Calculates with 2 Data Sets [message #902553] |
Sat, 18 August 2012 11:27 |
JOSE LUIS Messages: 5 Registered: August 2012 |
I have a question.
I have two databases one is access and other is MySql. I use information in tables and grid for each of these tables and using differents datasets, but when i want to create a DATA Cell with a result from 2 datasets from i have a problem, I don't know what can i do?.
My case is:
DataSet1 = Only it has a row with a number. TOTALSALES = 1112
DataSet2 = Only it has a row with a numbre. TOTALCOST = 345
I want show the value --> TOTALSALES - TOTALCOST in a grid, but i don't know if this is possible or impossible. The DATA CELL i would like to name = BENEFITS
BENEFITS = DataSet1.TOTALSALES - DataSet2.TOTALCOST
BENEFITS = 1112 - 345 = 767
Thanks.
(sorry for my english its no good)
[Updated on: Sun, 19 August 2012 12:48] Report message to a moderator
Re: Calculates with 2 Data Sets [message #902861 is a reply to message #902553] |
Mon, 20 August 2012 18:32 |
You could do something like:
data set one table
in a table with ds 1 you could write a onCreate script for the data
filed that displays total sales.
reportContext.setGlobalVariable("TS", this.getValue());
or
this.getRowData().getColumnValue("TOTALSALES"));
do the same for the data set 2 total cost, but use a different variable
name, say TC.
Then below both tables add a data item (No binding needed) with the
expression:
reportContext.getGlobalVariable("TS")/reportContext.getGlobalVariable("TC");
You may want to get TC first and check for a 0 value.
Jason
On 8/18/2012 7:27 AM, JOSE LUIS wrote:
> I have a question.
> My case is:
> name = BENEFITS
> BENEFITS = DataSet1.TOTALSALES - DataSet1.TOTALCOST BENEFITS = 1112 -
> 345 = 767
> Thanks.
Re: Calculates with 2 Data Sets [message #905588 is a reply to message #905164] |
Thu, 30 August 2012 17:34 |
You can try two things. First instead of using the setGlobalVariable
just put an a script in like:
TS=this.getRowData().getColumnValue("TOTALSALES");
Note that there is no var keyword which should make TS available
downstream. So in an expression later you could just use TS/TC;
or
Specify the type to store the variable
importPackage(Packages.java.lang);
var mydbl = new Double(this.getRowData().getColumnValue("TOTALSALES"));
reportContext.setGlobalVariable("TS", mydbl);
Jason
On 8/29/2012 4:42 PM, JOSE LUIS wrote:
> Hello Again,
> I have a problem. When data are INTEGER i have no problem, but when data
> are DECIMAL or MONEY, RESULT is 0 in all case.
> Do you know what is it happening?
> Kind Regards
Re: Calculates with 2 Data Sets [message #906215 is a reply to message #906195] |
Fri, 31 August 2012 21:16 |
can you try?
parseFloat(reportContext.getGlobalVariable("TS"))/parseFloat(reportContext.getGlobalVariable("TC"));
Jason
On 8/31/2012 4:34 PM, JOSE LUIS wrote:
> Thanks for your information, but if I use the first expression
> for example --> TS = 4.945,45 and TC = 2800,00
> if I apply to get result:
> the result is: 4945452800. This expression dosen't sum, this expression
> joining the numbers like a text. Do you know, what is happening?.
> Thanks.
Re: Calculates with 2 Data Sets [message #908003 is a reply to message #906380] |
Tue, 04 September 2012 14:33 |
Verify that reportContext.getGlobalVariable("TS") or
reportContext.getGlobalVariable("TC") is not null before you do the
division.
Jason
On 9/1/2012 5:34 AM, JOSE LUIS wrote:
> Good Morning Jason,
> When I used this expression
> parseFloat(reportContext.getGlobalVariable("TS"))-parseFloat(reportContext.getGlobalVariable("TC"));
> Eclipse give me a error:
> Grid (id = 2825): + Can not convert the value of NaN to BigDecimal type.
> CONVERT_FAILS ( 1 time(s) )
> detail : org.eclipse.birt.report.engine.api.EngineException: Can not
> Do you know what can we do?
> Thanks, Kindest regards
FUDForum. Page generated in 0.04004 seconds
