Home » Archived » BIRT » How to locate the connection profile store when BIRT running in a web app?
How to locate the connection profile store when BIRT running in a web app? [message #904400] Tue, 28 August 2012 11:27 Go to next message
Paul Ramsden is currently offline Paul RamsdenFriend
Member
BIRT 3.7.2
WebSphere 7
I recently deployed BIRT into an existing web app. I copied all the jars etc and wrote a servlet which handles report requests. Note I am *not* using the BirtViewer.
All reports have a common library which makes use of a connection profile store. This store contains all connection profiles for test and production environments. The 2 data sources I have defined use scripts to find the profile store file and to determine the profile name (test/prod).
Store file name:
function getProfilePath() {
	if(reportContext.getHttpServletRequest() != null) {
		var rp = reportContext.getHttpServletRequest().getSession().getServletContext().getRealPath("connectionStore.xml");
		if( rp != null ){
			return rp;
	return "connectionStore.xml";
Profile name (for DB/2):
function getDb2Profile(runtime) {
	var p = params["__runtime"].value;
	p = p.toLowerCase();
	if(p== 'prod') {
		return 'MVSDB2P';
	} else {
		return 'MVSDB2T';
The problem I have is that the file is not found at runtime. The value of 'reportContext.getHttpServletRequest()' is null and the path is then incorrect.
My (temporary) solution is to hard-code the return value in the getProfilePath() function on each platform. This proves everything else is working but I need a better solution.
Why is the getHttpServletRequest value empty? Could I set a path in the servlet init() function which could be used later?
[Updated on: Tue, 28 August 2012 11:30]
Report message to a moderator
Re: How to locate the connection profile store when BIRT running in a web app? [message #904626 is a reply to message #904400] Tue, 28 August 2012 21:04 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Paul
If you are writting your own servlet you have to add the request to the
appcontext like:
task.getAppContext().put(EngineConstants.APPCONTEXT_BIRT_VIEWER_HTTPSERVET_REQUEST,
request );
Jason
On 8/28/2012 7:27 AM, Paul Ramsden wrote:
> BIRT 3.7.2
> WebSphere 7
> (test/prod).
> Store file name:
> var rp =
> if( rp != null ){
> return rp;
> if(p== 'prod') {
> return 'MVSDB2P';
> } else {
> return 'MVSDB2T';
> incorrect.
Re: How to locate the connection profile store when BIRT running in a web app? [message #904814 is a reply to message #904626] Wed, 29 August 2012 07:47 Go to previous message
Member
Thanks! Works fine.
Previous Topic:including a Birt report to a JSF application (howto?)
Next Topic:[CentOS/Tomcat] Birt Viewer JDBC configured in XML
Current Time: Wed Mar 29 13:31:50 GMT 2023
Powered by FUDForum. Page generated in 0.01913 seconds
