Re: [CDO/Hibernate] Default values are not recognized [message #903098 is a reply to message #903025] |
Tue, 21 August 2012 21:45 |
Hi Christoph,
The behavior should be the same as the dbstore. Can you enter a bugzilla for this on CDO 4.1/4.2?
gr. Martin
On 08/21/2012 06:41 PM, Christoph Keimel wrote:
> Hello
> I am trying to define default values for some attributes of my model.
> Using this model element: ...
> class TestElement {
> String name = "New Element"
> boolean flagged = "true"
> ... with this test code ...
> public void testDefault(IEmTracRepoService repo) {
> TestElement element = EmTracFactory.eINSTANCE.createTestElement();
> Assert.isTrue(element.isFlagged());
> Assert.isTrue(element.getName().equals("New Element"));
> Diagnostic mDiagnostic = Diagnostician.INSTANCE.validate(element);
> Assert.isTrue(mDiagnostic.getSeverity() == Diagnostic.OK);
> CDOTransaction transaction = repo.openTransaction();
> try {
> CDOResource resource = transaction.getOrCreateResource(repo.getResourceName());
> resource.getContents().add(element);
> transaction.commit();
> } catch (CommitException e) {
> logger.info("CommitException: {}", e.getLocalizedMessage());
> } finally {
> transaction.close();
> ... the asserts are all true, but the columns "name" and "flagged" are each saved as NULL in the database. The dbstore
> persists the values as expected with "New Element" and "1", so I presume it is an issue with Hibernate.
> I can think of two solutions:
> * When persisting an entity, use the default value if the attribute is unset or null
> * Use the database default mechanism upon schema generation to define defaults. I. e. with the columnDefinition
> attribute of the @Column annotation. (Probably needs a refresh of the entity after persist.)
> Is one of these features currently implemented? Or do I need to set Hibernate to use "dynamic-insert"?
> Greetings
> Christoph
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
FUDForum. Page generated in 0.03103 seconds
