Home » Archived » BIRT » [chart] with multiple categories (on x)
Re: [chart] with multiple categories (on x) [message #909721 is a reply to message #909445] |
Fri, 07 September 2012 12:38   |
If you imported the report, you should have layout, Master Page, Script, XML Source and Preview tabs. If you create a new report do you get those? You can always select the xml tab and copy and paste the report contents in. Specifically this was done with chart script. Select the chart and click on the script tab:
last = "";
function beforeDrawAxisLabel( axis, label, icsc )
importPackage(
Packages.org.eclipse.birt.chart.model.attribute.impl );
importPackage(
Packages.org.eclipse.birt.chart.model.attribute );
if( axis.getType() == AxisType.TEXT_LITERAL ){
var cp =label.getCaption().getValue();
if( cp.substr(0,2) == last ){
label.getCaption().setValue(cp.substr( (cp.length()-2)));
}else{
label.getCaption().setValue(cp.substr( (cp.length()-2))+"\n\r "+cp.substr(0,2));
last = cp.substr(0,2);
It uses a beforeDrawAxisLabel script. When using the Chart API you can set a script like:
ChartWithAxes cwaBar = ChartWithAxesImpl.create( );
cwaBar.setScript( "function afterDataSetFilled( series, idsp,Iicsc )"
+ "{importPackage(Packages.java.lang); "
+ "if (series.getLabel().isVisible() == true)"
+ "{System.out.println(\"ok\");} "
+ "else"
+ "{System.out.println(\"false\");}} "
Jason
Re: [chart] with multiple categories (on x) [message #912470 is a reply to message #911687] |
Thu, 13 September 2012 12:31   |
The afterDataSetFilled was just an example of one event that you could override. You need to put the script in a Java String and use the setScript to set in on the chart. For a list of all events look at this post:
http://birtworld.blogspot.com/2010/08/birt-charting-scripting-overview.html
You could also use setScript to set a fully qualified classname that extends the ChartEventHandlerAdapter class. Like:
import org.eclipse.birt.chart.model.attribute.AxisType;
import org.eclipse.birt.chart.model.component.Axis;
import org.eclipse.birt.chart.model.component.Label;
import org.eclipse.birt.chart.script.ChartEventHandlerAdapter;
import org.eclipse.birt.chart.script.IChartScriptContext;
public class AxisScript extends ChartEventHandlerAdapter
* (non-Javadoc)
* @see org.eclipse.birt.chart.script.IChartItemScriptHandler#beforeDrawAxisLabel(org.eclipse.birt.chart.model.component.Axis,
* org.eclipse.birt.chart.model.component.Label,
* org.eclipse.birt.chart.script.IChartScriptContext)
public void beforeDrawAxisLabel( Axis axis, Label label,
IChartScriptContext icsc )
if (axis.getType() == AxisType.TEXT_LITERAL)
label.getCaption( ).getColor( ).set( 140, 198, 62 );
}else
label.getCaption().getColor( ).set( 208, 32, 0);
* (non-Javadoc)
* @see org.eclipse.birt.chart.script.IChartItemScriptHandler#beforeDrawAxisTitle(org.eclipse.birt.chart.model.component.Axis,
public void beforeDrawAxisTitle( Axis axis, Label label,
}else
and in your code you could do chart.setScript("AxisScript"); Note that this name you be fully qualified. In my example I did not have AxisScript in a package.
Jason
Re: [chart] with multiple categories (on x) [message #916986 is a reply to message #916847] |
Wed, 19 September 2012 13:57   |
In the report example I use row["FILIAL"]+" Week "+row["weekno"] as the expression in the birt design. This would result in category value of something like "SF Week 19". The script splits this up. When the chart engine is used in the BIRT designer it implements its on data set processor that does aggregations, etc before passing the data to the chart engine. So you need to either modify your data before passing it to the chart or implement your own data set process. Here is an example of that:
import java.awt.Graphics;
import java.awt.Graphics2D;
import java.awt.image.BufferedImage;
import org.eclipse.birt.chart.api.ChartEngine;
import org.eclipse.birt.chart.device.IDeviceRenderer;
import org.eclipse.birt.chart.device.IDisplayServer;
import org.eclipse.birt.chart.exception.ChartException;
import org.eclipse.birt.chart.factory.GeneratedChartState;
import org.eclipse.birt.chart.factory.Generator;
import org.eclipse.birt.chart.factory.IDataRowExpressionEvaluator;
import org.eclipse.birt.chart.factory.IGenerator;
import org.eclipse.birt.chart.factory.RunTimeContext;
import org.eclipse.birt.chart.model.Chart;
import org.eclipse.birt.chart.model.ChartWithAxes;
import org.eclipse.birt.chart.model.ChartWithoutAxes;
import org.eclipse.birt.chart.model.attribute.Anchor;
import org.eclipse.birt.chart.model.attribute.Bounds;
import org.eclipse.birt.chart.model.attribute.ChartDimension;
import org.eclipse.birt.chart.model.attribute.DataType;
import org.eclipse.birt.chart.model.attribute.SortOption;
import org.eclipse.birt.chart.model.attribute.impl.BoundsImpl;
import org.eclipse.birt.chart.model.attribute.impl.ColorDefinitionImpl;
import org.eclipse.birt.chart.model.attribute.impl.GradientImpl;
import org.eclipse.birt.chart.model.component.Series;
import org.eclipse.birt.chart.model.component.impl.SeriesImpl;
import org.eclipse.birt.chart.model.data.BaseSampleData;
import org.eclipse.birt.chart.model.data.DataFactory;
import org.eclipse.birt.chart.model.data.OrthogonalSampleData;
import org.eclipse.birt.chart.model.data.Query;
import org.eclipse.birt.chart.model.data.SampleData;
import org.eclipse.birt.chart.model.data.SeriesDefinition;
import org.eclipse.birt.chart.model.data.impl.QueryImpl;
import org.eclipse.birt.chart.model.data.impl.SeriesDefinitionImpl;
import org.eclipse.birt.chart.model.impl.ChartWithAxesImpl;
import org.eclipse.birt.chart.model.impl.ChartWithoutAxesImpl;
import org.eclipse.birt.chart.model.layout.Legend;
import org.eclipse.birt.chart.model.layout.Plot;
import org.eclipse.birt.chart.model.type.LineSeries;
import org.eclipse.birt.chart.model.type.PieSeries;
import org.eclipse.birt.chart.model.type.impl.LineSeriesImpl;
import org.eclipse.birt.chart.model.type.impl.PieSeriesImpl;
import org.eclipse.birt.core.framework.PlatformConfig;
* Test decription:
* </p>
* Chart script: afterDataSetFilled()
* </p>
public class AfterDatasetFilled
private static String OUTPUT = "output/DataRowEvaluator.png";
* The swing rendering device
private IDeviceRenderer dRenderer = null;
private IDisplayServer dServer = null;
private GeneratedChartState gcs = null;
private IGenerator gr = null;
* A chart model instance
private Chart cm = null;
* execute application
* @param args
public static void main( String[] args )
new AfterDatasetFilled( );
System.out.println("finished");
System.exit(0);
* Constructor
public AfterDatasetFilled( )
PlatformConfig pf = new PlatformConfig();
pf.setProperty("STANDALONE", true);
//Returns a singleton instance of the Chart Engine
ChartEngine ce = ChartEngine.instance(pf);
//Returns a singleton instance of the Generator
gr = ce.getGenerator();
try {
//device renderers for dv.SWT, dv.PNG, dv.JPG
//dv.PDF, dv.SVG, dv.SWING, dv.PNG24, div.BMP
dRenderer = ce.getRenderer("dv.PNG");
dServer = dRenderer.getDisplayServer();
} catch (Exception ex) {
ex.printStackTrace();
cm = createChart( );
bindGroupingData( cm );
BufferedImage img = new BufferedImage(
600,
600,
BufferedImage.TYPE_INT_ARGB );
Graphics g = img.getGraphics( );
Graphics2D g2d = (Graphics2D) g;
dRenderer.setProperty( IDeviceRenderer.GRAPHICS_CONTEXT, g2d );
dRenderer.setProperty( IDeviceRenderer.FILE_IDENTIFIER, OUTPUT ); //$NON-NLS-1$
Bounds bo = BoundsImpl.create( 0, 0, 600, 600 );
bo.scale( 72d / dRenderer.getDisplayServer( ).getDpiResolution( ) );
try
gcs = gr.build(
dServer,
cm,
bo,
null,
null,
null );
gr.render( dRenderer, gcs );
catch ( ChartException e )
e.printStackTrace( );
public Chart GetChartModel(){
return cm;
private void bindGroupingData( Chart chart )
//IDataRowExpressionEvaluator
// close, evaluate, first, and next
// Data Set
final Object[][] data =
new Object[][]
{{"x1", new Integer( 1 ), "g1"},
{"x1", new Integer( 2 ), "g2"},
{"x1", new Integer( 3 ), "g1"},
{"x1", new Integer( 4 ), "g3"},
{"x1", new Integer( 5 ), "g2"},
{"x2", new Integer( 6 ), "g1"},
{"x2", new Integer( 7 ), "g3"},
{"x2", new Integer( 8 ), "g2"},
{"x2", new Integer( 9 ), "g2"},
{"x0", new Integer( 0 ), "g2"},};
try
//Binds data to chart model
gr.bindData( new IDataRowExpressionEvaluator( ) {
int idx = 0;
public void close( )
public Object evaluate( String expression )
if ( "X".equals( expression ) )
return data[idx][0];
else if ( "Y".equals( expression ) )
return data[idx][1];
else if ( "G".equals( expression ) )
return data[idx][2];
return null;
public Object evaluateGlobal( String expression )
return evaluate( expression );
public boolean first( )
idx = 0;
return true;
public boolean next( )
idx++;
return ( idx < 9 );
}, chart, new RunTimeContext( ) );
private Chart createChart( )
// X-Axis
Axis xAxisPrimary = cwaBar.getPrimaryBaseAxes( )[0];
xAxisPrimary.setType( AxisType.TEXT_LITERAL );
// Y-Axis
Axis yAxisPrimary = cwaBar.getPrimaryOrthogonalAxis( xAxisPrimary );
yAxisPrimary.setType( AxisType.LINEAR_LITERAL );
// X-Series
Series seCategory = SeriesImpl.create( );
Query xQ = QueryImpl.create( "G" );
seCategory.getDataDefinition( ).add( xQ );
SeriesDefinition sdX = SeriesDefinitionImpl.create( );
xAxisPrimary.getSeriesDefinitions( ).add( sdX );
sdX.getSeries( ).add( seCategory );
sdX.setSorting( SortOption.ASCENDING_LITERAL );
sdX.getGrouping( ).setEnabled( true );
sdX.getGrouping( ).setGroupType( DataType.TEXT_LITERAL );
sdX.getGrouping( ).setAggregateExpression( "Sum" );
sdX.getGrouping( ).setGroupingInterval( 0 );
// Y-Series
LineSeries ls = (LineSeries) LineSeriesImpl.create( );
ls.getLabel( ).setVisible( true );
Query yQ = QueryImpl.create( "Y" );
ls.getDataDefinition( ).add( yQ );
SeriesDefinition sdY = SeriesDefinitionImpl.create( );
Query query = QueryImpl.create( "X" );//$NON-NLS-1$
sdY.setQuery( query );
yAxisPrimary.getSeriesDefinitions( ).add( sdY );
sdY.getSeriesPalette( ).shift( 0 );
sdY.getSeries( ).add( ls );
return cwaBar;
Jason
Re: [chart] with multiple categories (on x) [message #917956 is a reply to message #917478] |
Thu, 20 September 2012 11:42   |
The x-axis does not have two labels, it has one that that the script splits into two lines. From a Java perspective this would look like:
TextDataSet dsStringValue = TextDataSetImpl.create( new String[]{
"SF Week 19", "SF Week 20", "KF Week 19", "KF Week 20", "PF Week 19", "PF Week 20" } );
seCategory.setDataSet( dsStringValue );
So this script:
last = "";
importPackage(
importPackage(
}else{
So for the first label that comes in this line:
puts the week number on top and the Fial number on the bottom. The second label will just put the week number on top:
The reason I posted the afterdatasetfilled example was to show you how the data for a chart could be made to be dynamic if you wanted it to.
Jason
Re: [chart] with multiple categories (on x) [message #919079 is a reply to message #918612] |
Fri, 21 September 2012 13:03   |
public static final Chart createBarChart( )
// Chart Type
cwaBar.setType( "Bar Chart" );
cwaBar.setScript("AxisScriptSplit");
cwaBar.getTitle().setVisible(false);
cwaBar.getBlock( ).setBackground( ColorDefinitionImpl.WHITE( ) );
// Legend
Legend lg = cwaBar.getLegend( );
lg.setVisible( false );
// X-Axis
Axis xAxisPrimary = ( (ChartWithAxesImpl) cwaBar ).getPrimaryBaseAxes( )[0];
xAxisPrimary.getTitle( ).setVisible( false );
xAxisPrimary.getOrigin( ).setType( IntersectionType.VALUE_LITERAL );
//xAxisPrimary.getLabel( ).getCaption( ).setColor(
// ColorDefinitionImpl.GREEN( ).darker( ) );
xAxisPrimary.getLabel( ).getCaption( ).getFont( ).setSize(6);
xAxisPrimary.setLabelSpan(30);
// Y-Axis
Axis yAxisPrimary = ( (ChartWithAxesImpl) cwaBar )
yAxisPrimary.getLabel( ).getCaption( ).setValue( "Sales Growth" ); //$NON-NLS-1$
yAxisPrimary.getLabel( ).getCaption( ).setColor(
ColorDefinitionImpl.BLUE( ) );
yAxisPrimary.getLabel( ).getCaption( ).getFont( ).setSize(6);
yAxisPrimary.getTitle( ).setVisible( false );
yAxisPrimary.getOrigin( ).setType( IntersectionType.VALUE_LITERAL );
NumberDataSet dsNumericValues1 = NumberDataSetImpl
.create( new double[]{43.26, 56.55, 75.25, 47.56, 55.55, 32.1} );
// X-Series
Series seBase = SeriesImpl.create( );
seBase.setDataSet( dsStringValue );
sdX.getSeries( ).add( seBase );
// Y-Series
BarSeries bs = (BarSeries) BarSeriesImpl.create( );
bs.getLabel( ).getCaption( ).setColor( ColorDefinitionImpl.RED( ) );
bs.getLabel( ).setBackground( ColorDefinitionImpl.CYAN( ) );
bs.getLabel( ).setVisible( true );
bs.setDataSet( dsNumericValues1 );
bs.setStacked( false );
sdY.getSeriesPalette( ).update( ColorDefinitionImpl.GREEN( ) );
sdY.getSeries( ).add( bs );
return cwaBar;
Use the following for the AxisScriptSplit class:
public class AxisScriptSplit extends ChartEventHandlerAdapter
String last ="";
String cp =label.getCaption().getValue();
if( cp.substring(0,2).compareToIgnoreCase(last) == 0){
label.getCaption().setValue(cp.substring( (cp.length()-2)));
}else{
label.getCaption().setValue(cp.substring( (cp.length()-2))+"\n\r "+cp.substring(0,2));
last = cp.substring(0,2);
If you put the AxisScriptClass in a package make sure to change the setScript method to include the package name. A pic out the output is attached.
Current Time: Tue Mar 18 10:51:26 EDT 2025
Powered by FUDForum. Page generated in 0.04673 seconds
