Home » Language IDEs » Java Development Tools (JDT) » including other dependencies?
| including other dependencies? [message #120489] |
Mon, 24 November 2003 17:05  |
Originally posted by: list.redpoint.org.uk
I've just been playing with eclipse 2.1.2 and JDT to see how it manages an
existing Java project ... but as yet I can't get it to build.
Normally I just set:
export CLASSPATH=/home/fred/some/directory/with/the/classes:$CLASSP ATH
export LD_LIBRARY_PATH=/home/fred/some/directory/with/compiled/bina ries
and from then on my java is happy as it can find the files and the jni
libs it needs when compiling and running the app.
I've spent a few hours now trying to get it to build from within eclipse
and little to show for it other than a lot of failed import statments. All
I need to do is add the classpath to the project setting in some way, I
seem to be able to find some stuff that looks like it needs the classes to
be in a .jar (they arent) and evertying else seems to expect the classes
to be in another eclipse project (they arent) ...
Any help gratefully rx.
Oh, and when importing some files scattered around the disk into a
project, how do you stop eclipse generating the (totally irrelevant) set
of parent directories? ... eg just because the files I want to import into
the projects are deep, deep in a directory tree, I dont want all the
subdirs generated ... i just want to import the files themselves into a
folder.
thanks.
| Re: including other dependencies? [message #120577 is a reply to message #120489] |
Mon, 24 November 2003 20:19   |
Hi Robin,
Did you already try going to the Project Properties page to add the
proper classpath?
To be precise, right click on the project, select Properties, click on
Java Build Path. Go to tab Libraries, and try either Add External JARs
.... or Add Class Folder ...
As for the import, Eclipse will always start importing the structure
under the "root" that you specifies. In other works, make sure you
specify the direct container of what you want to import in the "From
directory:" field, and you should be ok.
Hope this helps.
Mike K.
robin wrote:
> folder.
> thanks.
| Re: including other dependencies? [message #121621 is a reply to message #120577] |
Tue, 25 November 2003 06:48   |
Michael Y Kwong wrote:
> Hi Robin,
> proper classpath?
yes ... this does not seem to work. The classes are not in a JAR so the
'add external JAR' is not appropriate, and the 'add class folder' is only
appropriate for folders within the eclipse workspace. The classes are
actually in /usr/local/.... as they are on production machines that my
software runs on, and you cannot navigate outside the eclipse workspace to
/usr/local using the Add Class Folder tool ...
hmmm ... ok so lets say I want to import some classes that currently
reside in /home/robin/projects/test/version2/source/*.java
I have created a new project called 'Test' and a folder in it called
'core' and I'd like to get the java files from above imported directly
into the 'core' folder. I dont need the structure below them
(/home/robin/projects/test/version2/source) as that is just where they
happen to be at the moment, but everything I have tried so far results in
creating all the underlying folders within the eclipse project workspace.
Ive tried both the 'create complete folder structure' and 'create selected
folders only' and the result seems to be the same. Even in 'create
selected folders only' all the parent folders are 'ticked' in the
selection tool, and you cannot de-select them without deselecting the
folder you actually want ...
> Hope this helps.
> Mike K.
> robin wrote:
> > Hi,
> > folder.
> > thanks.
| Re: including other dependencies? [message #121644 is a reply to message #120577] |
Tue, 25 November 2003 07:26   |
ahh OK .. I got that to work. I was just clicking on the icons in the
browse window, It worked when I got the right combination of stuff in
those windows .. I hadnt appreciated that you needed to get the path in th
top window right as well as the clicking in the file select window, i had
assumed that the text entry was a duplicate of the file select ..
anyway that bit worked out, its just the external classes that remain ..
> Hope this helps.
> Mike K.
> robin wrote:
> > Hi,
> > folder.
> > thanks.
| Re: including other dependencies? [message #121696 is a reply to message #120489] |
Tue, 25 November 2003 09:50  |
Originally posted by: eclipse-user.jibeinc.com
robin wrote:
The best approach is to create a Project in Eclipse to hold your source
code. If you have a "common" set and then application-specfic sets that
depend on "common", create separate Projects for "common" and then a
Project for each application.
I strongly recommend you spend the time to go through the Tutorial that
comes with the installed Eclipse help. It will give you the overview
information you need to understand how Eclipse works with Projects as
well as external classes.
BTW, you can include external classes in your Project Build Path by
defining a Java Classpath Variable in the Preferences and then adding
that variable to your Project's Java Build Path. But that is like going
from New York to Chicago via Los Angeles - not the best route.
Use Projects in Eclipse - they are your friend.
HTH,
Eric
Eric Rizzo
Software Architect
Jibe, Inc.
http://www.jibeinc.com
Current Time: Mon Nov 03 10:48:04 EST 2025
Powered by FUDForum. Page generated in 0.40484 seconds
