Re: Version Control System [message #120285 is a reply to message #120259] |
Mon, 28 April 2008 06:30 |
Originally posted by: stepper.sympedia.de
Hi Martin,
As you know CDO supports transparent versioning if the configured store
can do that. Do you think we should give it a try and enhance the
HibernateStore such that transparent versioning is supported out of the box?
Cheers
/Eike
Martin Taal schrieb:
> Hi Yigal,
> Afaik the hibernate versioning is really for optimistic locking and
> nothing more. I think to get complete versioning (to call it that) you
> would need to implement/model it explicitly. Hibernate has some
> concepts which can be helpfull (interceptors/eventlisteners for
> example). Maybe this blog can give some tips:
> http://hacimbengali.blogspot.com/2007/05/versionierung-von-d atenbank-entitten.html
> gr. Martin
> Yigal wrote:
>> Hi Martin,
>> When I generate my Hibernate mapping file, I get the version
>> attribute. Changing the data in the database creates new version of
>> the objects.
>> I have some questions about this:
>> 1. Can I use this feature and create a Version Control
>> application/database (similar to a source control) but for a complete
>> model? After all there are relation to maintain and it could be of
>> several levels and I would to be able to version it and retrieve a
>> certain version that includes the relations at that version.
>> 2. Where can I read more about this?
>> Thanks
>> Yigal
Re: Version Control System [message #120460 is a reply to message #120447] |
Mon, 28 April 2008 20:13 |
> Hi Eike,
> Yes that's a nice idea. However what I am not sure about is how to
> handle foreign key relations in the db using versioning. Afaiu the
> version number needs to be part of the primary key and foreign keys.
> But I can't really imagine how foreign keys can work when the target
> object is updated and a new version is stored in the db.
> How is this done in cdo?
In CDO the foreign keys are not versioned. In general entities are not
looked up via version but via timestamp to get a consistent view across
all entities. This is called an audit view. A normal view that sees the
latest versions (like a floating label) is also available. It will be
necessary to add two timestamp columns (created and revised).
Do you think that would be feasible with Hibernate?
Cheers
/Eike
> gr. Martin
> Eike Stepper wrote:
>> Hi Martin,
>> store can do that. Do you think we should give it a try and enhance
>> the HibernateStore such that transparent versioning is supported out
>> of the box?
>> Cheers
>> /Eike
>>> Hi Yigal,
>>> you would need to implement/model it explicitly. Hibernate has some
>>> gr. Martin
>>> Yigal wrote:
>>>> Hi Martin,
>>>> of the objects.
>>>> complete model? After all there are relation to maintain and it
>>>> could be of several levels and I would to be able to version it and
>>>> retrieve a certain version that includes the relations at that
>>>> version.
>>>> Thanks
>>>> Yigal
Re: Version Control System [message #617928 is a reply to message #120259] |
Hi Martin,
Cheers
/Eike
> Hi Yigal,
> gr. Martin
> Yigal wrote:
>> Hi Martin,
>> the objects.
>> Thanks
>> Yigal
Cheers
/Eike
http://www.esc-net.de
Re: Version Control System [message #617941 is a reply to message #120447] |
> Hi Eike,
Cheers
/Eike
> gr. Martin
> Eike Stepper wrote:
>> Hi Martin,
>> of the box?
>> Cheers
>> /Eike
>>> Hi Yigal,
>>> gr. Martin
>>> Yigal wrote:
>>>> Hi Martin,
>>>> of the objects.
>>>> version.
>>>> Thanks
>>>> Yigal
Cheers
/Eike
FUDForum. Page generated in 0.04360 seconds
