Re: BIRT WebViewer and Ports, dealing with HTTPS [message #902868 is a reply to message #902831] |
Mon, 20 August 2012 19:04 |
Changing the base href may work.
You could manually change the base href in the frameset fragment jsp or
put the base_url property in the viewer.property files
http://www.scribd.com/doc/44412235/Birt-Viewer-User-Guide#outer_page_9
Jason
On 8/20/2012 12:34 PM, Raishad Maharaj wrote:
> The short version of this is, is there a way to tell BIRT to use port
> 443 instead of 8280 (or whatever port the JBoss server is listening on)
> in the HTML BIRT generates?
> When I click on a report I get this window, it thinks about it for a
> while and then I get a browser prompt
> "Do you want to view only the webpage content that was delivered
> securely?"
> If I click ‘Yes’ the whole thing falls apart. If I click ‘No’ the report
> parameters dialog comes up OK, and then if I look at the HTML I find
> things like this:
> <TITLE>BIRT Report Viewer</TITLE><BASE
> href="http://server:8280/scereports/webcontent/birt"><!-- Mimics
> Internet Explorer 7, it just works on IE8. -->
> [snip…]
> <SCRIPT type=text/javascript>
> var soapURL =
> "http://server:8280/scereports/frameset?__report=report%2Fbilling%2FAccountSetup.rptdesign&__showtitle=false&__timezone=America%2FNew_York&__locale=en_US&__offsetMin=0";
> var rtl = false;
> </SCRIPT>
> Then when I click OK in the parameters dialog I get the browser dialog
> "This page is accessing information that is not under its control.
> This poses a security risk. Do you want to continue?"
> I assume that’s because clicking the OK button uses soapURL to redirect
> to another site/port than was used in the original request.
> The URL I am using to navigate to the report is https://server:443
> Httpd.conf is set up with a ProxyPass directive to redirect any request
> for /scereports on port 80 or 443 to the reports server on 8280. I
> assume BIRT figures out what port it’s running on from the servlet
> request and writes that URL into the HTML it generates. Is there a way
> to tell BIRT to use port 443 instead of 8280?
> I know that with the JBoss 5.1.0 SAML token environment we’re enabling
> SSL between Apache and JBoss and changing the ProxyPass directive to use
> the JBoss server’s SSL port. I’m working on that, but I’m not sure it’s
> going to get rid of the second message dialog, because it’s still going
> to be talking to a different port than the original request.
Re: BIRT WebViewer and Ports, dealing with HTTPS [message #903222 is a reply to message #902868] |
Wed, 22 August 2012 14:31 |
Raishad Messages: 77 Registered: July 2009 |
Member |
Thanks, the viewer.properties change seems to be working
> Jason
>> securely?"
>> things like this:
>> [snip…]
>> var soapURL =
>> var rtl = false;
>> </SCRIPT>
FUDForum. Page generated in 0.02915 seconds
