Home » Eclipse Projects » GEF » Width of palette when using PaletteGroup and PalleteDrawer
Width of palette when using PaletteGroup and PalleteDrawer [message #122213] Sun, 14 March 2004 16:48 Go to next message
Originally posted by: cwhite.ic.net
I have a palette that contains PaletteGroups and and a PaletteDrawer. When
the palette is displayed the palette width is insufficient to display the
entire label for the PaletteDrawer. Everything looks good if I use all
PalletteDrawers.
Is there some property I can set that will cause the palette to display with
its width sized to contain the longest label?
Re: Width of palette when using PaletteGroup and PalleteDrawer [message #122331 is a reply to message #122213] Mon, 15 March 2004 09:31 Go to previous messageGo to next message
It turns out the the width of the palette is fine if the intial state of the
drawer is OPEN and the drawer contains some items with labels that are at
least as long as the drawer label.
It must be that the palette doesn't pay the the drawer label win making its
sizing decisions.
Should I report this as a bug?
"Chris White" <cwhite@ic.net> wrote in message
news:c32jnh$s3m$1@eclipse.org...
> PalletteDrawers.
with
Re: Width of palette when using PaletteGroup and PalleteDrawer [message #122396 is a reply to message #122331] Mon, 15 March 2004 10:01 Go to previous messageGo to next message
What is your basis for asking hte palette its width?
Are you calling getPreferredSize or computeBounds?
news:c34eg7$pbi$1@eclipse.org...
the
its
> sizing decisions.
When
the
> > PalletteDrawers.
> with
Re: Width of palette when using PaletteGroup and PalleteDrawer [message #122504 is a reply to message #122331] Mon, 15 March 2004 10:46 Go to previous messageGo to next message
Look at GraphicalEditorWithPalette.getInitialPaletteSize()
the
its
> sizing decisions.
When
the
> > PalletteDrawers.
> with
Re: Width of palette when using PaletteGroup and PalleteDrawer [message #122658 is a reply to message #122396] Tue, 16 March 2004 11:48 Go to previous messageGo to next message
I am not asking the palette for its size. I am letting the palette size
itsself inside a composite that uses a grid layout (my own - I am not using
GraphicalEditorWithPalette). As I mentioned below the palette sizes properly
as long as the drawers is initially OPEN and it has a label that at least as
"Randy Hudson" <none@us.ibm.com> wrote in message
news:c34g7u$ru3$1@eclipse.org...
> the
> its
> > sizing decisions.
> When
> the
> > > PalletteDrawers.
display
> > with
Re: Width of palette when using PaletteGroup and PalleteDrawer [message #122669 is a reply to message #122658] Tue, 16 March 2004 13:23 Go to previous messageGo to next message
So, what you are saying is that the GridLayout is probably invoking
computeBounds on the palette's FigureCanvas, which in turn is invoking
getPreferredSize() on the palette. The problem here is that DrawerFigure
(in its getPreferredSize(int, int) method) returns its minimum size --
effectively, the preferred size of its header -- when not expanded, and
doesn't bother asking its children for their preferred size. I don't think
this quite qualifies as a bug, because that is what would be expected of it.
I am guessing you're seeing an ellipsis when you expand the drawer with the
entry that has the long label. Is that not acceptable?
Do you support internationalization? What happens when a palette's label
turns out to be really long in another language?
I'd suggest that you set an appropriate width hint for the palette.
news:c37arp$7q9$1@eclipse.org...
using
properly
as
of
> > the
> at
making
> > its
> > > sizing decisions.
PaletteDrawer.
> > When
display
> > the
all
> > > > PalletteDrawers.
> display
> > > with
Re: Width of palette when using PaletteGroup and PalleteDrawer [message #122678 is a reply to message #122669] Tue, 16 March 2004 14:21 Go to previous messageGo to next message
Thank you for the response.
It doesn't make sense to me that the collapsed (or expanded) drawer would
not be wide enough to display its own label. In my opinion this is a bug
(albiet a very tiny bug!).
I could write the code to calculate the preferred palette width but I would
attempt to cycle through the pallete looking for the longest label. It looks
like the pallete code is already something like this but as you point out
the preferred size for a collapse drawer doesn't take the length of its
label into account.
I am going to show my ignorance here. How would I set the pallete width
hint?
Having said all that, I have a better idea how this works and I appreciate
the info.
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:c37gfa$fck$1@eclipse.org...
think
it.
the
> using
> properly
least
> as
state
> of
> > > the
are
> > at
> making
> > > its
> > > > sizing decisions.
> PaletteDrawer.
> > > When
> display
> > > the
> all
> > > > > PalletteDrawers.
> > display
> > > > with
Re: Width of palette when using PaletteGroup and PalleteDrawer [message #122689 is a reply to message #122678] Tue, 16 March 2004 14:30 Go to previous messageGo to next message
I think I agree. If our layout managers respected figure visibility, then
drawerfigure wouldn't need to override getPreferredSize() at all. Open a
bugzilla. We can fix this for 3.0. If you need a fix for 2.1, the
workaround is to specify a widthHint to the GridData constraint object.
would
looks
> label into account.
> hint?
> the info.
DrawerFigure
> think
> it.
> the
label
size
> > using
> > properly
> least
> > as
> state
> > of
> > > > the
> are
> > > at
> > making
> > > > its
> > > > > sizing decisions.
> > PaletteDrawer.
> > > > When
> > display
> > > > the
use
> > all
> > > > > > PalletteDrawers.
> > > display
> > > > > with
Re: Width of palette when using PaletteGroup and PalleteDrawer [message #122693 is a reply to message #122678] Tue, 16 March 2004 15:22 Go to previous message
news:c37jsb$jr6$1@eclipse.org...
Aah. I misunderstood. I thought you meant that the drawer, in its
collapsed state, wasn't wide enough to completely fit the label of one of
its children (i.e., one of the palette entries inside the drawer). Right,
so the problem is still in getPreferredSize(int, int) in DrawerFigure. I
misspoke earlier when I said that,
when in collapsed state, the drawer's getMinimumSize() effectively returns
the preferred size of the header. A little more digging, and I realized
that it actually returns the minimum size of the header, which isn't wide
enough for the label.
> hint?
GridData data = new GridData();
data.widthHint = 200;
widget.setData(data);
> the info.
DrawerFigure
> think
> it.
> the
label
size
> > using
> > properly
> least
> > as
> state
> > of
> > > > the
> are
> > > at
> > making
> > > > its
> > > > > sizing decisions.
> > PaletteDrawer.
> > > > When
> > display
> > > > the
use
> > all
> > > > > > PalletteDrawers.
> > > display
> > > > > with
Previous Topic:Handles wont move
Next Topic:Forcing Figure Redraw
Current Time: Sun Nov 09 23:02:26 EST 2025
Powered by FUDForum. Page generated in 0.04566 seconds
