Home » Modeling » GMF (Graphical Modeling Framework) » reusing a GMF-generated editor as a viewer
reusing a GMF-generated editor as a viewer [message #122464] Sat, 28 April 2007 18:21 Go to next message
Originally posted by: chaves.inf.ufsc.nospam.br
The UML2tools has a GMF-based editor for the UML class diagram. I want
to create a model viewer (an read-only with no toolbars, no need for
persisting diagrams) by reusing it.
How can I do that?
I thought I could just create a Diagram using the ViewService:
diagram = ViewService.createDiagram(
package_,
PackageEditPart.MODEL_ID,
UMLDiagramEditorPlugin.DIAGRAM_PREFERENCES_HINT);
And then from the createPartControl method in my editor, I would do the
following:
viewer = new DiagramGraphicalViewer();
viewer.createControl(parent);
viewer.setEditPartFactory(new UMLEditPartFactory());
viewer.setContents(diagram);
The problem is that the above explodes with a NPE deep in GEF code. I am
not familiar enough with GMF or GEF to understand what can be causing
that. I included the NPE below in case anyone here can figure it out.
The NPE happens on the second line of the following method in
GraphicalViewerImpl:
public void registerAccessibleEditPart(AccessibleEditPart acc) {
Assert.isNotNull(acc);
getEventDispatcher().putAccessible(acc);
Thanks for any clues,
Rafael
org.eclipse.gef.ui.parts.GraphicalViewerImpl.registerAccessi bleEditPart(GraphicalViewerImpl.java:273)
org.eclipse.gef.editparts.AbstractEditPart.registerAccessibi lity(AbstractEditPart.java:768)
org.eclipse.gef.editparts.AbstractEditPart.register(Abstract EditPart.java:759)
org.eclipse.gef.editparts.AbstractEditPart.addNotify(Abstrac tEditPart.java:229)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotif y(AbstractGraphicalEditPart.java:212)
org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:198)
org.eclipse.gef.editparts.SimpleRootEditPart.setContents(Sim pleRootEditPart.java:101)
org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents( AbstractEditPartViewer.java:601)
org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents( AbstractEditPartViewer.java:610)
mypackage.ClassDiagramViewer.createPartControl(ClassDiagramV iewer.java:84)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:663)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:422)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:263)
org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1405)
org.eclipse.ui.internal.EditorManager$5.runWithException(Edi torManager.java:939)
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3650)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3287)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2260)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 76)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:463)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:458)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:101)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:146)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:356)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:171)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 476)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:416)
at org.eclipse.equinox.launcher.Main.run(Main.java:1141)
at org.eclipse.equinox.launcher.Main.main(Main.java:1116)
Re: reusing a GMF-generated editor as a viewer [message #122605 is a reply to message #122464] Mon, 30 April 2007 11:42 Go to previous message
Rafael,
Take a look at the code in
OffscreenEditPartFactory.createDiagramEditPart(Diagram diagram, Shell
shell, PreferencesHint preferencesHint). It does something similar.
Cherie
> How can I do that?
> package_,
> following:
> Rafael
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Previous Topic:Three way EditPart overlapping contained in a top node
Next Topic:Problems launching Help Contents
Current Time: Fri Jul 04 11:54:33 EDT 2025
Powered by FUDForum. Page generated in 0.03721 seconds
