SWT application cannot be started with Oracle Java 7 on Mac [message #912347] |
Thu, 13 September 2012 11:52 |
Albert Pikus Messages: 70 Registered: October 2009 |
Member |
my SWT application won't start from Eclipse on Mac (Mac OS X Lion) when using 64-bit Oracle Java 7 (build 1.7.0_05-b05), I get ***WARNING: Display must be created on main thread due to Cocoa restrictions.
It's a known requirement that -XstartOnFirstThread program argument must be passed when running SWT applications on Mac, which I have set inside Run > Debug Configurations > Arguments > Program Arguments for my debug configuration. It seems that Eclipse simply ignores this argument when running SWT app on Java 7, like it wasn't there. As soon as I switch to Java 6, everything is back to normal again. I'd be surprised if no one else encountered this problem.
The other problem that surfaced with Oracle Java 7 is starting (SWT) application bundled as a JAR. I have built a single JAR that also bundles other JAR libraries that my application uses, using the approach that worked perfectly for me for a long time, on all platforms (Windows, Mac and Linux), please see: http://stackoverflow.com/questions/2706222/create-cross-platform-java-swt-application
For starting my program on Mac, I use the following shell script:
#!/bin/sh
PROGRAM_DIR=`dirname "$0"`
PROGRAM_DIR=`cd "$PROGRAM_DIR"; pwd`
cd "${PROGRAM_DIR}"
for FILE in ./*.jar; do
CLASSPATH="${CLASSPATH:+${CLASSPATH}:}$FILE"
done
exec java \
-jar \
-Xms256m -Xmx512m \
-XstartOnFirstThread \
-cp "$\{CLASSPATH\}" \
application.jar
When I try to start my application on Mac with Oracle Java 7, this is the error that is printed in Terminal:
Error: Could not find or load main class application.jar
It seems that Java thinks that application.jar is a main CLASS that should be run. Again, this problem only appears with Java 7 and I don't have a slightest idea what is causing it.
I have no problems running my application with Java 7 on Windows, not from Eclipse and also not as a standalone JAR:
Has anyone encountered similar issues with Java 7 on Mac?
Thanks in advance, best regards,
Albert
[Updated on: Mon, 17 September 2012 14:31] Report message to a moderator
Re: SWT application cannot be started with Oracle Java 7 on Mac [message #912790 is a reply to message #912452] |
Fri, 14 September 2012 07:35 |
Member |
David Wegener wrote on Thu, 13 September 2012 11:57Your second problem is likely caused by a change in the way that Java 7 parses arguments. The -jar argument is supposed to be followed immediately by the jar file name. You have it separated by a number of other arguments. Move the -jar to the end right before application.jar and see what happens.
thank you for your fast answer. Regarding my second problem, you are right about the arguments order, although I established after a few tries that the correct order is the following:
#!/bin/sh
cd "${PROGRAM_DIR}"
done
exec java \
-jar \
application.jar \
NOTE THE EMPTY LINE!!!!
-Xms256m -Xmx512m \
It's particularly odd that if there is no empty line before -cp "$\{CLASSPATH\}" \, java.lang.ClassNotFoundException: -cp is thrown.
Other reasonable combinations that I tried are also throwing exceptions.
This arguments order produces java.lang.ClassNotFoundException: -Xms256m
exec java \
-jar \
application.jar \
-Xms256m -Xmx512m \
This arguments order produces SWTException: Invalid thread access (and dialog stating "(SWTException: Invalid thread access) Try adding -XstartOnFirstThread to your command line arguments" is shown):
exec java \
-jar \
application.jar \
-Xms256m -Xmx512m \
Considering that only the topmost example works (with obligatory additional line break before the -cp argument), I would say that Oracle Java 7 for Mac has problems with arguments parsing. This could also be a reason for Eclipse Run configuration that doesn't correctly recognize -XstartOnFirstThread argument anymore.
Albert
[Updated on: Fri, 14 September 2012 07:37] Report message to a moderator
Re: SWT application cannot be started with Oracle Java 7 on Mac [message #915454 is a reply to message #913054] |
Mon, 17 September 2012 10:07 |
Member |
David Wegener wrote on Fri, 14 September 2012 13:11What your test say to me is that -jar has to be the last option on the command line. Anything after the -jar argument is taken to be the program arguments and not vm arguments.
You are right, my arguments order was simply wrong. I should just check the output of "java" command, which is the same for Java 6 and Java 7:
Usage: java [-options] class [args...]
(to execute a class)
or java [-options] -jar jarfile [args...]
(to execute a jar file)
where options include:
-d32 use a 32-bit data model if available
-d64 use a 64-bit data model if available (implies -server, only for x86_64)
-client to select the "client" VM
-server to select the "server" VM
-jvm is a synonym for the "client" VM [deprecated]
-hotspot is a synonym for the "client" VM [deprecated]
The default VM is client.
-cp <class search path of directories and zip/jar files>
-classpath <class search path of directories and zip/jar files>
A : separated list of directories, JAR archives,
and ZIP archives to search for class files.
-D<name>=<value>
set a system property
-verbose[:class|gc|jni]
enable verbose output
-version print product version and exit
-version:<value>
require the specified version to run
-showversion print product version and continue
-jre-restrict-search | -jre-no-restrict-search
include/exclude user private JREs in the version search
-? -help print this help message
-X print help on non-standard options
-ea[:<packagename>...|:<classname>]
-enableassertions[:<packagename>...|:<classname>]
enable assertions
-da[:<packagename>...|:<classname>]
-disableassertions[:<packagename>...|:<classname>]
disable assertions
-esa | -enablesystemassertions
enable system assertions
-dsa | -disablesystemassertions
disable system assertions
-agentlib:<libname>[=<options>]
load native agent library <libname>, e.g. -agentlib:hprof
see also, -agentlib:jdwp=help and -agentlib:hprof=help
-agentpath:<pathname>[=<options>]
load native agent library by full pathname
-javaagent:<jarpath>[=<options>]
load Java programming language agent, see java.lang.instrument
-splash:<imagepath>
show splash screen with specified image
So first come VM arguments, then -jar followed by a jar file name and optional program arguments. It still seems funny to me that Java 6 permitted wrong arguments order.
Thank you again for your help, best regards,
Albert
FUDForum. Page generated in 0.02968 seconds
