Greate Job! and I have some questions [message #906940] |
Mon, 03 September 2012 01:30 |
I'm very impressed with Graphiti.
Most I like features are:
* Modeled View: PictogramElement and GA. (SVG Export)
* Simplified as Feature Context from All complex GEF things (Tool, EditDomain, EditPart, EditPolicy).
* Declarative Approach. (Incremental Development)
* Many automated feature against of EMF model.
I created commercial GEF plugins for 3 years.
GEF is relatively complex, It's big deal to training my team.
Graphiti is really good alternative solution.
But I have some worries for now:
* Is it really unnecessary to access native library? (likes GEF API)
* I couldn't not find a way to show more appropriate feedback to user.
* Undo / Redo may update pictogram elements which are invisible area.(IE: other drill down context, not in viewport) Can I highlight them or select them?
* SVG Export feature seems not work well with Non-English Text GA. (It was rendered as a image which have little bit broken, with English Text GA, it rendered as SVG Text element)
* Direct editing (F2) works with only selected PE which is located under mouse pointer. Using mouse makes user get slow on their job. Can I change this behavior?
Re: Greate Job! and I have some questions [message #907120 is a reply to message #906940] |
Mon, 03 September 2012 10:20 |
Michael Wenz Messages: 1931 Registered: July 2009 Location: Walldorf, Germany |
Lee, thanks for those flowers! :-)
See my answers below.
Michael
"Jeeeyul Lee" schrieb im Newsbeitrag news:k21179$5gb$1@xxxxxxxxe.org...
Graphiti aims at hiding the underlying library; although we currently only
support GEF, we have the option to replace it with another graphics library
in the futire, e.g. JavaFX. We allow to embed native GEF shapes into a
diagram and have opened ther dedicated APIs to directly access the layer
below. But the rest is emcapsulated on purpose. Just let us know spots were
it hurts and we will check and try to open up if needed.
Could you go into some more details here? Which kind of feedback would you
like to give to users?
them?
DiagramEditor offers a selectPictogramElement method that allows that.
That seems to be a bug. Would you open a bugzilla for this?
this behavior?
Hm, if that's the case, it also appears to be a bug. Would you file that as
a bugzilla as well?
Re: Greate Job! and I have some questions [message #907157 is a reply to message #907120] |
Mon, 03 September 2012 12:21 |
For instance, Consider OrderedLayout or GridLayout in GEF.
When user create or move entry element,
The Insertion Indicator needed to be shown.
I think something likes below will be needed. (not deep thinking)
public interface IFeedbackFeature{
- canShow(IContext)
- showFeedback(IContext)
- hideFeedback(IContext) // may be automatic removing using EMF ChangeRecorder against of Pictogram.
I think most important entry points are creating and moving.
So Selection Tool should have to be updated to support this needs.
FUDForum. Page generated in 0.04043 seconds
