Home » Archived » BIRT » Applet jar requirements for BIRT (4.2) ReportEngine
Applet jar requirements for BIRT (4.2) ReportEngine [message #906016] Fri, 31 August 2012 09:23 Go to next message
Hello.
I want to (need to) write an Applet that allows me to generate parametrised reports (in PDF format) using a Java Applet, but I cannot find anything online that tells me what dependencies (BIRT jar files) need to deployed along with it.
As you'll know I have to list the jars in the applet tag of the web page but I can't find a list of the jars needed. I know the required jar files vary depending on the abilities of my reports (which include charts), but even a minimal list of core required jar files is very elusive.
Can anyone help me here either in the form of a link or a list of jar files that I need to make available.
Bill
Re: Applet jar requirements for BIRT (4.2) ReportEngine [message #906202 is a reply to message #906016] Fri, 31 August 2012 16:49 Go to previous messageGo to next message
Bill
If you download the birt runtime, the required jars are in the
reportengine/lib directory. You can remove data source jars that you do
not need as a start.
Jason
On 8/31/2012 9:23 AM, Bill Moo wrote:
> Hello.
> elusive.
> Bill
Re: Applet jar requirements for BIRT (4.2) ReportEngine [message #907233 is a reply to message #906202] Mon, 03 September 2012 11:31 Go to previous messageGo to next message
Thanks for the time Jason. I've downloaded the runtime and copied the runtime_4.2 jar file to the same place as my web page containing the applet.
I've added the jar file to the archive attribute, but I now get an error at start up saying it can't find :
org/eclipse/core/runtime/CoreException
System.out.println("Starting...");
eConfig = new EngineConfig() ;
eConfig.setLogConfig(HOME + "/", Level.SEVERE) ;
eConfig.setLogFile("BirtLog.log") ;
eConfig.setTempDir(HOME);
try {
	System.out.println("Creating Platform Config");
	pConfig = new PlatformConfig() ;
	eConfig.setPlatformContext(new PlatformFileContext(pConfig)) ;
	Platform.startup(eConfig) ;
	System.out.println("Creating Report Factory");
	eFactory = (IReportEngineFactory) Platform.createFactoryObject(IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY) ;
System.out.println("Creating Report Engine");
rEngine = eFactory.createReportEngine(eConfig) ;
catch (BirtException e)
	e.printStackTrace() ;
I would really appreciate some help here I'm making no progress whatsoever.
Java Plug-in 10.7.0.10
Using JRE version 1.7.0_07-b10 Java HotSpot(TM) 64-Bit Server VM
Bill
Re: Applet jar requirements for BIRT (4.2) ReportEngine [message #908023 is a reply to message #907233] Tue, 04 September 2012 10:58 Go to previous message
Bill
Start off by trying to add all the jars from the
\birt-runtime-4_2_0\ReportEngine\lib directory. You can prune them once
you get it working.
Jason
> applet.
> try {
Previous Topic:apache.commons.io dependency problem
Next Topic:Problem charting datetime
Current Time: Sun May 18 04:30:37 EDT 2025
Powered by FUDForum. Page generated in 0.03629 seconds
