Home » Eclipse Projects » Eclipse Scout » Smartfield - Key Shortcut for Browse New
Smartfield - Key Shortcut for Browse New [message #902068] Wed, 15 August 2012 13:47 Go to next message
I am using getConfiguredBrowseNewText() and execBrowseNew(String searchText) on a Smartfield. This displays the "New" link as desired:
index.php/fa/11198/0/
How do I create a key shortcut for this link? Simply adding a key stroke to the smartfield doesn't seem to work when the proposal form is open.
Re: Smartfield - Key Shortcut for Browse New [message #903842 is a reply to message #902068] Sun, 26 August 2012 05:49 Go to previous messageGo to next message
By overriding
protected ISmartFieldProposalForm createProposalForm() throws ProcessingException;
and patching the New Button to IButton.DISPLAY_STYLE_DEFAULT
import org.eclipse.scout.commons.exception.ProcessingException;
import org.eclipse.scout.rt.client.ui.form.fields.button.IButton;
import org.eclipse.scout.rt.client.ui.form.fields.smartfield.ISmartField;
import org.eclipse.scout.rt.client.ui.form.fields.smartfield.SmartTableForm;
public class KeyStrokeSmartTableForm extends SmartTableForm {
  public KeyStrokeSmartTableForm(ISmartField<?> smartField) throws ProcessingException {
    super(smartField);
  protected void execInitForm() throws ProcessingException {
    super.execInitForm();
    getNewButton().setDisplayStyleInternal(IButton.DISPLAY_STYLE_DEFAULT);
it is at least possible to use button mnemonics to execute the button using the keyboard.
However, it would be great to use f-keys as well without replacing the whole SmartTableForm.
Re: Smartfield - Key Shortcut for Browse New [message #904047 is a reply to message #903842] Mon, 27 August 2012 12:14 Go to previous messageGo to next message
Hi Adrian
Defining a key stroke for the browse new link does not seems to be supported yet. I tried it with adding a class of AbstractKeyStroke to the SmartTableForm, but with no success either.
The approach we usually use is to define a new menu on the smartfield (which supports key strokes).
      @Order(10.0)
      public class SectorField extends AbstractSmartField<Long> {
        protected String getConfiguredLabel() {
          return TEXTS.get("Sector");
        protected Class<? extends LookupCall> getConfiguredLookupCall() {
          return CompanySectorLookupCall.class;
        @Order(10.0)
        public class NewSectorMenu extends AbstractMenu {
          protected String getConfiguredText() {
            return TEXTS.get("NewSector_");
          protected boolean getConfiguredEmptySpaceAction() {
            return true;
          protected void execAction() throws ProcessingException {
            newAction();
          protected String getConfiguredKeyStroke() {
            return "F3";
        private void newAction() {
          // add desired action here
        public class F3KeyStroke extends AbstractKeyStroke {
            return "F3";
            newAction();
Stephan
Re: Smartfield - Key Shortcut for Browse New [message #904327 is a reply to message #904047] Tue, 28 August 2012 04:49 Go to previous messageGo to next message
Thanks for your suggestion, Stephan.
But the key stroke action of the menu is not executed when the proposal form is open.
What I want, is a user-friendly way to add new entries to a smartfield:
- user types a 'ABC'
- smartfield proposal form opens, 'ABC' is not found
- when the value is not available, the user should be able to press a key shortcut and open a form to create the new entry with 'ABC' prefilled
Re: Smartfield - Key Shortcut for Browse New [message #905573 is a reply to message #904327] Thu, 30 August 2012 12:55 Go to previous messageGo to next message
Hi Adrian
This does not seem to be possible right now. What you need is something like a getConfiguredBrowseNewKeyStroke method on AbstractSmartField, am I right? Can you create a bugzilla ticket for this.
Thanks!
Stephan
Re: Smartfield - Key Shortcut for Browse New [message #905837 is a reply to message #902068] Fri, 31 August 2012 03:13 Go to previous messageGo to next message
I opened ticket
https://bugs.eclipse.org/bugs/show_bug.cgi?id=388494
Thanks for your support.
Re: Smartfield - Key Shortcut for Browse New [message #1709121 is a reply to message #902068] Thu, 24 September 2015 04:27 Go to previous message
have a look at getConfiguredBrowseNewText() in AbstractContentAssistField.
   * When the smart proposal finds no matching records and this property is not
   * null, then it displays a link or menu with this label.<br>
   * When clicked the method {@link #execBrowseNew(String)} is invoked, which in
   * most cases is implemented as opening a "New XY..." dialog
Previous Topic:Creating new Form to TablePage
Next Topic:[Blog Post] Maven repository for Mylyn Wikitext
Current Time: Wed Sep 24 04:07:16 EDT 2025
Powered by FUDForum. Page generated in 0.04880 seconds
