Resource class not found while exporting plugin using ant [message #911012] |
Mon, 10 September 2012 20:07 |
Eyck Jentzsch Messages: 21 Registered: August 2012 |
if I build the plugin using ant (during product export) I get the following error message:
.../.metadata/.plugins/org.eclipse.pde.core/temp/org.eclipse.pde.container.feature/compile.org.eclipse.pde.container.feature.xml:9: The following error occurred while executing this line:
.../build.xml:301: The following error occurred while executing this line:
.../build.xml:218: The following error occurred while executing this line:
.../customBuildCallbacks.xml:57: java.lang.NoClassDefFoundError: org/eclipse/sapphire/modeling/Resource
where line 57 is the sapphire task:
<sapphire src="src" dest=".resources"/>
I was searching for hours but I did not get a clue what's the cause. Any hint what's wrong with this?
THXIA
-Eyck
[Updated on: Mon, 10 September 2012 20:09] Report message to a moderator
FUDForum. Page generated in 0.03670 seconds
