012 18:58, schrieb Warwick Burrows:
> Hi CDO team,
> I ran into a problem where my previously working model was getting a "Legacy mode is not enabled" message like the
> following:
> Caused by: org.eclipse.emf.cdo.util.LegacyModeNotEnabledException: Legacy mode is not enabled
> at org.eclipse.emf.spi.cdo.FSMUtil.adapt(FSMUtil.java:101)
> at org.eclipse.emf.cdo.server.ocl.OCLQueryHandler.getRevision(OCLQueryHandler.java:204)
> at org.eclipse.emf.cdo.server.ocl.OCLQueryHandler.addResult(OCLQueryHandler.java:195)
> at org.eclipse.emf.cdo.server.ocl.OCLQueryHandler.executeQuery(OCLQueryHandler.java:175)
> ... 7 more
> I found that the problem was not due to problems with my objects but due to the mishandling of an error object coming
> back from an OCL call which was being passed on for further processing as a model object. Here is the code I believe
> to be in error:
> Object result = evaluate(query, object);
> if (result instanceof Collection<?>)
> for (Object element : (Collection<?>)result)
> if (!addResult(element, context, view))
> break;
> else
> addResult(result, context, view);
> The result coming back from evaluate() is an OclInvalid object -- signifying that the evaluation failed -- and since
> the object isn't an instance of a collection it is passed to the addResult() method. FSMUtil then tries to adapt the
> object in order to get its revision history which fails with the LegacyModeNotEnabled exception since OclInvalid isnt
> in the model. Ideally the code should be checking for any of the OclStandardLibrary error objects and returning the
> error information to the caller.
> Should I open a bugzilla defect for this?
Strange that this didn't pop up earlier. Yes, please submit a bugzilla against EMF/cdo.core.
Cheers
/Eike
http://www.esc-net.de
Cheers
/Eike
Re: [CDO/OCL] Bug in error handling causes misleading LegacyModeNotEnabledException [message #915932 is a reply to message #915862] |
Tue, 18 September 2012 08:36 |
Ed Willink Messages: 7670 Registered: July 2009 |
Hi Eike
This seems remarkably adjacent to existing issues.
From an OCL perspective it is not clear that the OclInvalid result is
not a 'valid' result that should propagate back to the caller. Certainly
invalid is a defined OCL result.
This issue may have further ramifications if/when OCL acquires a
constructor syntax that supports object creation; such objects would
also not be in the model.
And on further reflection an OCL query involving Collection.product may
return a Tuple which is also an object that is not in the model.
So I think the problem is to do with passing OCL returns back to the
caller rather than with the OCL returns themselves.
Ed Willink
>> Hi CDO team,
>> "Legacy mode is not enabled" message like the following:
>> at
>> at
>> at
>> ... 7 more
>> due to the mishandling of an error object coming back from an OCL
>> object. Here is the code I believe to be in error:
>> break;
>> else
>> signifying that the evaluation failed -- and since the object isn't
>> FSMUtil then tries to adapt the object in order to get its revision
>> OclInvalid isnt in the model. Ideally the code should be checking for
>> any of the OclStandardLibrary error objects and returning the error
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
FUDForum. Page generated in 0.04057 seconds
