| update to 3.5.0 failed [message #911877] |
Wed, 12 September 2012 09:51  |
we are currently using virgo 3.0.1, when updating to 3.5.0 we are getting many exceptions ( Invocation of init method failed; nested exception is java.lang.IllegalArgumentException: required property 'bundleContext' has not been set ) for every spring osgi:reference
Any idea why ?
| Re: update to 3.5.0 failed [message #912012 is a reply to message #912007] |
Wed, 12 September 2012 15:32   |
happens also at runtime.
2012-09-12 20:54:41.190 ERROR [region-dm-9] o.e.virgo.medic.eventlog.default - Application context creation failure for bundle 'app.configuration' version '3.1.1.1'.
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dataSource': Invocation of init method failed; nested exception is java.lang.IllegalArgumentException: Required 'bundleContext' property was not set.
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1420) ~[org.springframework.beans_3.0.5.RELEASE.jar:3.0.5.RELEASE]
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519) ~[org.springframework.beans_3.0.5.RELEASE.jar:3.0.5.RELEASE]
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456) ~[org.springframework.beans_3.0.5.RELEASE.jar:3.0.5.RELEASE]
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:291) ~[org.springframework.beans_3.0.5.RELEASE.jar:3.0.5.RELEASE]
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222) ~[org.springframework.beans_3.0.5.RELEASE.jar:3.0.5.RELEASE]
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:288) ~[org.springframework.beans_3.0.5.RELEASE.jar:3.0.5.RELEASE]
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:190) ~[org.springframework.beans_3.0.5.RELEASE.jar:3.0.5.RELEASE]
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:563) ~[org.springframework.beans_3.0.5.RELEASE.jar:3.0.5.RELEASE]
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:895) ~[na:na]
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.access$1600(AbstractDelegatedExecutionApplicationContext.java:60) ~[org.eclipse.gemini.blueprint.core_1.0.0.RELEASE.jar/:1.0.0.RELEASE]
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext$4.run(AbstractDelegatedExecutionApplicationContext.java:325) ~[org.eclipse.gemini.blueprint.core_1.0.0.RELEASE.jar/:1.0.0.RELEASE]
at org.eclipse.gemini.blueprint.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85) ~[na:na]
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.completeRefresh(AbstractDelegatedExecutionApplicationContext.java:290) ~[org.eclipse.gemini.blueprint.core_1.0.0.RELEASE.jar/:1.0.0.RELEASE]
at org.eclipse.gemini.blueprint.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$CompleteRefreshTask.run(DependencyWaiterApplicationContextExecutor.java:137) [org.eclipse.gemini.blueprint.extender_1.0.0.RELEASE.jar/:1.0.0.RELEASE]
at org.eclipse.virgo.kernel.agent.dm.ContextPropagatingTaskExecutor$2.run(ContextPropagatingTaskExecutor.java:95) [org.eclipse.virgo.kernel.agent.dm_3.5.0.RELEASE.jar/:3.5.0.RELEASE]
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886) [na:1.6.0_32]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908) [na:1.6.0_32]
at java.lang.Thread.run(Thread.java:662) [na:1.6.0_32]
Caused by: java.lang.IllegalArgumentException: Required 'bundleContext' property was not set.
at org.springframework.util.Assert.notNull(Assert.java:112) ~[org.springframework.core_3.0.5.RELEASE.jar:3.0.5.RELEASE]
at org.springframework.osgi.service.importer.support.AbstractOsgiServiceImportFactoryBean.afterPropertiesSet(AbstractOsgiServiceImportFactoryBean.java:79) ~[na:na]
at org.springframework.osgi.service.importer.support.AbstractServiceImporterProxyFactoryBean.afterPropertiesSet(AbstractServiceImporterProxyFactoryBean.java:52) ~[na:na]
at org.springframework.osgi.service.importer.support.OsgiServiceProxyFactoryBean.afterPropertiesSet(OsgiServiceProxyFactoryBean.java:118) ~[na:na]
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1477) ~[org.springframework.beans_3.0.5.RELEASE.jar:3.0.5.RELEASE]
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1417) ~[org.springframework.beans_3.0.5.RELEASE.jar:3.0.5.RELEASE]
... 17 common frames omitted
the bean 'dataSource' which fails to init is created via osgi registry:
<osgi:reference id="dataSource" interface="javax.sql.DataSource"/>
this is the manifest:
Manifest-Version: 1.0
Archiver-Version: Plexus Archiver
Created-By: Maven Integration for Eclipse
Built-By: admin
Build-Jdk: 1.6.0_32
Export-Package: app.configuration;version="3.1.1.1";uses:="jav
ax.annotation,javax.management,org.apache.commons.configuration,org.a
pache.commons.configuration.event,org.osgi.framework,org.springframew
ork.beans.factory,org.springframework.beans.factory.annotation,org.sp
ringframework.jmx.export.annotation,org.springframework.osgi.context,
org.springframework.stereotype"
Bundle-Vendor: app Sources
Bundle-Version: 3.1.1.1
Tool: Bundlor 1.0.0.RELEASE
Bundle-Name: app Configuration
Bundle-ManifestVersion: 2
Bundle-SymbolicName: app.configuration
Import-Package: javax.annotation,javax.management,javax.management.rem
ote,javax.management.remote.rmi,javax.security.auth.login,javax.sql,o
rg.apache.commons.collections,org.apache.commons.configuration,org.ap
ache.commons.configuration.event,org.apache.commons.configuration.rel
oading,org.apache.naming.java,org.eclipse.virgo.web.dm;version="[3.0.
0, 4.0.0)",org.osgi.framework,org.slf4j,org.springframework.beans.fac
tory,org.springframework.beans.factory.annotation,org.springframework
.jmx.export.annotation,org.springframework.osgi.context;version="[1.2
.1,1.3.0)",org.springframework.stereotype
Any idea whats wrong ?
Thanks for you help
| Re: update to 3.5.0 failed [message #912461 is a reply to message #912012] |
Thu, 13 September 2012 12:10  |
Hi Jacob,
Sorry, this one is outside of my area of expertise. Perhaps someone from Runtime has ideas? Have you tried it with other runtime targets, e.g. 3.5.0?
Miles
FUDForum. Page generated in 0.03919 seconds
