BIRT usage of Web Services [message #904313] |
Tue, 28 August 2012 04:16  |
Many thanks for any information you can provide Jason Weathersby.
I have a couple of questions with regards to the run time architecture of BIRT, specifically with regards to what calls are made when BIRT reports are run asynchronously via AJAX calls.
The background is that a production system was running slowly, it was found that some Web Service calls were causing threads to hang or to return very slowly (4 hours) to the WebSphere thread pool. The BIRT Viewer is deployed as a separate Web Application on WebSphere, with BIRT reports being integrated into the Main Application via client side aggregation, i.e. the main application embeds BIRT charts via embedded URL calls to the BIRT Viewer application..
For the threads that were running very slowly, the Wepshere log files contain stack traces from BIRT where the "axis" package names appeared with the BIRT stack trace. My assumption was that BIRT uses some axis API's internally to support AJAX or some other purposes, can you confirm that no web service calls are made as part of the run time invocation of a BIRT report.
Have you seen any other production system issues similar to the one we are seeing?
We are also reviewing to see if we can allocate a seperate thread pool to the BIRT viewer appliction on Webpshere, the idea is to seperate any BIRT long running processso that they do not impact the main applicaion (which has strict performance requirements).
Do you know if it is possible to allocate a thread pool to the BIRT Viewer web app (even if it uses web services? or does a web services call complicate he deployment configuration. Apologies for the array of questions.
We have verified that there are no BIRT reports that consume or reference Web Services, we are currently getting a list of the SQL statements that were running on the database at the time to verify that there were/are NO very inefficient blocks of SQL with any BIRT reports.
Re: BIRT usage of Web Services [message #904614 is a reply to message #904313] |
Tue, 28 August 2012 16:27   |
Anthony
I believe it would be a good idea to open a bugzilla request to help
determine why web service calls were causing threads to hang. BIRT uses
AJAX inside the viewer to call web services on the viewer to run a
report or retrieve a new page when you use page controls etc. If you
are only using charting from the viewer, you could try using the
/preview URL instead of the /run or frameset URL
Jason
> a BIRT report.
> are seeing?
> questions.
FUDForum. Page generated in 0.05215 seconds
