Re: Modeler / jBPM Problem [message #913454 is a reply to message #913051] |
Sat, 15 September 2012 17:58 |
Hi Andre,
Hmm, yes this is a known issue and I do have a workaround for it. Unfortunately it's a bit of hack and I've posted a question on the EMF forum here:
http://www.eclipse.org/forums/index.php/t/376638/
in hopes of getting a better solution to this problem. Ideally, the jBPM parser should be changed to allow ns prefixes on attributes that are contained in the drools model elements.
If I don't have an acceptable solution to this within the next few days, I'll have to go with the workaround. Either way, this WILL be fixed
Bob
Re: Modeler / jBPM Problem [message #915511 is a reply to message #915438] |
Mon, 17 September 2012 12:47 |
Hi Andre,
The "lax feature processing" option is set in the Bpmn2ModelerResourceImpl constructor as a load option like so:
getDefaultLoadOptions().put(XMLResource.OPTION_LAX_FEATURE_PROCESSING, true);
but, this is not the way to correct this problem. It looks like this is caused by a setting in the model's ExtendedMetaData as pointed out by Ed Merks in the EMF forum thread (see my earlier post). I'll have a look at this today and hopefully publish another build.
Bob
FUDForum. Page generated in 0.03381 seconds
