ctrl-c ctrl-v not working in 3.5 [message #11063] |
Mon, 13 July 2009 18:19 |
Originally posted by: jpeltzer.rossvideo.com
Has anyone else had the ctrl-x/ctrl-c/ctrl-v keys stop working in Eclipse
3.5?
They used to work perfectly in my Swing text fields but not anymore.
I have tried this on Java 6 u6 and Java 6 u14.
Confirmation or denials are both welcome responses.
James
Re: ctrl-c ctrl-v not working in 3.5 [message #11074 is a reply to message #11063] |
Wed, 15 July 2009 13:15 |
After further testing/investigation,
To get these keys back, I had to disable the key filter in the
IBindingService. Apparently this will prevent all key bindings from working
(not an overly great solution). Any better workarounds out there?
James
"James Peltzer" <jpeltzer@rossvideo.com> wrote in message
news:h3ftvl$7f6$1@build.eclipse.org...
> 3.5?
> James
Re: ctrl-c ctrl-v not working in 3.5 [message #12478 is a reply to message #12453] |
Thu, 16 July 2009 17:14 |
Thanks for the heads up. I'll repost over there given that this thread
hasn't gotten a lot of action over the past 3 days.
"Grant Gayed" <grant_gayed@ca.ibm.com> wrote in message
news:h3na47$fq1$1@build.eclipse.org...
> If you don't get an answer here then you should ask this on the
> eclipse.platform newsgroup. I know that at least until 3.4.x that one
> step
> that was taken in reaction to Ctrl+C/V/W was to introspect on the focus
> control for copy()/cut()/paste() methods, and this was done specifically
> to
> handle the case of a Swing control like a text field having focus. I'm
> pretty sure that this would not have been intentionally changed in 3.5, so
> there may be a regression that Eclipse UI needs to investigate.
> Grant
> news:h3kkp6$uh8$1@build.eclipse.org...
> working
>> James
> Eclipse
>> > 3.5?
>> > Thanks,
>> > James
FUDForum. Page generated in 0.04551 seconds
