Home » Modeling » TMF (Xtext) » Odd error using IJvmTypeProvider
Odd error using IJvmTypeProvider [message #911199] |
Tue, 11 September 2012 07:16 |
Aaron Digulla Messages: 258 Registered: July 2009 Location: Switzerland |
This is part of my DSL:
Import: 'import' name=QualifiedName ';';
In the .i18n (model) file, I have this line:
This is checked using this code:
import org.eclipse.xtext.common.types.JvmType;
import org.eclipse.xtext.common.types.access.IJvmTypeProvider;
import com.pany.eclipse.i18n_dsl.i18nDsl.I18nDslPackage;
import com.pany.eclipse.i18n_dsl.i18nDsl.Import;
import com.google.inject.Inject;
@SuppressWarnings( "restriction" )
public class ImportChecker {
@Inject
private IJvmTypeProvider.Factory typeProviderFactory;
public void checkImports( Import imp, I18nDslJavaValidator validator ) {
// don't check wildcard imports
String name = imp.getName();
if( name.endsWith( ".*" ) ) {
return;
IJvmTypeProvider typeProvider = typeProviderFactory.findOrCreateTypeProvider( imp.eResource().getResourceSet() );
JvmType jvmType = typeProvider.findTypeByName( name );
if( jvmType == null ) {
validator.error( "The import " + name + " cannot be resolved", imp, I18nDslPackage.Literals.IMPORT__NAME );
From the code above, this Java code is generated in the same Eclipse project (= same classpath as the .i18n file)
public final static I18nMessage foo( Locale locale ) { ... }
Now the fun part:
1. When I open the .i18n file in Eclipse, there are no problems (warnings or errors).
Then I add a space, delete it again and save.
Suddenly, the import is underlined in red. The error message reads "The import java.util.Locale cannot be resolved"
2. There is no entry in the Problems View!
3. The Java code compiles without error.
Questions:
1. How is it possible that I get an error in the editor but not in the problems view?
2. Why do I get the error at all? If java.util.Locale wasn't on the classpath, I doubt that the generated Java code would compile.
A. Digulla
Re: Odd error using IJvmTypeProvider [message #911231 is a reply to message #911199] |
Tue, 11 September 2012 08:02 |
Sebastian Zarnekow Messages: 3118 Registered: July 2009 |
Hi Aaron,
I assume you somehow get a null impl of the JvmTypeProvider. Could you
try to set a breakpoint into the constructor
NullJdtTypeProvider(ResourceSet)?
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 11.09.12 09:16, schrieb Aaron Digulla:
> import java.util.Locale;
> @Inject
> return;
> Now the fun part:
> Questions:
> problems view?
> A. Digulla
Re: Odd error using IJvmTypeProvider [message #916778 is a reply to message #911231] |
Wed, 19 September 2012 12:58 |
Sebastian Zarnekow wrote on Tue, 11 September 2012 10:02Hi Aaron,
Okay, I could create a working launch config again.
The break point is hit. Here is the stack trace:
Thread [Worker-2] (Suspended (breakpoint at line 34 in NullJdtTypeProvider))
NullJdtTypeProvider.<init>(ResourceSet) line: 34
JdtTypeProviderFactory.createJdtTypeProvider(IJavaProject, ResourceSet) line: 39
JdtTypeProviderFactory.createTypeProvider(ResourceSet) line: 32
JdtTypeProviderFactory.createTypeProvider(ResourceSet) line: 1
JdtTypeProviderFactory(AbstractTypeProviderFactory).findOrCreateTypeProvider(ResourceSet) line: 41
ImportChecker.checkImports(Import, I18nDslJavaValidator) line: 22
I18nDslJavaValidator.checkImports(Import) line: 367
NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line: not available [native method]
NativeMethodAccessorImpl.invoke(Object, Object[]) line: 39
DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: 25
Method.invoke(Object, Object...) line: 597
AbstractDeclarativeValidator$MethodWrapper.invoke(AbstractDeclarativeValidator$State) line: 109
I18nDslJavaValidator(AbstractDeclarativeValidator).internalValidate(EClass, EObject, DiagnosticChain, Map<Object,Object>) line: 291
I18nDslJavaValidator(AbstractInjectableValidator).validate(EClass, EObject, DiagnosticChain, Map<Object,Object>) line: 62
CompositeEValidator.validate(EClass, EObject, DiagnosticChain, Map<Object,Object>) line: 126
CancelableDiagnostician(Diagnostician).validate(EClass, EObject, DiagnosticChain, Map<Object,Object>) line: 159
CancelableDiagnostician(Diagnostician).validate(EObject, DiagnosticChain, Map<Object,Object>) line: 137
CancelableDiagnostician.validate(EObject, DiagnosticChain, Map<Object,Object>) line: 36
CancelableDiagnostician(Diagnostician).doValidateContents(EObject, DiagnosticChain, Map<Object,Object>) line: 174
CancelableDiagnostician.doValidateContents(EObject, DiagnosticChain, Map<Object,Object>) line: 48
CancelableDiagnostician(Diagnostician).validate(EClass, EObject, DiagnosticChain, Map<Object,Object>) line: 162
CancelableDiagnostician(Diagnostician).doValidateContents(EObject, DiagnosticChain, Map<Object,Object>) line: 178
CancelableDiagnostician(Diagnostician).validate(EObject, Map<?,?>) line: 120
ResourceValidatorImpl.validate(Resource, CheckMode, CancelIndicator) line: 108
ValidationJob$1.exec(XtextResource) line: 79
ValidationJob$1.exec(Object) line: 1
XtextDocument$XtextDocumentLocker(AbstractReadWriteAcces<P>).readOnly(IUnitOfWork<T,P>) line: 32
XtextDocument.readOnly(IUnitOfWork<T,XtextResource>) line: 78
ValidationJob.createIssues(IProgressMonitor) line: 75
ValidationJob.run(IProgressMonitor) line: 64
Worker.run() line: 54
I followed the code and createJdtTypeProvider() is interesting:
if (javaProject == null)
//TODO throw a serious exception instead of returning a non working implementation
return new NullJdtTypeProvider(resourceSet);
I guess the exception would have been better for me
Debugging this further, I got to XtextResourceSetBasedProjectProvider:
Object context = xtextResourceSet.getClasspathURIContext();
This code is invoked when I open a DSL document, when I change it and when I save. The context is null when I open the DSL document and when I type in it. When I save, it contains an instance of JavaProject.
That would explain the odd behavior of the Problems view: It's not updated when the document is loaded or while I make changes. So I get errors in the editor but not in the view. When I save, JavaProject!= null, so the validation passes and the Problem View doesn't show any errors.
The errors in the editor stay because Xtext doesn't refresh them on save (probably on the grounds that the list can't have changed since the last change and saving the document).
So I went further back. The XtextResource resource which is used for org.eclipse.xtext.ui.editor.model.XtextDocument.setInput(XtextResource) has a null classpathURIContext even though the resource comes from a JavaProject. It was created with
XtextResource xtextResource = (XtextResource) resourceForEditorInputFactory.createResource(editorInput);
which eventually calls org.eclipse.xtext.ui.editor.model.ResourceForIEditorInputFactory.getResourceSet(IStorage):
protected ResourceSet getResourceSet(IStorage storage) {
if (storage instanceof IFile) {
return resourceSetProvider.get(((IFile) storage).getProject());
return resourceSetProvider.get(null);
storage is an IFile and getProject() returns != null. We end up here:
public class SimpleResourceSetProvider implements IResourceSetProvider {
@Inject
private Provider<XtextResourceSet> resourceSetProvider;
public ResourceSet get(IProject project) {
return resourceSetProvider.get();
At this point, project is an instance of org.eclipse.core.internal.resources.Project (so not a Java project). When the method returns, classpathURIContext is still null.
Also the setter setClasspathURIContext() is never called. It's only called in org.eclipse.xtext.ui.resource.XtextResourceSetProvider.get(IProject) but this code is only invoked when I save the document. It's not invoked for open/edit.
What now?
A. Digulla
Re: Odd error using IJvmTypeProvider [message #916859 is a reply to message #916778] |
Wed, 19 September 2012 14:59 |
Make sure you use the XtextResourceSetProvider. It's configured in
org.eclipse.xtext.ui.DefaultUiModule.bindIResourceSetProvider().
Why did you override it?
Sebastian
Am 19.09.12 14:58, schrieb Aaron Digulla:
>> Hi Aaron,
> line: 120
> I guess the exception would have been better for me :)
> errors.
> @Inject
> called in
> open/edit.
> What now?
> A. Digulla
Re: Odd error using IJvmTypeProvider [message #916892 is a reply to message #916859] |
Wed, 19 September 2012 15:57 |
Sebastian Zarnekow wrote on Wed, 19 September 2012 16:59Make sure you use the XtextResourceSetProvider. It's configured in
Because computePlatformURIMap is too slow. What do you think of this implementation:
public class PlatformURIMapCache {
private final static Logger LOG = Logger.getLogger(PlatformURIMapCache.class);
private Map<String, Map<URI, URI>> cache = newHashMap();
public Map<URI, URI> computePlatformURIMap(IJavaProject javaProject) {
HashMap<URI, URI> hashMap = newHashMap(EcorePlugin.computePlatformURIMap());
try {
if (!javaProject.exists())
return hashMap;
IClasspathEntry[] classpath = javaProject.getResolvedClasspath(true);
for (IClasspathEntry classPathEntry : classpath) {
processClasspathEntry( hashMap, classPathEntry );
} catch (JavaModelException e) {
LOG.error(e.getMessage(), e);
return hashMap;
protected void processClasspathEntry( HashMap<URI, URI> hashMap, IClasspathEntry classPathEntry ) {
IPath path = classPathEntry.getPath();
if (null == path || ! "jar".equals(path.getFileExtension())) {
return;
try {
final File file = path.toFile();
if (null == file || ! file.exists()) {
return;
processJarFile(hashMap, file);
} catch (IOException e) {
protected void processJarFile( HashMap<URI, URI> hashMap, final File file ) throws IOException {
String key = file.getAbsolutePath();
Map<URI, URI> cached = cache.get(key);
if (null == cached) {
cached = mapFromJarFile(file);
cache.put(key, cached);
hashMap.putAll(cached);
private Map<URI, URI> mapFromJarFile( File file ) throws IOException {
JarFile jarFile = new JarFile(file);
try {
Manifest manifest = jarFile.getManifest();
if (null == manifest) {
return Collections.emptyMap();
String name = manifest.getMainAttributes().getValue("Bundle-SymbolicName");
if (null == name) {
name = stripSemicolon( name );
if (EcorePlugin.getPlatformResourceMap().containsKey(name)) {
String p = "archive:" + file.toURI() + "!/";
URI uri = URI.createURI(p);
final URI platformResourceKey = URI.createPlatformResourceURI(name + "/", false);
final URI platformPluginKey = URI.createPlatformPluginURI(name + "/", false);
Map<URI, URI> result = newHashMap();
result.put(platformResourceKey, uri);
result.put(platformPluginKey, uri);
return result;
} finally {
jarFile.close();
protected String stripSemicolon( String name ) {
final int indexOf = name.indexOf(';');
if (indexOf > 0)
name = name.substring(0, indexOf);
return name;
Now XtextResourceSetProvider could inject the singleton and call it's computePlatformURIMap().
A. Digulla
Re: Odd error using IJvmTypeProvider [message #916907 is a reply to message #916892] |
Wed, 19 September 2012 16:11 |
So you confirm that the other stuff is working properly if you use the
XtextResourceSetProvider instead of the SimpleResourceSetProvider?
Feel free to bind you own XtextResourceSetProvider if the default impl
is too slow in your environment.
Any kind of caching mechanism needs a means to update the cache, e.g. if
you open / close projects or add more items to the classpath. Thus I
doubt that you sketched impl works for the common case.
Sebastian
Am 19.09.12 17:57, schrieb Aaron Digulla:
> implementation:
> try {
> return hashMap;
> return hashMap;
> return;
> try {
> return;
> try {
> String name =
> if (null == name) {
> return result;
> } finally {
> jarFile.close();
> if (indexOf > 0)
> return name;
> A. Digulla
Re: Odd error using IJvmTypeProvider [message #917528 is a reply to message #916907] |
Thu, 20 September 2012 07:04 |
Sebastian Zarnekow wrote on Wed, 19 September 2012 18:11So you confirm that the other stuff is working properly if you use the
Probably. I didn't test it explicitly but it works with my new FastXtextResourceSetProvider, so it's safe to assume your version works as well. Thanks for helping me find the issue so fast.
Please look at the code. You will see that the part which handles the workspace hasn't changed. I'm just caching information from JAR files. Maybe I should generate a key which includes file name, last modification and size but JARs on the classpath will rarely change.
A. Digulla
[Updated on: Thu, 20 September 2012 07:16] Report message to a moderator
Re: Odd error using IJvmTypeProvider [message #917567 is a reply to message #917528] |
Thu, 20 September 2012 07:50 |
Sorry, I missed that at a first glance, though I like the improved
version in the gist better. Can you provide some rough numbers on the
improved time to create a resource set for an average project of yours?
Would you be willing to contribute the code (the gist does not contain
license information)?
Sebastian
Am 20.09.12 09:04, schrieb Aaron Digulla:
>> if you open / close projects or add more items to the classpath. Thus
>> I doubt that you sketched impl works for the common case.
> A. Digulla
Re: Odd error using IJvmTypeProvider [message #917748 is a reply to message #917698] |
Thu, 20 September 2012 11:48 |
Hi Aaron,
if a reasonable sized projects uses 100ms in that routine but opening a
file (for the second time?) takes 2 secs, I'm reluctant to include the
code. It introduces additional complexity (even though only minor) but
does not address a serious issue. However, please file a ticket and
attach the code. We'll take some measurements with that one and decide
how to continue with the effort to make an editor snappier.
Did you try to profile the open-action?
Sebastian
Am 20.09.12 12:43, schrieb Aaron Digulla:
> Sebastian Zarnekow wrote on Thu, 20 September 2012 09:50
> I timed the calls. To my surprise, they weren't that high to begin with.
> In a big project (188 JARs), the computation takes around 100ms. My
> patch about halves this figure.
> Most of that is probably spent in EcorePlugin.computePlatformURIMap()
> but I have no idea how to cache that :-/
> I also noticed that something expensive happens afterwards:
> 1. I double click a DSL file
> 2. I see the log output from my timing code
> 3. Noticeable lag for 100 to 2000ms. What happens here?
> 4. Editor opens
> I'd love to see this code included. What do you need me to do?
> A. Digulla
Re: Odd error using IJvmTypeProvider [message #918658 is a reply to message #917748] |
Fri, 21 September 2012 08:05 |
Sebastian Zarnekow wrote on Thu, 20 September 2012 13:48Hi Aaron,
I was surprised as well. After thinking about it for some time, I realized why the timing isn't accurate: I have 16GB of RAM with 4GB file buffer. So the 188 JARs are in memory. When they have to be loaded from disk, that can take several seconds.
After flushing the caches, I get these timings:
1.37s for loading 33 JARs (small project) and 9.62s for 188 JARs (initial load for both cases). This number doesn't change much with the old code. With my patch, the subsequent invocations go down to 50-100ms in both cases.
So I suggest that you include the patch.
Yesterday, I created a version of the cache which duplicates the code from EcorePlugin.computePlatformURIMap() but in my case, it doesn't return many URLs and it uses information which is cached by Eclipse, so the speedup of that code probably isn't that high anyway.
But since it was quite a bit of work to rearrange the EMF code, I've added a switch that disables the cache by default. Maybe it makes a difference for large workspaces but I have only 7 plugins in my workspace, so I can't really tell.
Bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=390074
I suggest to apply this for the SR1 or SR2. For people with tight memory and large workspaces, this patch is a huge time-saver.
A. Digulla
[Updated on: Fri, 21 September 2012 08:06] Report message to a moderator
Re: Odd error using IJvmTypeProvider [message #918735 is a reply to message #918658] |
Fri, 21 September 2012 09:39 |
Thanks for the patch. The numbers look good to me.
Sebastian
Am 21.09.12 10:05, schrieb Aaron Digulla:
>> Hi Aaron,
>> a file (for the second time?) takes 2 secs, I'm reluctant to include
>> the code. It introduces additional complexity (even though only minor)
>> but does not address a serious issue. However, please file a ticket
>> and attach the code. We'll take some measurements with that one and
>> decide how to continue with the effort to make an editor snappier.
> (initial load for both cases). This number doesn't change much when the
> fast cache is disabled. With my patch, the subsequent invocations go
> A. Digulla
Current Time: Fri Apr 26 05:55:51 GMT 2024
Powered by FUDForum. Page generated in 0.05498 seconds
