Home » Eclipse Projects » EclipseLink » Error on Test #2 JPA/DCN Example Code(Error running example code: EclipseLink/Examples/JPA/DCN)
Error on Test #2 JPA/DCN Example Code [message #906203] |
Fri, 31 August 2012 20:53 |
Julie Schenk Messages: 18 Registered: August 2012 |
Hello. As can be seen at the very bottom of this post, the example starts to run however it fails on the second test. I believe it has to do with the earlier warnings which are indications that things are not being set up properly. I am surprised that the author did not encounter these issues as well. I tried using @IdClass in the OrderLine class to no avail. I don't think it's hurting that the tables are trying to be recreated, even though it puts out errors. I changed the log level from 'FINE' to 'WARNING' but can change it back if necessary. Has anyone seen this problem? Does anyone have any suggestions please? Thanks.
C:\Documents and Settings\schenkjd\My Documents\NetBeansProjects\jpa-dcn>ant example
Buildfile: C:\Documents and Settings\schenkjd\My Documents\NetBeansProjects\jpa-dcn\build.xml
clean:
[delete] Deleting directory C:\Documents and Settings\schenkjd\My Documents\NetBeansProjects\jpa-dcn\classes
init:
[mkdir] Created dir: C:\Documents and Settings\schenkjd\My Documents\NetBeansProjects\jpa-dcn\classes
build:
[echo] org.eclipse.persistence.example.jpa.databaseevent: C:\Documents and Settings\schenkjd\My Documents\NetBeansProjects\jpa-dcn\build.xml
[javac] C:\Documents and Settings\schenkjd\My Documents\NetBeansProjects\jpa-dcn\build.xml:24: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds
[javac] Compiling 4 source files to C:\Documents and Settings\schenkjd\My Documents\NetBeansProjects\jpa-dcn\classes
[copy] Copying 1 file to C:\Documents and Settings\schenkjd\My Documents\NetBeansProjects\jpa-dcn\classes\META-INF
example:
[java] [EL Warning]: metadata: 2012-08-31 16:35:07.192--ServerSession(30199356)--You have specified multiple ids for the entity class [model.OrderLine] without specifying an @IdClass. By doing this you may lose the ability to find by identity, distributed cache support etc. Note: You may however use entity manager find operations by passing a list of primary key fields. Else, you will have touse JPQL queries to read your entities. For other id options see @PrimaryKey.
[java] [EL Warning]: metadata: 2012-08-31 16:35:07.27--ServerSession(32392776)--You have specified multiple ids for the entity class [model.OrderLine] without specifying an @IdClass. By doing this you may lose the ability to find by identity, distributed cache support etc. Note: You may however use entity manager find operations by passing a list of primary key fields. Else, you will have touse JPQL queries to read your entities. For other id options see @PrimaryKey.
[java] Setting up database.
[java] [EL Warning]: metadata: 2012-08-31 16:35:07.301--ServerSession(25589390)--You have specified multiple ids for the entity class [model.OrderLine] without specifying an @IdClass. By doing this you may lose the ability to find by identity, distributed cache support etc. Note: You may however use entity manager find operations by passing a list of primary key fields. Else, you will have to use JPQL queries to read your entities. For other id options see @PrimaryKey.
[java] [EL Warning]: sql: 2012-08-31 16:35:09.52--ServerSession(25589390)--
java.sql.SQLSyntaxErrorException: ORA-00942: table or view does not exist
[java]
[java] Setup complete.
[java] [EL Warning]: metadata: 2012-08-31 16:36:00.661--ServerSession(28819334)--You have specified multiple ids for the entity class [model.OrderLine] without specifying an @IdClass. By doing this you may lose the ability to find by identity, distributed cache support etc. Note: You may however use entity manager find operations by passing a list of primary key fields. Else, you will have to use JPQL queries to read your entities. For other id options see @PrimaryKey.
[java] [EL Warning]: metadata: 2012-08-31 16:36:00.677--ServerSession(11147203)--You have specified multiple ids for the entity class [model.OrderLine] without specifying an @IdClass. By doing this you may lose the ability to find by identity, distributed cache support etc. Note: You may however use entity manager find operations by passing a list of primary key fields. Else, you will have to use JPQL queries to read your entities. For other id options see @PrimaryKey.
[java] [EL Warning]: 2012-08-31 16:36:01.927--ServerSession(28819334)--Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.4.0.v20120608-r11652): org.eclipse.persistence.exceptions.DatabaseException
[java] Internal Exception: java.sql.SQLSyntaxErrorException: ORA-00955: name is already used by an existing object
[java]
[java] Error Code: 955
[java] Call: CREATE TABLE DBE_ORDER (ORDER_ID NUMBER(19) NOT NULL, DESCRIPT
ION VARCHAR2(255) NULL, TOTALCOST NUMBER(38) NULL, VERSION NUMBER(19) NULL, CUST
OMER_ID NUMBER(19) NULL, PRIMARY KEY (ORDER_ID))
[java] Query: DataModifyQuery(sql="CREATE TABLE DBE_ORDER (ORDER_ID NUMBER(
19) NOT NULL, DESCRIPTION VARCHAR2(255) NULL, TOTALCOST NUMBER(38) NULL, VERSION
NUMBER(19) NULL, CUSTOMER_ID NUMBER(19) NULL, PRIMARY KEY (ORDER_ID))")
[java] [EL Warning]: 2012-08-31 16:36:15.505--ServerSession(28819334)--Exce
[java]
[java] Call: CREATE TABLE DBE_ORDERLINE (LINENUMBER NUMBER(10) NOT NULL, CO
ST NUMBER(38) NULL, DESCRIPTION VARCHAR2(255) NULL, ORDER_ID NUMBER(19) NOT NULL
, PRIMARY KEY (LINENUMBER, ORDER_ID))
[java] Query: DataModifyQuery(sql="CREATE TABLE DBE_ORDERLINE (LINENUMBER N
UMBER(10) NOT NULL, COST NUMBER(38) NULL, DESCRIPTION VARCHAR2(255) NULL, ORDER_
ID NUMBER(19) NOT NULL, PRIMARY KEY (LINENUMBER, ORDER_ID))")
[java] [EL Warning]: 2012-08-31 16:36:15.63--ServerSession(28819334)--Excep
org.eclipse.persistence.exceptions.DatabaseException: org.eclipse.persistence.exceptions.DatabaseException
[java]
[java] Call: CREATE TABLE DBE_CUSTOMER (ID NUMBER(19) NOT NULL, NAME VARCHA
R2(255) NULL, VERSION NUMBER(19) NULL, PRIMARY KEY (ID))
[java] Query: DataModifyQuery(sql="CREATE TABLE DBE_CUSTOMER (ID NUMBER(19)
NOT NULL, NAME VARCHAR2(255) NULL, VERSION NUMBER(19) NULL, PRIMARY KEY (ID))")
[java] [EL Warning]: 2012-08-31 16:24:29.367--ServerSession(11147203)--Exce
[java] Internal Exception: java.sql.SQLSyntaxErrorException: ORA-02275: such a referential constraint already exists in the table
[java]
[java] Error Code: 2275
[java] Call: ALTER TABLE DBE_ORDER ADD CONSTRAINT FK_DBE_ORDER_CUSTOMER_ID
FOREIGN KEY (CUSTOMER_ID) REFERENCES DBE_CUSTOMER (ID)
[java] Query: DataModifyQuery(sql="ALTER TABLE DBE_ORDER ADD CONSTRAINT FK_
DBE_ORDER_CUSTOMER_ID FOREIGN KEY (CUSTOMER_ID) REFERENCES DBE_CUSTOMER (ID)")
[java] [EL Warning]: 2012-08-31 16:24:29.539--ServerSession(11147203)--Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.4.0.v20120608-r11652) : org.eclipse.persistence.exceptions.DatabaseException
[java]
[java] Call: ALTER TABLE DBE_ORDERLINE ADD CONSTRAINT FK_DBE_ORDERLINE_ORDE
R_ID FOREIGN KEY (ORDER_ID) REFERENCES DBE_ORDER (ORDER_ID)
[java] Query: DataModifyQuery(sql="ALTER TABLE DBE_ORDERLINE ADD CONSTRAINT
FK_DBE_ORDERLINE_ORDER_ID FOREIGN KEY (ORDER_ID) REFERENCES DBE_ORDER (ORDER_ID
[java] [EL Warning]: 2012-08-31 16:24:29.742--ServerSession(11147203)--Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.4.0.v20120608-r11652): org.eclipse.persistence.exceptions.DatabaseException
[java]
[java] Call: CREATE TABLE SEQUENCE (SEQ_NAME VARCHAR2(50) NOT NULL, SEQ_COUNT NUMBER(38) NULL, PRIMARY KEY (SEQ_NAME))
[java] Query: DataModifyQuery(sql="CREATE TABLE SEQUENCE (SEQ_NAME VARCHAR2
(50) NOT NULL, SEQ_COUNT NUMBER(38) NULL, PRIMARY KEY (SEQ_NAME))")
[java]
[java]
[java] Starting example.
[java]
[java]
[java] Selecting all customer on application #2.
[java]
[java]
[java] Inserting new customer on application #1.
[java]
[java]
[java] Selecting new customer on application #2.
[java]
[java]
[java] Customer name on application #1: Test1
[java] Customer name on application #2: Test1
[java]
[java]
[java] Updating customer name to 'Test2' on application #1.
[java]
[java]
[java] Selecting customer on application #2.
[java]
[java]
[java] Customer name on application #1: Test2
[java] java.lang.RuntimeException: Test #2 failed
[java] at example.Example.run(Example.java:116)
[java] at example.Example.main(Example.java:35)
BUILD SUCCESSFUL
Total time: 1 minute 30 seconds
Re: Error on Test #2 JPA/DCN Example Code [message #908104 is a reply to message #906203] |
Tue, 04 September 2012 18:23 |
Chris Delahunt Messages: 1389 Registered: July 2009 |
Logging for the OracleChangeNotificationListener class only occurs at the Finest level, and any messages that might indicate why the listener is not being registered are being lost.
Please upload the log with the level set to FINEST or ALL. You might also try increasing the value used for the SLEEP variable in the test to make sure it is not a delay in the database change event processing.
Best Regards,
Chris
[Updated on: Tue, 04 September 2012 18:28] Report message to a moderator
Re: Error on Test #2 JPA/DCN Example Code [message #908161 is a reply to message #908104] |
Tue, 04 September 2012 21:10 |
Thank you for the message. I did both things- increased the sleep time and changed the log level to 'FINEST'. Following is the tail- hope it is enough but not too much (see end please).
I actually did some digging myself and notice that "ORA-29970: Specified registration id does not exist" indicates that I might need to "Clear out Change Notification Registrations". I have asked my DBA if he's willing to do that. Could the connection pool have passed an incorrect regid value to the dbms_chnf procedure? Any additional thoughts and suggestions are much welcomed and appreciated.
Here's the end of the log messages:
in])--JavaSECMPInitializer - global instrumentation is null.
[java] [EL Finest]: jpa: 2012-09-04 16:15:12.551--ServerSession(2978880)--Thread(Thread[main,5,main])--Begin predeploying Persistence Unit order2; session
order2; state Predeployed; factoryCount 0
[java] [EL Finest]: jpa: 2012-09-04 16:15:12.567--ServerSession(2978880)--Thread(Thread[main,5,main])--End predeploying Persistence Unit order2; session order2; state Predeployed; factoryCount 1
[java] [EL Warning]: 2012-09-04 16:15:13.833--ServerSession(29326115)--Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.4.0.v20120608-r11652): org.eclipse.persistence.exceptions.DatabaseException
[java]
[java] [EL Warning]: 2012-09-04 16:15:14.02--ServerSession(29326115)--Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.4.0.v20120608-r11652):
[java]
[java] Query: DataModifyQuery(sql="CREATE TABLE DBE_ORDERLINE (LINENUMBER NUMBER(10) NOT NULL, COST NUMBER(38) NULL, DESCRIPTION VARCHAR2(255) NULL, ORDER_
[java] [EL Warning]: 2012-09-04 16:15:14.27--ServerSession(29326115)--Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.4.0.v20120608-r11652):
[java]
[java] [EL Warning]: 2012-09-04 16:15:14.473--ServerSession(29326115)--Exce
[java]
[java] [EL Warning]: 2012-09-04 16:15:14.583--ServerSession(29326115)--Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.4.0.v20120608-r11652): org.eclipse.persistence.exceptions.DatabaseException
[java]
[java] [EL Warning]: 2012-09-04 16:15:14.801--ServerSession(29326115)--Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.4.0.v20120608-r11652)
[java]
[java]
[java]
[java]
[java]
[java] [EL Finest]: jpa: 2012-09-04 16:15:15.129--ServerSession(2978880)--Thread(Thread[main,5,main])--Begin deploying Persistence Unit order2; session order2; state Predeployed; factoryCount 1
[java] [EL Finer]: 2012-09-04 16:15:15.129--ServerSession(2978880)--Thread(
Thread[main,5,main])--Could not initialize Validation Factory. Encountered following exception: java.lang.NoClassDefFoundError: javax/validation/Validation
[java] [EL Finest]: properties: 2012-09-04 16:15:15.129--ServerSession(2978
880)--Thread(Thread[main,5,main])--property=eclipselink.logging.level; value=FINEST; translated value=FINEST
[java] [EL Finest]: properties: 2012-09-04 16:15:15.223--ServerSession(2978
880)--Thread(Thread[main,5,main])--property=javax.persistence.jdbc.user; value=f
pa_dev
[java] [EL Finest]: properties: 2012-09-04 16:15:15.223--ServerSession(2978880)--Thread(Thread[main,5,main])--property=javax.persistence.jdbc.password; value=xxxxxx
[java] [EL Finest]: properties: 2012-09-04 16:15:15.239--ServerSession(2978880)--Thread(Thread[main,5,main])--property=javax.persistence.jdbc.driver; value
=oracle.jdbc.OracleDriver
[java] [EL Finest]: properties: 2012-09-04 16:15:15.254--ServerSession(2978
880)--Thread(Thread[main,5,main])--property=javax.persistence.jdbc.url; value=jd
bc:oracle:thin:@scladb08.fuel.wec.com:1521:dev
880)--Thread(Thread[main,5,main])--property=eclipselink.cache.database-event-lis
tener; value=org.eclipse.persistence.platform.database.oracle.dcn.OracleChangeNo
tificationListener
[java] [EL Info]: 2012-09-04 16:15:15.254--ServerSession(2978880)--Thread(Thread[main,5,main])--EclipseLink, version: Eclipse Persistence Services - 2.4.0.v20120608-r11652
[java] [EL Finest]: dbPlatformHelper_regExprDbPlatform: 2012-09-04 16:15:15
.864--Thread(Thread[main,5,main])--(?i)oracle.*11 (There is no English translati
on for this message.)
[java] [EL Fine]: connection: 2012-09-04 16:15:15.864--Thread(Thread[main,5,main])--Detected database platform: org.eclipse.persistence.platform.database.o
racle.Oracle11Platform
[java] [EL Config]: connection: 2012-09-04 16:15:15.895--ServerSession(2978880)--Connection(6447371)--Thread(Thread[main,5,main])--connecting(DatabaseLogin(
[java] platform=>Oracle11Platform
[java] user name=> ""
[java] datasource URL=> "jdbc:oracle:thin:@:1521:dev"
[java] ))
[java] [EL Config]: connection: 2012-09-04 16:15:16.426--ServerSession(2978880)--Connection(13709034)--Thread(Thread[main,5,main])--Connected: jdbc:oracle:thin:@:1521:dev
[java] User: FPA_DEV
[java] Database: Oracle Version: Oracle Database 11g Enterprise Edition Release 11.2.0.3.0 - 64bit Production
[java] With the Partitioning, OLAP, Data Mining and Real Application Testing options
[java] Driver: Oracle JDBC driver Version: 11.2.0.3.0
[java] [EL Finest]: connection: 2012-09-04 16:15:16.426--ServerSession(2978880)--Connection(13709034)--Thread(Thread[main,5,main])--Connection acquired from connection pool [default].
[java] [EL Finest]: connection: 2012-09-04 16:15:16.52--ServerSession(2978880)--Connection(13709034)--Thread(Thread[main,5,main])--Connection released to connection pool [default].
[java] [EL Finest]: sequencing: 2012-09-04 16:15:16.52--ServerSession(2978880)--Thread(Thread[main,5,main])--sequencing connected, state is Preallocation_Transaction_NoAccessor_State
[java] [EL Finest]: sequencing: 2012-09-04 16:15:16.52--ServerSession(2978880)--Thread(Thread[main,5,main])--sequence ORD_SEQ: preallocation size 50
[java] [EL Finest]: sequencing: 2012-09-04 16:15:16.52--ServerSession(2978880)--Thread(Thread[main,5,main])--sequence CUST_SEQ: preallocation size 50
[java] [EL Info]: connection: 2012-09-04 16:15:16.536--ServerSession(2978880)--Thread(Thread[main,5,main])--order2 login successful
[java] [EL Finest]: connection: 2012-09-04 16:15:16.536--ServerSession(2978880)--Thread(Thread[main,5,main])--Registering for database change event notification.
[java] [EL Finest]: connection: 2012-09-04 16:15:16.723--ServerSession(2978880)--Thread(Thread[main,5,main])--Registering table [DBE_CUSTOMER] for database
[java] [EL Finer]: metamodel: 2012-09-04 16:15:16.739--ServerSession(297888
0)--Thread(Thread[main,5,main])--Canonical Metamodel class [model.OrderLine_] not found during initialization.
0)--Thread(Thread[main,5,main])--Canonical Metamodel class [model.Order_] not fo
[java] [EL Finer]: metamodel: 2012-09-04 16:15:16.77--ServerSession(2978880
)--Thread(Thread[main,5,main])--Canonical Metamodel class [model.Customer_] not
[java] [EL Finest]: jpa: 2012-09-04 16:15:16.77--ServerSession(2978880)--Th
read(Thread[main,5,main])--End deploying Persistence Unit order2; session order2
; state Deployed; factoryCount 1
[java] [EL Finer]: connection: 2012-09-04 16:15:16.77--ServerSession(297888
0)--Thread(Thread[main,5,main])--client acquired: 24615045
[java] [EL Finer]: transaction: 2012-09-04 16:15:16.77--ClientSession(24615
045)--Thread(Thread[main,5,main])--acquire unit of work: 12482247
[java] [EL Finest]: query: 2012-09-04 16:15:16.77--UnitOfWork(12482247)--Th
read(Thread[main,5,main])--Execute query ReadAllQuery(referenceClass=Customer sql="SELECT ID, NAME, VERSION, ROWID FROM DBE_CUSTOMER")
[java] [EL Finest]: connection: 2012-09-04 16:15:16.77--ServerSession(2978880)--Connection(13709034)--Thread(Thread[main,5,main])--Connection acquired from
[java] [EL Fine]: sql: 2012-09-04 16:15:16.77--ServerSession(2978880)--Connection(13709034)--Thread(Thread[main,5,main])--SELECT ID, NAME, VERSION, ROWID FROM DBE_CUSTOMER
[java] [EL Finest]: connection: 2012-09-04 16:15:17.411--ServerSession(2978
[java]
[java]
[java]
[java]
[java] [EL Finer]: connection: 2012-09-04 16:16:57.772--ServerSession(29788
80)--Thread(Thread[main,5,main])--client acquired: 8861475
[java] [EL Finer]: transaction: 2012-09-04 16:16:57.772--ClientSession(8861
475)--Thread(Thread[main,5,main])--acquire unit of work: 20245380
[java] [EL Finest]: query: 2012-09-04 16:16:57.772--UnitOfWork(20245380)--T
hread(Thread[main,5,main])--Execute query ReadObjectQuery(referenceClass=Custome
r jpql="Select c from Customer c where c.id = 201")
[java] [EL Finest]: connection: 2012-09-04 16:16:57.772--ServerSession(2978
[java] [EL Fine]: sql: 2012-09-04 16:16:57.819--ServerSession(2978880)--Con
FROM DBE_CUSTOMER WHERE (ID = ?)
[java] bind => [201]
[java] [EL Finest]: connection: 2012-09-04 16:16:57.866--ServerSession(2978
[java]
[java]
[java]
[java]
[java]
[java]
[java] [EL Finer]: connection: 2012-09-04 16:18:37.977--ServerSession(2978880)--Thread(Thread[main,5,main])--client acquired: 11382417
[java] [EL Finer]: transaction: 2012-09-04 16:18:37.977--ClientSession(11382417)--Thread(Thread[main,5,main])--acquire unit of work: 10479694
[java] [EL Finest]: query: 2012-09-04 16:18:37.993--UnitOfWork(10479694)--Thread(Thread[main,5,main])--Execute query ReadObjectQuery(referenceClass=Custome
[java] [EL Finest]: transaction: 2012-09-04 16:18:37.993--UnitOfWork(10479694)--Thread(Thread[main,5,main])--Register the existing object model.Customer@4c71d2
[java]
[java]
[java] Local Exception Stack:
[java] Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.4.0.v20120608-r11652): org.eclipse.persistence.exceptions.DatabaseException
[java] Internal Exception: java.sql.SQLException: ORA-29970: Specified registration id does not exist
[java]
[java] Error Code: 29970
[java] at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:324)
[java] at org.eclipse.persistence.platform.database.oracle.dcn.OracleChangeNotificationListener.remove(OracleChangeNotificationListener.java:249)
[java] at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.logout(DatabaseSessionImpl.java:888)
[java] at org.eclipse.persistence.sessions.server.ServerSession.logout(ServerSession.java:748)
[java] at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.removeSessionFromGlobalSessionManager(EntityManagerSetupImpl.java:396)
[java] at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.undeploy(EntityManagerSetupImpl.java:2392)
[java] at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.close(EntityManagerFactoryDelegate.java:249)
[java] at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.close(EntityManagerFactoryImpl.java:267)
[java] at example.Example.run(Example.java:192)
[java] Caused by: java.sql.SQLException: ORA-29970: Specified registration id does not exist
[java]
[java] at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:445)
[java] at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:389)
[java] at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:382)
[java] at oracle.jdbc.driver.T4CTTIfun.processError(T4CTTIfun.java:600)
[java] at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:450)
[java] at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:192)
[java] at oracle.jdbc.driver.T4CTTIokpn.doOKPN(T4CTTIokpn.java:282)
[java] at oracle.jdbc.driver.T4CConnection.doUnregisterDatabaseChangeNotification(T4CConnection.java:4560)
[java] at oracle.jdbc.driver.T4CConnection.doUnregisterDatabaseChangeNo\tification(T4CConnection.java:4606)
[java] at oracle.jdbc.driver.PhysicalConnection.unregisterDatabaseChang
eNotification(PhysicalConnection.java:10624)
angeNotificationListener.remove(OracleChangeNotificationListener.java:247)
[java] ... 8 more
[java] [EL Config]: metadata: 2012-09-04 16:15:12.52--ServerSession(2978880
)--Thread(Thread[main,5,main])--The foreign key column name for the mapping elem
Re: Error on Test #2 JPA/DCN Example Code [message #987450 is a reply to message #964508] |
Mon, 26 November 2012 16:32 |
Hello again. I was able to work with the DBA to try both suggestions from 9/11 of restarting the DB and trying a different install. Unfortunately neither of those helped and I received the same result. I am walking through the code and log in Netbeans and have read the 'Oracle Database Change Notification documentation' link at the bottom of the example and am coming up with some additional thoughts and questions. I can see the DBE_CUSTOMER table being registered for the database change notifications a few times however only on queries. In particular, I see a registration during the query prior to the insertion of the first customer however I do NOT see it during the very next query, the one after the insertion of the first customer. MAYBE that's o.k. since the 'Oracle Database Change Notification documentation' specifies that Associating a Query with a Registration "is a one-time process". What could be a problem is that the insertion of the customer does not log any DCN events that I can see. The documentation indicates that a listener should have been set up to 'Notifying Database Change Events'. I'm assuming that the persistence code uses the example code or similar to that in the documentation link so I'm considering downloading the source and having a look. Any feedback as to if I'm on the right track here would be most appreciated.
I suppose perhaps this is obvious but I guess either the DatabaseChangeEvent isn't being fired by the insert or the DatabaseChangeListener isn't set up correctly to receive it.
I see some places where the eventManager is null in UnitOfWorkImpl.commitAndResume and I'm not sure if that is supposed to be instantiated or not...
[Updated on: Mon, 26 November 2012 19:45] Report message to a moderator
Re: Error on Test #2 JPA/DCN Example Code [message #987693 is a reply to message #987450] |
Tue, 27 November 2012 16:10 |
I don't see anything unexpected in the log. The only guesses I have are,
1 - you are somehow dropping-replacing the tables after registering for them. I don't see this in the log, but can you start the example with the tables already created (don't drop the schema).
2 - the change events from the database are either not getting through, or very slow to get through. Try increasing the sleep time in the example. Also try a basic JDBC test of your database to see if DCN is working.
James : Wiki : Book : Blog : Twitter
Current Time: Thu Sep 26 01:48:03 GMT 2024
Powered by FUDForum. Page generated in 0.06013 seconds
