Re: [chart]Mixing stacked and unstacked bars [message #908030 is a reply to message #907758] |
Tue, 04 September 2012 15:07 |
Currently I do not believe this is supported. Can you post a
screenshot of what you want it to look like, and I may be able to show
you another way to do this.
Jason
On 9/4/2012 4:57 AM, Missing name Mising name wrote:
> (could be double post - if so delete this, their is something wrong
> here. after submitting a topic or reply i see the post but with no
> contents)
> i just made my first steps with birt charting api. i created some
> stacked and not-stacked (grouped) bar charts, but i need also a mix of
> them: some of the bar series should be stacked and some of the should be
> grouped. how to achieve this?
> (setting some but not all series to bs1.setStacked(true); yields an
> exception ... contains a mix of stacked and unstacked series.)
Re: [chart]Mixing stacked and unstacked bars [message #908072 is a reply to message #908030] |
Tue, 04 September 2012 16:40 |
This is supported if you specify a new series definition for the
unstacked series. You can not mix stacked and unstacked in the same
series definition.
public Chart createStackedBar()
ChartWithAxes cwaBar = ChartWithAxesImpl.create();
cwaBar.setType("Bar Chart"); //$NON-NLS-1$
//cwaBar.setSubType("Stacked"); //$NON-NLS-1$
// Plot
cwaBar.getBlock().setBackground(ColorDefinitionImpl.WHITE());
cwaBar.getBlock().getOutline().setVisible(true);
Plot p = cwaBar.getPlot();
p.getClientArea().setBackground(ColorDefinitionImpl.create(255,
255,
225));
// Title
cwaBar.getTitle()
.getLabel()
.getCaption()
.setValue("Stacked Bar Chart"); //$NON-NLS-1$
// Legend
Legend lg = cwaBar.getLegend();
lg.setItemType(LegendItemType.CATEGORIES_LITERAL);
Axis xAxisPrimary = cwaBar.getPrimaryBaseAxes()[0];
xAxisPrimary.setType(AxisType.TEXT_LITERAL);
xAxisPrimary.getMajorGrid().setTickStyle(TickStyle.BELOW_LITERAL);
xAxisPrimary.getOrigin().setType(IntersectionType.MIN_LITERAL);
// Y-Axis
Axis yAxisPrimary = cwaBar.getPrimaryOrthogonalAxis(xAxisPrimary);
yAxisPrimary.getMajorGrid().setTickStyle(TickStyle.LEFT_LITERAL);
yAxisPrimary.setType(AxisType.LINEAR_LITERAL);
yAxisPrimary.setLabelPosition(Position.RIGHT_LITERAL);
yAxisPrimary.getLabel().getCaption().getFont().setRotation(45);
// Data Set
TextDataSet categoryValues = TextDataSetImpl.create(new String[] {
"Item 1a", "Item 2", "Item 3", "Item 4", "Item 5" }); //$NON-NLS-1$
//$NON-NLS-2$ //$NON-NLS-3$ //$NON-NLS-4$ //$NON-NLS-5$
NumberDataSet orthoValues1 = NumberDataSetImpl.create(new double[] {
25, 35, 15, 5, 20
NumberDataSet orthoValues2 = NumberDataSetImpl.create(new double[] {
5, 10, 25, 10, 5
NumberDataSet orthoValues3 = NumberDataSetImpl.create(new double[] {
15, 12, 28, 10, 25
SampleData sd = DataFactory.eINSTANCE.createSampleData();
BaseSampleData sdBase = DataFactory.eINSTANCE.createBaseSampleData();
sdBase.setDataSetRepresentation("");//$NON-NLS-1$
sd.getBaseSampleData().add(sdBase);
OrthogonalSampleData sdOrthogonal1 = DataFactory.eINSTANCE
.createOrthogonalSampleData();
sdOrthogonal1.setDataSetRepresentation("");//$NON-NLS-1$
sdOrthogonal1.setSeriesDefinitionIndex(0);
sd.getOrthogonalSampleData().add(sdOrthogonal1);
OrthogonalSampleData sdOrthogonal2 = DataFactory.eINSTANCE
sdOrthogonal2.setDataSetRepresentation("");//$NON-NLS-1$
sdOrthogonal2.setSeriesDefinitionIndex(1);
sd.getOrthogonalSampleData().add(sdOrthogonal2);
cwaBar.setSampleData(sd);
// X-Series
Series seCategory = SeriesImpl.create();
seCategory.setDataSet(categoryValues);
SeriesDefinition sdX = SeriesDefinitionImpl.create();
xAxisPrimary.getSeriesDefinitions().add(sdX);
sdX.getSeries().add(seCategory);
sdX.getSeriesPalette().shift(0);
// Y-Series
BarSeries bs1 = (BarSeries) BarSeriesImpl.create();
bs1.setDataSet(orthoValues1);
bs1.getLabel().setVisible(true);
bs1.setLabelPosition(Position.INSIDE_LITERAL);
bs1.setRiserOutline(ColorDefinitionImpl.TRANSPARENT());
BarSeries bs2 = (BarSeries) BarSeriesImpl.create();
bs2.setDataSet(orthoValues2);
bs2.setStacked(true);
bs2.setRiserOutline(ColorDefinitionImpl.TRANSPARENT());
bs2.getLabel().setVisible(true);
bs2.setLabelPosition(Position.INSIDE_LITERAL);
BarSeries bs3 = (BarSeries) BarSeriesImpl.create();
bs3.setDataSet(orthoValues3);
bs3.setStacked(false);
SeriesDefinition sdY = SeriesDefinitionImpl.create();
sdY.getSeriesPalette().shift(0);
yAxisPrimary.getSeriesDefinitions().add(sdY);
SeriesDefinition sdY2 = SeriesDefinitionImpl.create();
sdY2.getSeriesPalette().shift(0);
yAxisPrimary.getSeriesDefinitions().add(sdY2);
sdY.getSeries().add(bs1);
sdY.getSeries().add(bs2);
sdY2.getSeries().add(bs3);
return cwaBar;
Jason
> Jason
>> contents)
FUDForum. Page generated in 0.03938 seconds
