Exception creating session singleton [message #121250] |
Wed, 11 February 2009 13:28 |
Hi all,
after having updated my target to 1.2.0 M5 and implemented the save on
perspectives I can't use my RAP application anymore.
The server starts as always, but when I try to load my application, after
a custom implemented login, I receive the following errors:
java.lang.RuntimeException: Could not create the session singleton
instance of
'org.eclipse.ui.internal.WorkbenchPlugin$PerspectiveRegistry Store' because
an Exception was thrown by the constructor:
Could not create the session singleton instance of
[... LINE REPEATED hundreds of times...]
null........................................................ ............................................................ ............................................................ ............................................................ .................................
at
org.eclipse.rwt.SessionSingletonBase.getInstanceInternal(Ses sionSingletonBase.java:189)
at
org.eclipse.rwt.SessionSingletonBase.getInstance(SessionSing letonBase.java:91)
at
org.eclipse.ui.internal.WorkbenchPlugin$PerspectiveRegistryS tore.getInstance(WorkbenchPlugin.java:115)
at
org.eclipse.ui.internal.WorkbenchPlugin.getPerspectiveRegist ry(WorkbenchPlugin.java:707)
at
org.eclipse.ui.internal.Workbench.getPerspectiveRegistry(Wor kbench.java:1163)
at
org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow(Work bench.java:1794)
at
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1729)
at
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:188)
at
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:790)
at
org.eclipse.ui.internal.Workbench$25.runWithException(Workbe nch.java:1335)
at
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:32)
at
org.eclipse.rwt.internal.lifecycle.UICallBackManager.addSync (UICallBackManager.java:135)
at org.eclipse.swt.widgets.Display$2.run(Display.java:648)
at
org.eclipse.rwt.internal.lifecycle.UICallBackServiceHandler. runNonUIThreadWithFakeContext(UICallBackServiceHandler.java: 455)
at
org.eclipse.rwt.lifecycle.UICallBack.runNonUIThreadWithFakeC ontext(UICallBack.java:44)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:646)
at
org.eclipse.ui.internal.StartupThreading.runWithoutException s(StartupThreading.java:110)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1330)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2309)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:22 00)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:425)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:333)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:408)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:157)
at
ch.oasi.xl.ui.workbench.ApplicationRunner.run(ApplicationRun ner.java:35)
at ch.oasi.xl.ui.rap.EntryPoint.createUI(EntryPoint.java:14)
at
org.eclipse.rwt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:92)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWT LifeCycle.java:228)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:116)
at java.lang.Thread.run(Thread.java:619)
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at
sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:39)
at
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:5 13)
at
org.eclipse.rwt.SessionSingletonBase.getInstanceInternal(Ses sionSingletonBase.java:154)
... 29 more
Caused by: java.lang.RuntimeException: Could not create the session
[... line repeated thousands of times...]
Is the save on perspectives implemnted in RAP environment?
Where are these data saved?
Re: Exception creating session singleton [message #121351 is a reply to message #121283] |
Thu, 12 February 2009 09:04 |
Hi Benjamin,
Hi all,
For «Save on perspective» I mean saving the perspective layout. My
application is composed with many perspectives, and the user can switch
from one to another; when i switch the perspective I save the current
perspective layout using the following code (snippet):
IWorkbenchWindow w = PlatformUI.getWorkbench().getActiveWorkbenchWindow();
IWorkbenchPage page = w.getActivePage();
// save perspective
try
page.savePerspective();
// .. code omitted ...
page.close()
catch( Exception e )
e.printStackTrace();
The Console output is (I have cutted some repeated lines... you can see a
zipped log file (console.log.zip) here: http://drop.io/elvisd79io ):
osgi>java.lang.RuntimeException: Could not create the session singleton
instance of 'org.eclipse.ui.internal.WorkbenchPlugin
$PerspectiveRegistryStore' because an Exception was thrown by the
constructor:
because an Exception was thrown by the constructor:
at org.eclipse.rwt.SessionSingletonBase.getInstanceInternal
(SessionSingletonBase.java:189)
(SessionSingletonBase.java:91)
at org.eclipse.ui.internal.WorkbenchPlugin
$PerspectiveRegistryStore.getInstance(WorkbenchPlugin.java:1 15)
at org.eclipse.ui.internal.WorkbenchPlugin.getPerspectiveRegist ry
at
org.eclipse.ui.internal.registry.PerspectiveDescriptor.resto reState
(PerspectiveDescriptor.java:332)
at org.eclipse.ui.internal.registry.PerspectiveRegistry.loadCus tom
(PerspectiveRegistry.java:449)
(PerspectiveRegistry.java:409)
at org.eclipse.ui.internal.WorkbenchPlugin$1.runWithException
(WorkbenchPlugin.java:108)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run
at org.eclipse.rwt.internal.lifecycle.UICallBackManager.addSync
at
(UICallBackServiceHandler.java:455)
at
at org.eclipse.ui.internal.StartupThreading.runWithoutException s
$PerspectiveRegistryStore.<init>(WorkbenchPlugin.java:106)
at sun.reflect.GeneratedConstructorAccessor7.newInstance(Unknow n
Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance
(DelegatingConstructorAccessorImpl.java:27)
(SessionSingletonBase.java:154)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
at
at
Source)
at
FUDForum. Page generated in 0.03644 seconds
