XMI Resource to BinaryResourceImpl [message #902299] |
Thu, 16 August 2012 16:55  |
Hi Everyone,
We are trying to migrate from XML based resources to Binary resources in our application (due to performance reasons).
In order to do so, there are 2 issues we are trying to get around:
1. We see considerable improvements in the save time and the file size, however, there is an increase in load times in case of Binary resources, which is unexpected.
Here are the stats:
XMI Resource loaded in 7244 ms
XMI Resource saved in 2493 ms
XMI File Size 86,359 KB (84.2 MB)
Binary Resource loaded in 8905 ms
Binary Resource saved in 862 ms
Binary File Size 24,842 KB (24.2 MB)
And this is how we are loading / saving the resources:
ResourceSet resourceSet = new MyResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap()
.put("binary", new Resource.Factory() {
public Resource createResource(URI uri) {
return new BinaryResourceImpl(uri);
EObject model = ModelUtils.load(URI.createFileURI(sourceFileName), resourceSet);
Resource resource = model.eResource();
resource.save(null);
In the above code, MyResourceSetImpl has a default resource factory (for xml-files), and a custom factory (for binary-files). The resource are instantiated fine, with out any problems based on the type of the file. But we can't figure out the reason for the increase in load time.
What are we missing?
2. The other problem is that we are currently using UUID's to identify the objects. Since UUID's are string based, and binary files can't be "read", is there a suggested alternative to ID the instances in binary file format?
Thanks in advance!
- Karan Anand
Re: XMI Resource to BinaryResourceImpl [message #902320 is a reply to message #902299] |
Fri, 17 August 2012 00:44   |
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
Karan,<br>
<br>
Which version of EMF are you using? I know there were issues with
buffering on the input and output streams that caused things to be
slow; this was fixed in 2.7. Also, XMLResource.OPTION_BINARY was
added so that an XMLResourceImpl can read or write binary, <b>and </b>can
load and save the extrinsic ID map so you don't loose the IDs you
get when you serialize XML/XMI.<br>
<br>
<br>
<div class="moz-cite-prefix">On 16/08/2012 10:55 PM, Karan Anand
wrote:<br>
</div>
<blockquote cite="mid:k0jmnk$a7b$1@xxxxxxxxe.org" type="cite">Hi
Everyone,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Here are the stats:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
resourceSet);
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Thanks in advance!
<br>
<br>
- Karan Anand
<br>
</blockquote>
<br>
</body>
</html>
FUDForum. Page generated in 0.08609 seconds
