RAP and MSSQL [message #911813] |
Wed, 12 September 2012 07:27 |
can u help me please???
how can I create and use a connection to MSSQL Server in RAP!!!
please!!!
The Error:
2012-09-12 13:08:28.426:INFO:oejs.Server:jetty-8.1.3.v20120522
2012-09-12 13:08:30.017:INFO:oejs.AbstractConnector:Started SelectChannelConnector@0.0.0.0:54972
osgi>
java.lang.ClassNotFoundException: com.microsoft.sqlserver.jdbc.SQLServerDriver
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at database.SQLVerbindung.connect(SQLVerbindung.java:18)
at second.AnotherView.ConnectDB(AnotherView.java:41)
at second.AnotherView.createPartControl(AnotherView.java:26)
at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewReference.java:375)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:226)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:599)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:318)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:542)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:185)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:265)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:64)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:479)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1262)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1215)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1614)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:659)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:585)
at org.eclipse.ui.internal.PartSashContainer.createControl(PartSashContainer.java:573)
at org.eclipse.ui.internal.PerspectiveHelper.activate(PerspectiveHelper.java:269)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.java:980)
at org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPage.java:2627)
at org.eclipse.ui.internal.WorkbenchWindow$26.run(WorkbenchWindow.java:3077)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:66)
at org.eclipse.ui.internal.WorkbenchWindow.setActivePage(WorkbenchWindow.java:3058)
at org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(WorkbenchWindow.java:763)
at org.eclipse.ui.internal.Workbench$18.runWithException(Workbench.java:1267)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:32)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:229)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:1061)
at org.eclipse.ui.internal.StartupThreading.runWithWorkbenchExceptions(StartupThreading.java:55)
at org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Workbench.java:1263)
at org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow(Workbench.java:2062)
at org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbench.java:1993)
at org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWindow(WorkbenchConfigurer.java:188)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:790)
at org.eclipse.ui.internal.Workbench$27.runWithException(Workbench.java:1641)
at org.eclipse.ui.internal.StartupThreading.runWithoutExceptions(StartupThreading.java:110)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1636)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2655)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:2530)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:702)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:685)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:157)
at second.Application.start(Application.java:18)
at org.eclipse.rap.ui.internal.application.EntryPointApplicationWrapper.createUI(EntryPointApplicationWrapper.java:38)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWTLifeCycle.java:177)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:289)
at java.lang.Thread.run(Unknown Source)
at org.eclipse.rwt.internal.lifecycle.UIThread.run(UIThread.java:102)
thanks,
Andi
FUDForum. Page generated in 0.02829 seconds
