Schema default value not honored for complex type [message #906675] |
Sun, 02 September 2012 06:59 |
Derek Wallace Messages: 5 Registered: March 2012 |
I have a simple schema.
I have some elements with simple type and an element as a complex type. The complex type consists of a number of simple type elements.
All elements have a default value.
When i use the Outline view in Eclipse to add elements, the default value is honored for simple types but not for the elements in the complex type.
Ive attached the .xml file and the .xsd.
If i use File - New - Other - XML and follow the wizard to create the initial .xml based on the schema, it adds the elements (simple and complex) and the default of the simple and complex types are honored.
here is how thie file first looks.
<del:bookstore xmlns:del="xxxxdel" xmlns:xsi="xxxxXMLSchema-instance" xsi:schemaLocation="xxxxxdel example2.del.xsd ">
<del:Simple>789</del:Simple>
<del:SimpleList>DSSEA</del:SimpleList>
<del:Complex>
<del:Age>39</del:Age>
<del:Color>White</del:Color>
</del:Complex>
</del:bookstore>
If i now manually add a 2nd instance of the Simple type (via the Outline window, righ click, add after, Simple) it is correct.
<del:bookstore xmlns:del="xxxxdel" xmlns:xsi="xxxxXMLSchema-instance" xsi:schemaLocation="xxxxdel example2.del.xsd ">
<del:Complex>
</del:Complex>
</del:bookstore>
If i now manually add a 2nd instance of the Complex type (via the Outline window) it is NOT correct.
<del:bookstore xmlns:del="xxxx/del" xmlns:xsi="xxxxXMLSchema-instance" xsi:schemaLocation="xxxxxdel example2.del.xsd ">
<del:Complex>
</del:Complex>
<del:Complex>
<del:Age>del:Age</del:Age>
<del:Color>del:Color</del:Color>
</del:Complex>
</del:bookstore>
Im using Eclipse Helios.
Version: 3.7.1
Build id: M20110909-1335
Thx
Derek
[Updated on: Sun, 02 September 2012 07:04] Report message to a moderator
FUDForum. Page generated in 0.03851 seconds
