How to change tab color? [message #901945] |
Wed, 15 August 2012 08:44 |
Markus Pitha Messages: 5 Registered: August 2012 |
I reconfigured Eclipse Juno to use the classic theme look. What I can't get managed is the tab color of all tabs. They are blue and this causes eye cancer to me. I couldn't find any setting to solve that. In earlier versions I had success with changing colors of list items, not configurable by Eclipse itself, while using an ".eclipse-gtkrc":
style "eclipse" {
font_name = "Sans Condensed 8"
style "listitem" {
base[ACTIVE] = "#AAAAAA"
class "GtkWidget" style "eclipse"
class "GtkTreeView" style "listitem"
And invoked it like this:
#!/bin/bash
env GTK2_RC_FILES=/usr/share/themes/Ambiance/gtk-2.0/gtkrc:/home/markus/.gtkrc-eclipse '/opt/eclipse/eclipse'
I tried to solve this tab color problem in the same way, but I don't know which GTK component this is. I thought it is GtkNotebook, but changing colors of this widget has no effect.
Any ideas how to change the tab colors, maybe in a different way?
By the way: There are settings to change the colors (see tabcolor_juno.png), but these settings don't cause any effect, so can I assumed it is a bug?
Attachment: juno.png
(Size: 34.78KB, Downloaded 400 times) -
Attachment: tabcolor_juno.png
(Size: 119.17KB, Downloaded 399 times)
[Updated on: Wed, 15 August 2012 09:21] Report message to a moderator
Re: How to change tab color? [message #901983 is a reply to message #901973] |
Wed, 15 August 2012 12:05 |
Thanks, but I can't install that. You can't neighter add github.com/tomsontom/e4-e3theme/downloads nor github.com/tomsontom/e4-e3theme (incldung https:// which I can't add here due to strange spam protection in this forum) to Available Software Site in Eclipse, because it ends up in a "Could not find...." or "No software site found".
You can't install it by local repository too. I'm not sure what to import there. The zip file, the tar.gz or some unzipped file? None of these worked and ends up in the error message from above. Any ideas what's wrong with that?
[Updated on: Wed, 15 August 2012 12:06] Report message to a moderator
FUDForum. Page generated in 0.03588 seconds
