Re: Going from Galileo to Juno [message #915317 is a reply to message #915123] |
Mon, 17 September 2012 03:35 |
On 09/16/2012 08:24 AM, Richard Mittleman wrote:
> I am on a Mac.
> The java source is in Macintosh HD/Users/zscipio/workspace.
> The Galileo version, Eclipse.app, is in Macintosh HD/eclipse 2.
> The Juno version, eclipse-jee-juno-macosx-cocoa-x86_64.tar was
> downloaded to
> Macintosh HD/Users/zscipio/Downloads.
> The .tar file was unzipped to Macintosh
> HD/images/eclipse-jee-juno-macosx-cocoa-x86_64
> I can't figure out what to do next. Can anyone help.
> Thank you.
Everything should be fine. Once unzipped, you can launch Juno and simply
navigate to open your old workspace. Normally, there should be no problem.
Once you've opened and/or worked in your old workspace with Juno,
there's a chance you will not be able to use it again from Galileo. This
shouldn't be a problem since you'll be using Juno from now on, but you
should know in case you have thoughts about going back.
However, the projects and source code inside the workspace can still be
turned into workable projects in Galileo if necessary. The point is,
nothing terribly destructive will happen.
Best of luck.
FUDForum. Page generated in 0.08479 seconds
