Home » Language IDEs » C / C++ IDE (CDT) » ECPG Preprocessor(How do I add a pre-preprocessor to the build process?)
ECPG Preprocessor [message #911088] Mon, 10 September 2012 20:18 Go to next message
I want to try using the embedded SQL in C facility in postgresql.
This requires starting with a .pgc source file, which is converted to a .c file by running the command
/usr/bin/ecpg source-file.pgc
which produces a .c file, which can then be compiled and linked normally.
I have tried getting eclipse to recognize the extra step, with no success.
Can anyone tell me how to tell eclipse (or the CDT builder?) about the additional dependency and how to handle it?
Re: ECPG Preprocessor [message #1251762 is a reply to message #911088] Thu, 20 February 2014 10:17 Go to previous message
you have solved it?
Previous Topic:[Closed - no solution] Perspective not stored in preferences during export
Next Topic:Cannot create GDB Hardware Debugging cofiguration
Current Time: Tue Oct 28 18:37:48 EDT 2025
Powered by FUDForum. Page generated in 0.50497 seconds
