Re: Processing the XMI of the KDM [message #910820 is a reply to message #909520] |
Mon, 10 September 2012 12:45 |
Rafael Durelli Messages: 72 Registered: September 2012 |
Member |
Hello Hugo Bruneliere thanks to reply. However, I think I didn't get it. Thus, let me trying to explain my problem to you and probably you can help much more.
My problem is the following: I have an instance of the KDM (XMI), which represents my legacy systems, my goal is remove specifics chunk of code (edges) of this XMI. These chunk of code will be every statements related to persistence (JDBC), such as ResultSet, Statement, Preparedstatements, etc. After remove these chunk of code I'll pretend to extend the KDM to deal with AspectJ, thus, afterwards these chunk of code I'll be transform to a KDM extended.
As I said in my earlier post I tried to do such goal by using XPath, reading all XMI and removing them, but this is demanding such time.
So my doubt is, how can I do that? Could you give me a simple example, because I'm new in Modisco.
Thanks guys
FUDForum. Page generated in 0.04028 seconds
