JAR file behaves differently than in Eclipse [message #903782] |
Sat, 25 August 2012 22:22 |
David Tannen Messages: 50 Registered: August 2012 |
Member |
First post here and a newbie to Java and Eclipse (long time programmer). I did some searching around the forum but didn't see anything like this.
Ok I have built a desktop application using Java and Eclipse. When I run it from inside of Eclipse it runs just fine. All of my GUI elements work and the application is great.
But after following the instructions I found How to create JAR file in Eclipse ("codejava.net/ides/eclipse/how-to-create-jar-file-in-eclipse") and tried to run my application the only thing that worked were the 'built in GUI' elements. The FileChooser worked and a message box when closing the application. But all of the GUI elements I put into my application failed.
The zip file I am posting has both the necessary XML input file and the JAR that was created.
Thank you in advance
Attachment: HCM.zip
(Size: 409.91KB, Downloaded 289 times)
David Tannen
[Updated on: Sat, 25 August 2012 22:23] Report message to a moderator
