Designer plug-in project not working [message #909166] |
Thu, 06 September 2012 16:55 |
John 555 Messages: 21 Registered: September 2012 |
I'm making an ODA designer plug-in project to go with the runtime driver that I have created. The runtime project is correctly referenced in the manifest file, and has been added to the designer project's build path. I have created some simple test pages that should show up in the new data set wizard, and I have added them to the plugin.xml file. But, when I run the designer project as an eclipse application, the new data set wizard has none of my custom pages. Can anyone with plugin experience provide any insight?
[Updated on: Thu, 06 September 2012 16:55] Report message to a moderator
Re: Designer plug-in project not working [message #909254 is a reply to message #909202] |
Thu, 06 September 2012 20:19 |
Jason,
I'm not sure I understand you correctly, do you mean put the packages for both the runtime and the designer plugin in the same project folder? I went ahead and tried it and it did not work, but I'm pretty sure I'd need to make some sort of change to the plugin.xml for that to work.
I don't think there is any problem with having the runtime project in the designer project's build path though. I've seen it done in examples. But when I apply an example to what I am doing, my runtime plugin acts as though there is no designer plugin.
Edit: I put a static breakpoint in my designer project's activator. That breakpoint is never even reached.
-John
[Updated on: Fri, 07 September 2012 13:16] Report message to a moderator
Re: Designer plug-in project not working [message #909703 is a reply to message #909254] |
Fri, 07 September 2012 16:12 |
Generally when you create an ODA you create a runtime plugin and a designer ui plugin. If you export both plugins, you should be able to just copy these to the designers plugins directory to have them show up. If you want to debug them, you can have both plugin projects in the same workspace and setup a debug configuration with a new Eclipse Application. Other than implementing extensions you should not have to do anything to the plugin.xml.
Jason
FUDForum. Page generated in 0.03076 seconds
